Old 7th December 2004, 21:32   #1
Thunderbird
Thunderbird's Avatar
Garage: 2000 E39 M5, titanium silver
I need some help w/ air flow meters
I think I may have gotten my Air Flow meters dirty. I recently got the Dinan CAI and MAF's and I never drive the car in the rain but lately I have had to and it has rained alot. I have been getting a Service Engine Soon light going on and off and the car is runing rich so I can tell there has been a fault and my BMW dealer checked it out and said there was a cam sensor fault and air flow meter fault. My Dinan dealer told me that is possible that I got the AFM's dirty bec. of the wet conditions that I have been driving in that I could have picked up some garbage in my air intake and with all the water and moisture it has most likely stuck to the AFM's. Has anyone had this problem and what is the best way to clean the meters.
Thunderbird is offline
Old 8th December 2004, 03:04   #2
Wrightsville Beast
Wrightsville Beast's Avatar
Garage: 2002 Jet Black M5
Re: I need some help w/ air flow meters
Do a search. I just posted a thread a few weeks ago about my experince cleaing MAFS.
Wrightsville Beast is offline
Old 8th December 2004, 05:50   #3
6spd
6spd's Avatar
Garage: 73 Pinto Babypuke Green
Try a non film contact cleaner, you can get it from a eletronics store/hardware store. There was a question like this a few months back.
6spd is offline
Old 8th December 2004, 10:36   #4
jjc1843
jjc1843's Avatar
Garage: 2000 M5 Carbon Black
Send a message via AIM to jjc1843
If you run K&N filters, they are known to contaminate the MAF's (Mass Air Flow Sensor).
Shouldn't the air filter catch "debris"?
Posts abound on how to clean them. It's an easy DIY project.
There is also an excellent post on how to replace the CPS's.
Good luck
Joe
'00 E39 S62 ///M5 Carbon Black/Caramel
AA CAI
UFM IATS Relocation Kit
SuperSprint Headers
Bassani Racing Cats-Custom Tubing
Tubi Cat Back System
Powerchip 93
UUC Lightweight Flywheel
UUC Stage III Clutch
Rogue Engineering Tranny Mounts
3.45 Diff KMS Ring & Pinion Swap
TC Designs Rear Swaybar Brackets
Royal Purple Syncromax Tranny Fluid
UUC SSK
UUC DSSR
'95 525i Black/Parchment 195K Eibach/Billstien/Power Chip [Sold!!!!]
jjc1843 is offline
Old 8th December 2004, 19:36   #5
Thunderbird
Thanks for the advice guys
Old 8th December 2004, 23:53   #6
gra8fuldd ed
gra8fuldd ed's Avatar
Garage: 2003 M5 Carbon Black w/Imola Red
Thunderbird:
How long ago did you have your Dinan CAI & MAFS installed? I ask this because, Sometime in within the last year, Dinan upgraded their install procedure, Parts and the location of the IATS. Do you have the Dinan Rain or Water Ducts behind your foglights?
If NOT ... You may want to go see your Dinan dealer and ask about upgrading ... I don't that Dinan has a charge for this ... You just need to call Dinan and discuss the problem with them.
I've had the Dinan CAI and MAFS for just shy of a year without incident. I also have the Dinan Water & Debris Protection Ducts which are located directly behind each of the Foglights.
Hope this helps.
gra8fuldd ed is offline
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 10:23
Air / Fuel reading with Dinan CAI & High Flow Airmass Meters? howler E39 M5 and E52 Z8 Discussion 4 18th September 2004 04:03
Dinan's CAI and High Air Flow Meters TexasM5 E39 M5 and E52 Z8 Discussion 12 23rd March 2004 23:27
Question for guys that have Dinan CAI & air flow meters or anyone knowledgable....... FAST 5 E39 M5 and E52 Z8 Discussion 61 31st December 2003 15:45
Page generated in 0.10627 seconds with 11 queries
