SES light stays on - 4 fault codes - BMW M5 Forum and M6 Forums
Old 17th December 2004, 13:12   #1
M5 CFF
M5 CFF's Avatar
Garage: BMW M5 E39 2000 Le Mans Blue
My SES engine management light came on recently. I took it to a BMW dealer & asked them to do a diagnostic test. They found no faults currently present, system reset. When my car returned by the dealer, that little yellow light is still on.
I booked the car in again for another diagnostic test (which they tried to charge me for again). Again they say no faults currently present & reset the system. Thank you sir, good bye. However, I requested a copy of the diagnostic report. On the drive home that little yellow light reappeared.
Looking at the diagnostic report it lists 4 faults:
1. Camshaft sensor, bank 1, synchronisation to crankshaft, recorded as 3th fault in fault memory. OBDII code: P0394. Detected 11 times.
2. Signal, oxygen sensor before cat. bank 1 recorded as 1th fault in memory. OBDII code: P0134. Detected 189 times.
3. Signal, camshaft sensor, exhaust, bank 1 recorded as 2th fault in memory. OBDII code: P0365. Detected 36 times.
4. Function, exhaust VANOS, bank 1 recorded as 4th fault in memory. Actual value too high. OBDII code: P0014. Detected 11 times.
I have booked the car in again. But judging from previous posts, this can really take many visits to finally fix. Can anyone please decipher the above, so I might be able to point the dealer in the right direction. BTW the car runs fine & drinks only Shell.
Thanks in advance for any help. Chris
BMW M5 e39 2000 Le Mans Blue
Previously owned:
BMW M5 e34 1995 Sterling Silver Touring "Elekta"
BMW M5 e34 1992 Diamond Black Touring
BMW M5 e34 1995 Avus Blue
Kawasaki ZX12R
Audi S2 quattro
BMW 320d
Golf GTi
Mazda MX5
Kawasaki GPZ900R
M5 CFF is offline   Reply With Quote
Old 17th December 2004, 13:22   #2
x703jko
x703jko's Avatar
Garage: 2003 Dinan S3 M5, LeMans Blue/Caramel
Re: SES light stays on - 4 fault codes
There may not be any recent codes, but the fact that some of the conditions that caused the codes occurred multiple times is why your car is throwing SES lights even after the light is cleared. Take your car to a dealer that has service engineers that know what they are doing.
Although I'm not the resident expert, the codes point to a faulty camshaft sensor I believe.
Jeff
2003 M5 LeMans Blue/Caramel/Walnut
Dinan S3 Includes all Dinan S3 Mods With JRZ Sruts/Shocks, Oil Cooler, Monoball Links
StopTech 4 Wheel BBK With Red Calipers And Slotted Rotors
Axxis Ultimate Pads
M Enhanced Audio
Park Distance Sensors
Two Sets Of Dinan Lightweight Forged Wheels
Winter Tires - Michelin Pilot Sport A/S - 275/35ZR18(Y) (F); 285/35ZR18(Y) (R) (Not Sure If They'll Survive The S3)
Summer Tires - Toyo RA1s- 275/35ZR18(Y) (F); 275/35ZR18(Y) (R)
Dual, Front Mounted LE30's With Custom AIDesigns Kill Switch/LED Panel
Valentine V1 With Stealth One
UUC Short Shifter With DSSR
Oil - BMW/Castrol 5W30 Changed and tested every 3000 miles.
x703jko is offline   Reply With Quote
Old 17th December 2004, 13:25   #3
Ahmed
Ahmed's Avatar
Garage: Black C63 AMG P31
Sales Feedback: (4)
Yes indeed....
Same faults appeared on my system as well, and a new exhaust cam position sensor fixed it!
When no faults are throwned and there are obvious problems with the car, 8 outta 10 times its a MAF fault!
2006 E60 M5 Sepang Bronze/Natural Brown/Olive Ash (RIP)
2013 C63 AMG P31 Magnetite Black/Classic Red & Black/Carbon Fibre
Ahmed is offline   Reply With Quote
Old 17th December 2004, 15:42   #4
BMW_Jim
BMW_Jim's Avatar
Garage: 2002 BMW M5 Artic Silver
I had the same problem with my car. I had taken it in multiple times and they said no problem but the SES light kept coming on.
I searched our board's posts and found a reference to the Peak Research scan tool. So, I purchased a scan tool from http://www.peakeresearch.com/ and scanned the car codes myself. (It is super easy and you don't have to delete the codes so whatever you see the dealer can see.) I then called my dealer and told them what I found and, low and behold, they made an appointment for me to bring in my car and replaced my cam shaft sensor under warranty. Now the SES light no longer comes on and the car runs even better than before (I hadn't really dedected the reduction in performance from the problem).
Sometimes a little knowledge makes the difference between getting your car fixed or not. The $150 for the tool was a small price to pay for the knowledge it provided me. And no, I'm not connected with Peake Research in any way. I'm just a very satisfied customer.
Good luck!
Jim
2002 M5
Titanium Silver Metalic
BMW_Jim is offline   Reply With Quote
Old 18th December 2004, 17:19   #5
M5 CFF
M5 CFF's Avatar
Thanks Jeff, Ahmed & Jim for your very helpful suggestions. Regarding the interesting Peake Research Scan Tool, I hope my BMW dealer uses something similar, or am I asking for too much?!
Regards
Chris
Old 18th December 2004, 19:46   #6
louv
louv's Avatar
Garage: '00 M5 Carbon Black / Caramel
Regards
Chris
Your dealer is useing something far more sophisticated than a Peake tool, probably a GT1. The Peake = US$150. GT1 = US$15,000.
From those codes (and my expereince) I'd start by replacing the Exhaust Cam Position Sensor (bank 1... the easier one!) US$100 parts, 1/2 hour labor.
If that doesn't do it, then replace the Pre-Cat O2 sensors (may as well do both sides). Easy.
Both of these are fairly easy do-it-yourself jobs. (if you have a TIS and ETK for instructions...)
1989 750iL 220k, but still runs great
2000 M5 128,000 miles. All mine. mine. mine.
2001 Tundra Hauls... stuff
2008 Z4 M Coupe My Roundel Cover Girl
2008 Mercedes C350 Sport wifey's car
2009 BMW R1200GS-Adv Rode to the Arctic Circle
2010 BMW G450X Dirt Bike with a Roundel
louv is offline   Reply With Quote
How many M5 owners to change a light bulb? Aussie2U Off Topic Forum 36 29th November 2009 21:54
SES Light - Engine Misfire! x703jko E39 M5 and E52 Z8 Discussion 24 8th March 2005 19:49
fault codes without SES light? mottati E39 M5 and E52 Z8 Discussion 9 1st December 2004 23:27
Need help please.... My SES light just appeared. FAST 5 E39 M5 and E52 Z8 Discussion 9 9th June 2003 19:37
TECH: SES light on... BlueBomber E39 M5 and E52 Z8 Discussion 5 9th May 2002 17:21
