Need help, engine cutting out at 3000 rpm (ctxt) - BMW M5 Forum and M6 Forums
Old 14th November 2004, 20:15   #1
d_russian
Garage: M5 2001 Blue
Maybe somone has experienced this or knows what the problem might be. The local BMW tech cant figure it out. Has called Tech line.
I will try to be as descriptive as I can.
The car is a 2001 M5. If I take the car up to 6K RPM (not hitting the rev limiter) in third gear, upon shifting to 4th gear, there is absolutely no power when I depress the gas pedal. I can floor the gas pedal but nothing happens. It is if the engine is not putting out at all. The rpms do not drop to idle, the rpms stay up. The car decelerates. Below 3K rpm I can get very little power (perhaps 1/3 of normal) but the engine feels smooth, just very weak. As I approach 3K rpm (from 2K) in any gear the car starts "bucking" right at 3 K rpm. The sensation is not dissimilar to what one experiences as one hits the rev limiter. I pull over and turn the car off. I restart the car. The car drives fine. Pulls fine. No problem until I hit approx 6K rpm in third gear. Then the same thing happens. The engine will attempt to cut out at approx 3K rpm no matter what gear I am in. BTW, no error light or warning lights come on.
The BMW tech drives the car with me. This scenario occurs 3 out 6 times. So it is intermittent. Sometimes the car will continue to drive fine after 6K rpm in 3rd gear and sometimes not.
The tech ran a scan. The errors that came up were that 1st cylinder was misfiring and something regarding fuel pressure. So I am thinking that perhaps it is a fuel pump or somesuch but he tells me that it is not likely to be so simple. He says that the errors could be the symptoms of something else.
I dont know. I am open to suggestions. Anyone have an idea ?
Thanks in advance.
d_russian
d_russian is offline   Reply With Quote
Old 14th November 2004, 22:42   #2
Digi
Digi's Avatar
Garage: 2006 M5 Silverstone II
Re: Need help, engine cutting out at 3000 rpm (ctxt)
I'd guess there is not enough fuel, and fuel pump, or some other reason for intermittently not getting enough fuel seems likely. Like the tech says, the answer may not be easy to find. Funny that there is nothing much in the computer that helps identify the problem.
Digi is offline   Reply With Quote
Old 15th November 2004, 12:37   #3
Ahmed
Ahmed's Avatar
Garage: Black C63 AMG P31
Sales Feedback: (4)
many possibilities, however the scan should give you an idea of where the problem may lye.
have them check your MAF's sensors fitst. If that doesnt work, then probably the CAM positioning sensors ( either intake or exhaust ) maybe be faulty.
Also, you say its intermitent, have them check your throttle potentiometer.
2006 E60 M5 Sepang Bronze/Natural Brown/Olive Ash (RIP)
2013 C63 AMG P31 Magnetite Black/Classic Red & Black/Carbon Fibre
Ahmed is offline   Reply With Quote
Specifications of every BMW Der Abt Off Topic Forum 11 7th February 2011 22:35
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav Most Memorable Threads' 0 4th July 2004 21:13
515 bhp MY2001 M5 MAH E39 M5 and E52 Z8 Discussion 24 26th September 2001 16:48
Optimal Shift Points-it's at 7000 KirklandM5 E39 M5 and E52 Z8 Discussion 26 14th June 2001 00:58
Break In period Joe Lapicki E39 M5 and E52 Z8 Discussion 21 29th March 2001 20:23
