Timing Chain Replacement Interval - BMW M5 Forum and M6 Forums
Like Tree3Likes
Old 19th November 2004, 17:49   #1
x703jko
x703jko's Avatar
Garage: 2003 Dinan S3 M5, LeMans Blue/Caramel
What is the recommended timing chain replacement interval in the E39 M5? Is there any reason to do it more frequently?
Thanks.
Jeff
2003 M5 LeMans Blue/Caramel/Walnut
Dinan S3 Includes all Dinan S3 Mods With JRZ Sruts/Shocks, Oil Cooler, Monoball Links
StopTech 4 Wheel BBK With Red Calipers And Slotted Rotors
Axxis Ultimate Pads
M Enhanced Audio
Park Distance Sensors
Two Sets Of Dinan Lightweight Forged Wheels
Winter Tires - Michelin Pilot Sport A/S - 275/35ZR18(Y) (F); 285/35ZR18(Y) (R) (Not Sure If They'll Survive The S3)
Summer Tires - Toyo RA1s- 275/35ZR18(Y) (F); 275/35ZR18(Y) (R)
Dual, Front Mounted LE30's With Custom AIDesigns Kill Switch/LED Panel
Valentine V1 With Stealth One
UUC Short Shifter With DSSR
Oil - BMW/Castrol 5W30 Changed and tested every 3000 miles.
x703jko is offline   Reply With Quote
Old 19th November 2004, 19:08   #2
TexasM5
TexasM5's Avatar
Garage: TiSi 2000 M5
Re: Timing Chain Replacement Interval
Thanks.
Jeff
Considering the cost, I certainly hope not.
TexasM5
TexasM5 is offline   Reply With Quote
Old 19th November 2004, 22:52   #3
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
i don't think there is a replacement interval, unless the engine is remove for rebuilding. Then again, with the alusil cylinder bores, i don't think a rebuild is an option.
mottati is offline   Reply With Quote
Old 19th November 2004, 23:02   #4
x703jko
x703jko's Avatar
Thanks Mike. So one relies on the chain tensioner huh?
How about cam timing adjustment? Or is there such a thing in the E39 M5? Jeff
Old 19th November 2004, 23:41   #5
mottati
mottati's Avatar
Should be taken care of by the vanos.
mike
Old 19th November 2004, 23:46   #6
x703jko
x703jko's Avatar
mike
Thanks Mike. Jeff
Old 20th November 2004, 00:20   #7
bayerischemotor
bayerischemotor's Avatar
Garage: M5 E60 Interlagos Blue
the cam chain lasts the engines lifespan, only if it gets defected it should be replaced.
° Evolve Alpha N
° RPi ram air induction kit
° RPi ST pulley kit
° Supersprint exhaust and resonator
° Secondary cat delete
° (Evolve long tube headers coming!)
bayerischemotor is offline   Reply With Quote
Old 1st September 2012, 05:01   #8
methylamine
Garage: 2000 White e39 M5
And, apparently, that is my fate.
The engine's perfect. Just redid the rod bearings, though when I pulled them they were still perfect at 118,000 miles. Leak-down test is within 5% of factory on all cylinders. Engine's perfect mechanically...
EXCEPT--the f***ing Bank 1 VANOS won't pass the GT1 testing procedure, it reads at 70 degrees, tolerance for first test is 58-67 degrees.
Apparently, either my chain guides are too worn, or my chain has stretched.
Bavarian Machine Specialties is quoting $11,000 to replace the chain and all tensioners/guides.
What do you guys think? For a lousy 4 degrees, can I just remove a link from the chain?
Or, can I thread a new chain through, using the old chain to pull it?
Is there any other way than a brutal disassembly?
methylamine is offline   Reply With Quote
Old 1st September 2012, 05:49   #9
tradin1
Company Representative for RK Autowerks
tradin1's Avatar
Garage: 00 carbon black/heritage black
Sales Feedback: (5)
$11,000 to replace chains and tensioners? That is a really steep price, a regular repair shop that is good at what they do should be able to do it for a few thousand at most.
I did enough work a week or so ago to where doing the chains would have been an hour or two extra work.
-R
Vortech V7 YSI with a low compression forged S62.
For product and service information, please view our website!
www.RKAutowerks.com
Raza@RKAutowerks.com
tradin1 is offline   Reply With Quote
The Following 2 Users Say Thank You to tradin1 For This Useful Post:
M5 London (2nd September 2012), Quicksilv3r (2nd September 2012)
Old 1st September 2012, 06:40   #10
methylamine
Thanks Tradin1.
Yes--I thought it was steep too.
I admit it looks like a fair bit of work--lots of dissassembly/reassembly, but not a rebuild.
Does anyone know a good shop in the Houston area that's more reasonable? And, by the way, competent to do this job properly?
Introduction... And who's done guide rails for the timing chain? S38Junkie E28 M5 Discussion 0 23rd December 2003 21:31
Does the M3 E46 have timing chain or belt ? JetBoy E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 8 14th April 2002 03:31
Timing chain replacement. JetBoy E28 M5 Discussion 4 12th February 2002 15:28
Timing chain replacement 3.8 l Bruce S E34 M5 Discussion 4 11th October 2001 11:27
replacing timing chain without removing the head ? Yves E34 M5 Discussion 5 20th February 2001 16:35
