Old 10th December 2004, 01:32   #1
jaymag
Garage: bmw m5 carbon black
hesitation 2k to 3k rpms
I often experience a little sluggishness between 1k to 2k rpms and some slight hesitation, or what seems to be loss of linear power, between 2k and 3.5k rpms. The condition is not dependent on engine temperature and seems to improve when in sport mode. Once I get above 4k things seem fine.
Through searches on the board, I've read some comments that faulty / dirty MAFS caused some degree of poor performance. Could this be it, or does bad MAFS cause poor performance throughout the entire range of rpm's?
BTW, it's a 2003 M5 with aprox 14k miles and the lack of linear power has been an issue for awhile.
Any suggestions so that I can direct the dealer are appreciated.
Thanks,
MJ
jaymag is offline
Old 10th December 2004, 01:57   #2
khiroshima
khiroshima's Avatar
Garage: 2001 M5 silver
Re: hesitation 2k to 3k rpms
MJ, do you find that this happens with and without the Sport button depressed? I notice this as well with my 2001 (52k miles), but it seems to not be as noticable in Sport. Kevin
khiroshima is offline
Old 10th December 2004, 02:15   #3
stair69
stair69's Avatar
Garage: M5 Le Mans Blue
Probably asking the obvious, but do you have DSC turned on? I've found that it causes a bit of hesitation at those revs even if the yellow "DSC" light isn't flashing.
Cheers
Alastair
stair69 is offline
Old 11th December 2004, 00:34   #4
jaymag
The hesitation is not as noticeable with sport mode on, and i usually drive with DSC on. Also, the hesitaiton happens without DSC engaging (ie the light does not come on). It feels as if the rpms are increasing without a corresponding increase in power, but I must admit that it isn't always as noticeable. However, the car I drove at the M5 driving experience in NC was much more responsive, even without using the sport mode.
jaymag is offline
Old 11th December 2004, 00:37   #5
chunpng
chunpng's Avatar
Garage: M5, silver/black
Mine does it only when it's very cold. I now let the car idle until the RPM drops to the 750 RPM steady state before I drive off. Seems to help that way.
CP
CP
00 Titanium Silver: 6/00-1/05 RIP
95 Black Metallic RUF BTR-2
07 Meteor Grey Cayman
chunpng is offline
Old 11th December 2004, 00:50   #6
jaymag
jaymag is offline
Old 11th December 2004, 00:55   #7
jaymag
CP- mine runs rougher when cold, but I discount that. I've heard the same from many m5 owners.
jaymag is offline
Old 11th December 2004, 01:12   #8
ELEVENS
Garage: '03 M5 LMB/LMB&Al
That's pretty common, it seems. I think BMW has the temperature enrichment map too lean, perhaps for emission reasons. A powerchip reprogram will fix that quite nicely.
ELEVENS is offline
Old 13th December 2004, 04:42   #9
jaymag
Does the powerchip reprogram fix the cold temp hesitation (which I'm not all that concerned about) or the general acceleration performance? Can the dealer just change the temperature enrichment map without me purchasing a chip? Thanks!
jaymag is offline
Old 13th December 2004, 21:09   #10
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
It helped tremendously on mine. There is no "chip", the ECU is reprogrammed through the OBDII interface. If you run a board search, I think everyone who has upgraded to Powerchip is pleased. I just had them adjust mine for the header install, and the car is smoother still. Make sure you mention this board if you order, at one time they were giving a board discount, something like $100.
Dealer can't just enrich part of the ECU maps AFAIK. They can upload new and improved software that BMW gives them, but I am unaware of any programming ability on the part of any of the dealerships.
gsfent is offline
Dinan software causes idle to go to 900 rpms = too loud! atomic80 E39 M5 and E52 Z8 Discussion 13 6th September 2002 17:13
Lumpy power delivery below 2K rpm? SilverSBlack5 E39 M5 and E52 Z8 Discussion 6 5th June 2001 18:13
Oil change every 3k or waiting for service indicator? ALX E39 M5 and E52 Z8 Discussion 1 20th April 2000 01:18
Page generated in 0.16049 seconds with 11 queries
