2nd December 2004, 18:03
#1
Very happy - fixed my DSP problem!
There are two common faults with the DSP; the first is that the sound will die for no apparent reason but can be restored by simply switching the engine off and restarting after a few moments.
The second, more serious defect happened to me recently. The sound (all sources including SatNav) died and the little orange light wouldn't come on no matter how much I pushed it. The system has remained dead for a number of weeks whilst my dealer was pursuing a replacement part on back order from Germany.
Here is a pdf file of the technical service bulletin related to this problem:
http://members.roadfly.org/bmw_e46_m...ins/650804.pdf
Now for the good part...HERE IS THE FIX:
(1) Insert key but do not turn on ignition
(2) Turn on headlights (don't ask but it works!)
(3) Disconnect battery
(4) Remove fuses no. 7 and no. 41 from holder in glovebox
(5) Wait 5 minutes
(6) Reconnect battery & plug fuses back in
Voila! The DSP, radio, CD, SatNav voice etc. are all restored
Ashok
hmm.. next up.. lardy F10 M5 @ £85,000 with fake "active sound"? I don't think so
http://www.m5board.com/vbulletin/e60...kend-hell.html
The Following 10 Users Say Thank You to Ashok Arora For This Useful Post:
2nd December 2004, 18:16
#2
Re: Very happy - fixed my DSP problem!
(5) Wait 5 minutes
Sounds silly, but glad it worked out!
M-Fünf (a.k.a. Jeff)
His: '03 M5 Ti Silver/Silverstone
Her's: '04 M3 Silver Gray/Black 6 speed
2nd December 2004, 18:50
#3
01 M5 Black/caramel
(5) Wait 5 minutes
I didn't realize Lucas made components for our German cars!
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, CNS 10.5 dual mass clutch, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
The Following User Says Thank You to gsfent For This Useful Post:
2nd December 2004, 19:37
#4
E39
(5) Wait 5 minutes
I heard step 7 was to hop on your left foot 2 times with your right eye shut while spitting chewing tobacco in a Folgers can.
2nd December 2004, 20:01
#5
That's only for those without M-Audio
2nd December 2004, 20:50
#6
'01 540/6
Ah the Prince of Darkness... I hate that company. Ever seen half the dashboard lights turn off when you hit a bump? Drive a car with Lucas electronics and you sure will. One thing I just hated in my Triumph. That name makes me want to take a shower.
-Brendan
'01 540/6
3rd December 2004, 10:57
#7
M5 black
Strange,
I don't have DSP but can only presume that the lights-on, but with battery disconected somehow drained charge from somewhere that was retaining it, and using the retained change to memorise some realted fault trip.
No I haven't a clue either.
3rd December 2004, 14:55
#8
01 M5 Black/caramel
Yes, that name was just so fitting, wasn't it?
30th August 2005, 00:34
#9
WORKED FOR ME TOO!!!
Just got back from a long holiday and the Beast wouldn't crank after the layoff. Sho nuff, I inch the second car nearer, jumpered the connections and got it fired up. I forgot to do the max blower/lights etc procedure to prevent voltage spikes as per the manual. The sat nav screen died and no audio either. Another strange affliction was that the green dashboard arrows and accompanying tick-tocks indicator didn't work even thought the indicators themselves were working. I think PDC stopped functioning too.
I searched this forum and found this mdc's thread first ...
Nav and TV Problem - Battery or Jump Start Connected?
Jeez, I'm cooked.
Since the car is still under warranty, I was imagining ways to lie to the dealer "honest guv, the thing just died as I rounded the corner from my house" when I searched this forum again and found this thread we're on. Ashok's suggestion worked a treat and system back now. I even remembered to hop on one leg and yowl like a beast.
Given the other symptoms in my case, seems to me this solution can apply to a multitude of electronic glitches I've seen discussed here and not just the DSP and could qualify for a sticky.
THANKS ASHOK.
 E39 M5 2001 Velvet Blue Individual
30th August 2005, 01:45
#10
Happy to help Mike
Hope you can make it to our meet on October 2nd
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
