I took out the mechanical fan this past weekend. This is a common mod on e36 and e46 M3's, supposedly worth 8hp on a dyno. The electric pusher fan is still there, for idling in traffic. I may get an additional electric fan before the weather warms up, if i feel any difference in power. Initial impressions are minimal, I pretty much i don't notice any change, not that I could feel 3-4 hp if it actually gained anything. At idle, the engine seems to rev a bit freer, but it could be the lack of fan noise...
What can I say, the weather was bad and I was bored, this is a 3 minute mod! (it is surprising how much noise the fan made, now that it's gone!)
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
Ok, I guess you are now going to remove the power steering as well! Have your thought about the Evosport power pullies?
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
Do you think the standard electric fan will be enough in July in bumper to bumper traffic? I think "mr bock" has a full electric fan setup. Let me know how this does in some spirited driving runs.
Joe
'00 E39 S62 ///M5 Carbon Black/Caramel
AA CAI
UFM IATS Relocation Kit
SuperSprint Headers
Bassani Racing Cats-Custom Tubing
Tubi Cat Back System
Powerchip 93
UUC Lightweight Flywheel
UUC Stage III Clutch
Rogue Engineering Tranny Mounts
3.45 Diff KMS Ring & Pinion Swap
TC Designs Rear Swaybar Brackets
Royal Purple Syncromax Tranny Fluid
UUC SSK
UUC DSSR
If you happen to be able to plan in a dyno of the car with and without the fan that would be quite interesting.
There is nothing wrong with removing the clutch based fan, I do it on all of the Supercharged conversions and have considered the same on NA applications as well. However, I would highly recomend replacing it with a good electric fan. If the motor were to overheat it will become a very expensive service call.
With regards to the pusher fan that you spoke of; it is the aux. AC fan and is not designed to cool the radiator.......Its primary purpose is to cool the condensor core for more efficient AC operation in the exteme heat.
My fan has been out for a couple summers now and no problems, but 90+ degree days are uncommon where I live. I weighed the fan once, but forgot the reading. Maybe about 6 pounds...
edit: it's 4 pounds.
How did you remove it? You mentioned a 3minute method?
I'm not so intrested in the couple of horse powers, but if it makes the car idling and running quieter that's enough for me.
Removing the fan is super easy... put a big wrench on the nut (where fan meets the engine) and give a quick smack to the wrench with a hammer. Caution!!! REVERSE THREADS!!!! Spin the nut free and out comes the whole fan. When I first did mine, I drove the beast for a few miles to see how it felt. The only thing I noticed is that the rpms stayed higher between shifts. Due to less inertia/drag??? My temp was going up some while sitting at stop lights, so I added the electric fan (pulling air throught the radiator). Something different?, minor enhancement?
LOL
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
Mr Bock has it right. Big wrench (i used a crescent), wack towards the right it spins right off. Nothing else needs to be removed too get it out.
If i get on a dyno anytime again soon, ill try both with and without.
MAH: i already have the pulleys!
I will either re-install it or go the electric route, before the weather gets warm. Today, with plenty of driving around town in traffic, coolant temp never went beyond 12 oclock (i know that is meaningless), at low load cruise it's at my normal 'wintertime position' of about 11 oclock. Oil temp never over 200, usually around 180. So i'd say it's ok for 50F weather. The aux did kick on a couple of times at prolonged traffic lights etc. No changes under hard acceleration either (as far as temp), but again, it's cool outside.
Another plus is no worries about the self destructing OE fan/clutch assembly. I figure if that were to go, in addition to a rad and hoses, i'd be shopping for new cai tubes!
what type of project (approx. time and expense) is putting in an electric fan? Did you do this yourself?
Thanks.
LOL
Silver 2003 M5
GC Coilovers by Shadowman
Supersrint Headers by Shadowman
Supersprint X-Pipe
Dinan Exhaust
Shadowman Software
IATS by Shadowman
AA Cold Air Intake
Dinan Rear Sway Bar
Dinan Front Strut Bar
B&M SSK
DSSR
Power Pulleys
SSR GT3s - 8.5 & 10 x 19 w/ SO3s & 285s in Back
