Old 1st January 2005, 04:20   #1
Keith97M3turbo
Keith97M3turbo's Avatar
Garage: 01 M5 White
Alcantara wheel and boots
After getting the idea from a member selling his beast in the For Sale forum, it sounded like a next step, so here it is.
The wheel is from the 330i PP (pn 32 34 7 919 218)
The swap of the wheel and boots took no time at all.
Disconnect battery, push airbag release springs(2), loosen 16mm bolt, remove 2 clips inside wheel, remove wheel.....reinstall. Just that easy.
And the boots ,well r&r.
The boots are from Leatherz www.leatherz.com
Very good stuff I must say.
And by the way HAPPY NEW YEAR!
SOLD! [color=Navy]Power Parts:
Powerchips Gold/93 , RDSport Comp. headers(coated) , Dinan CAI,
Ign. Solutions coils , Evosport pulleys , UFM IATS kit
Tubi catback & Random Tech metal cats
Heat barrier on lower plenum , UUC clutch&flyweel kit
Evosport 3.45 diff.(static&dynamic changed) , Schrick cams
Susp.& Brakes:
BBS LM'S (19x9-19x10)(255-285's)
FK Koenigsport coilovers , H/Depot mod w/ euroducts
Eibach/Technik swaybars w/ B/Power brackets
Wiechers Strutbrace , Axxis Ultimates f/r
Exterior:
E6 CSL splitter & rear diffuser trim , E6 carbon hood ,E6 carbon eyelids
M motorsport door emblems
Tecknic carbon door pillars
Hamann Rear Diffuser
Interior:
UUC SSK , Euro dash conversion & center armrest,
Alcantara steering wheel & shift/e-brake boots, TEC cup holder
Misc.../In the works../Considering todo..:
[size=1]Rennsport/Tecknic v/stacks (uninstalled)
Plenum Spacer DONE! but not tested (4-5-04)
Extra set of stock t/boddies (bored to 54mm)
Keith97M3turbo is offline
Old 1st January 2005, 04:37   #2
boostmiser
boostmiser's Avatar
Garage: 2002 Alpine White M5
Re: Alcantara wheel and boots
That looks great Same thickness? How's it feel....better than leather?? more grip??
How much for the wheel??
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
boostmiser is offline
Old 1st January 2005, 05:35   #3
MPRESIV
Garage: W211 E55 - E60 M5
Looks good
How much is the alcantara Shift and Emergency Brake boots ?
ronnierenaldi.com | superb-image.com
MPRESIV is offline
Old 1st January 2005, 05:45   #4
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
I love that wheel! What year is your car, will this work on a 2000 with the older style wheel? I had thought about doing this, but my friend at the dealer parts dept said the alcantara 'balls up' and wears out quickly, and they'd replaced a ton of them under warranty on 330pp cars, some with std leather wheels, after the second alcantara wheel. Let us know how it wears!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 1st January 2005, 05:54   #5
BmwNut
BmwNut's Avatar
Garage: '01 540/6
Send a message via AIM to BmwNut
I like the wheel, but I dont really care for the shift and ebrake boot. Alcantara on the wheel does get messy as Mike said, so let us know how it wears. A good pair of driving gloves would probably lessen the balling and discoloring.
-Brendan
'01 540/6
BmwNut is offline
Old 1st January 2005, 07:46   #6
2003 M5!!!
2003 M5!!!'s Avatar
Garage: 2003 Silver M5
I have always liked that wheel too! Nice job . . .
Silver 2003 M5
GC Coilovers by Shadowman
Supersrint Headers by Shadowman
Supersprint X-Pipe
Dinan Exhaust
Shadowman Software
IATS by Shadowman
AA Cold Air Intake
Dinan Rear Sway Bar
Dinan Front Strut Bar
B&M SSK
DSSR
Power Pulleys
SSR GT3s - 8.5 & 10 x 19 w/ SO3s & 285s in Back
View My Alien Technology Project!
2003 M5!!! is offline
Old 1st January 2005, 12:35   #7
amfung
Nice one. Do they have one with the M tri-color stiching ?
amfung is offline
Old 1st January 2005, 14:11   #8
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
With that color interior, I think it looks very good, especially the way the boots match up. How many horsepower is it good for?
gsfent is offline
Old 1st January 2005, 18:59   #9
Keith97M3turbo
Garage: 01 M5 White
Boostmeister, same thickness, it feels SOOOO nice, kinda grippy.
I think the wheel was mid 300ish, I'll have to find my reciept,I work at and around the car dealers so I get employee price. I'll look!
Mpresiv, I think the boots were 165., if you haven't looked at the site check it out, you can even custom select colors. Look at the e46 and z4 links there are some colors there.
Motatti, mine is a 2001, as for the swap you most likely can the only thing I don't know is if the slip ring is the same, if it isn't is no problem you can get the slip ring too ,if I recall they aren't to much. But again you might not even need that. Have your friend in the parts dept. look and see if the slip rings are the same from 00 to 01 if so it's just a easy wheel swap.
As for the wear, I've heard that aswell, but hey I thought I'd try it anyway.
And I don't drive my car to much lately so I wasn't terribly concerned, but I will report on any wear.
amfung, no tri stiching that I know of, but it does have the M logo on the bottom just like our stock wheel.
Jerry, shoot I think it's good for at least 5 'cosmetic' hp.,you think?
Too bad no butt-o-meter hp's though.
Susp.& Brakes:
Exterior:
Interior:
Old 1st January 2005, 19:30   #10
gsfent
gsfent's Avatar
You know, if tri stitching was important, I would think any company that refinshes steering wheels could restitch for you. Someone has to do it for BMW M cars. Not sure if it is worth the $$$, but it might very well be do-able. Might see who the dealer uses if they have to restitch a wheel. There is a place in south Florida, I think it is called AGLA.
gsfent is offline
Page generated in 0.16805 seconds with 11 queries
