Old 7th December 2004, 20:12   #1
Wilkie
Garage: 01 Ti Silver M5
Advice on Mounting Front License Plate Frame
Just got my third ticket for having no front license plate. This is a fix-it ticket (I can't just pay a fine), so I'm going to bite the bullet and mount my front plate. In looking at the front license plate frame my dealer provided me, I note that the bottom has hooks that fit neatly into slots cut into existing slots at the bottom of the bumper, and at the top, each corner has two holes, a large one and a smaller one with a threaded brass insert, to attach to the bumper. Has anyone monted this frame? Do I use the larger holes or the ones with the threaded brass inserts? If I use the non-threaded hole, I presume I can just drill a hole into the bumper and use a machine screw to mount the frame; not sure how to do it using the threaded hole.
Any help or suggestions appreciated.
Thanks,
Wilkie
Wilkie is offline
Old 7th December 2004, 20:22   #2
SC'dKellenersM5
SC'dKellenersM5's Avatar
Garage: Red White and Blue
Re: Advice on Mounting Front License Plate Frame
wilkie...im going to look at my m3 right now. I had to move from a no front plate state to a front plate state here in TX..
verdict..
the ones nearest the outside of the plate holder are for attaching to the bumper...the inner ones are for holding the plate
Im in the highspeed aluminum business
SC'dKellenersM5 is offline
Old 7th December 2004, 21:42   #3
Philip
Garage: Pinto--Black
Send a message via ICQ to Philip
Can the plate bracket be mounted by NOT using the upper 2 holes (don't have to drill holes into face of bumper)? I've never had my plates put on, and would put the front on only temporary for a cop to sign off on.
Philip is offline
Old 7th December 2004, 23:33   #4
Wilkie
verdict..
Well, there are actually THREE sets of holes-- I aligned the license plate to the frame, and the holes on the plate match up with a third set of (smaller, unthreaded) holes on the frame. If the frame attaches via the outside holes, as you indicate I wonder what the other holes (with the threaded brass insert) are for?
Thanks for your reply.
Wilkie is offline
Old 7th December 2004, 23:38   #5
Wilkie
Well, I've heard from other people on this forum that they've taped or velcroed the plate on the front, took it in for the inspection, and then took it off again once it passed. However, I don't think I could live through the embarassment if I tried that, and just my luck, the plate would fall off right while the cop was inspecting it!! On the other hand, maybe a super strong double sticky tape might work??
Wilkie
Wilkie is offline
Old 7th December 2004, 23:53   #6
boplaw
boplaw's Avatar
Garage: 00 M5 White
Use 3M double sided tape. It is sold at Home Depot in the paint dept. Make sure you get the black tape, it is for outdoor use, and has red wrapping. After inspection, pull it off, and use some 3M adhesive remover (sold at Autozone I think) for any residue.
boplaw is offline
Old 8th December 2004, 00:03   #7
Apex
Apex's Avatar
Garage: 01 M5 Silverstone/Black
I live in Tx and run without my front plate and have not been busted yet. I have had the idea of taking the front plate and Swiss cheesing the area around the numbers and letters of the plate and attaching it to the lower grill with black zip ties. I think this would still allow enough air through to the radiator?
On my Porsche I just could not figure out a good spot to attach it to the front of the car. I attached suction cups to the tag and placed it in the lower right hand corner of the windshield. This works very well unless I have a passenger in the car with me. This also works very well because the law in Tx is that the front plate must be in view from the front of the vehicle.
2001 BMW M5 Silverstone/Black Leth.*SOLD*
1983 BMW 320is White/black
1988 Porsche 951S Red/Tan 295 hp/312 tq & Cup Racing goodies from factory
Apex is offline
Old 8th December 2004, 01:12   #8
M-Fünf
M-Fünf's Avatar
Garage: 2003 M5 - Titanium Silver Metallic - Silverstone (Arrived 3/17/03)
Would it be possible to make (or have made) a braket that mounts under the front lip of the bumper that would be stiff enough to hold the front plate? (to be like 007, you could have it flip up when you need it and flip down and retract under the bumper when you don't ) Maybe using something like 1/4 turn fasteners so it could be installed quickly?
I've not had the pleasure of being stopped for a front plate violation, so I don't know what they'll look for in the mount, but I think it would suffice just to have it attached in any way to the front of the car...
M-Fünf (a.k.a. Jeff)
His: '03 M5 Ti Silver/Silverstone
Her's: '04 M3 Silver Gray/Black 6 speed
M-Fünf is offline
Old 8th December 2004, 01:28   #9
JamE55
JamE55's Avatar
Garage: Kleemann
Thanks,
Wilkie
I'm Ghetto so use double sided tape to mount my plates!
55k S8
JamE55 is offline
Old 8th December 2004, 18:59   #10
Wilkie
Thanks, I think that's what I'll try, rather than drilling holes into the face of the front bumper.
Wilkie
Wilkie is offline
Looking for M5 license plate frames C43///M5 E39 M5 and E52 Z8 Discussion 4 20th April 2002 05:03
Better front licence plate holder for M5 PaulMarin E39 M5 and E52 Z8 Discussion 13 12th March 2001 06:20
Help with front license plate Barry E39 M5 and E52 Z8 Discussion 4 24th December 2000 22:25
why some M5 doesn't have front licence plate proust0657 E39 M5 and E52 Z8 Discussion 8 20th December 2000 19:11
Front license plate mount basil E39 M5 and E52 Z8 Discussion 13 17th July 2000 05:04
Page generated in 0.17128 seconds with 11 queries
