Old 8th November 2004, 00:31   #1
JohnL
Garage: 2000 M5 Carbob Black
Anyone DIY for the valve cover gaskets?
Has anyone replaced the valve cover gasket on their M5? I have some oil collected on both sides in the spark plug recessed area. Per this board, the claim is that the valve covers are leaking. As I am a DIY, I want to do this myself. I have the Bentley E39 book and on the 4.4 it seems faily easy although it doesn't really give great instructions. Looking for someone who may have done it themselves and can provide some tips. The car is still under warrantee, but I doubt that the gaskets are covered.
JohnL is offline
Old 8th November 2004, 01:15   #2
ray540inyc
ray540inyc's Avatar
Garage: 1997 540i sport , jet black
Re: Anyone DIY for the valve cover gaskets?
i think they are still under warranty. if not theres a write up on bmwtips.com for the 540's , same thing i think
ray
ray540inyc is offline
Old 8th November 2004, 03:40   #3
fc_celtic_fan
fc_celtic_fan's Avatar
Garage: 2000 M5 silver-blue
I just had my level 2 done at a local shop, they noticed the same thing, called the dealer (mine is cpo w/60K) and they said they would fix under warantee.
Taking it in on the 20th so we will see.
fc_celtic_fan is offline
Old 8th November 2004, 03:47   #4
Lscman
Garage: E39
If you still have warranty coverage, you might investigate whether your valve cover gaskets are covered. I would consult the BMW dealer AND BMWNA. The gaskets should not be failing already. Be advised that crankcase breather system malfunctions are causing gaskets to prematurely fail on some recent BMW V8 cars & SUV's. In these cases, the breather needs fixed before looking into gaskets.
My guess is the M5 gasket job is a lot different than 540i. The valve cover gasket tech tips are for older, simpler pre-Vanos cars.
Lscman is offline
Old 8th November 2004, 05:24   #5
JohnL
Thanks. Email me (jlangenf@tmo.blackberry.net) with the results. Mine is CPO also.
JohnL is offline
Old 8th November 2004, 07:43   #6
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
someone did post a diy writeup of this a while back, might be worth doing a search. then again, if you're under warranty, let them fix it... cpo does cover oil leaks, and of course the original new car warranty would too, if you're still covered. I remember that you need to get the plenum off for clearance, but after that, it's just remove and reinstall.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 9th November 2004, 08:16   #7
shadowman
shadowman's Avatar
Garage: Z8
The process to replace the VC gaskets is very straightforward. Certainly if you can have BMW pick up the tab by all means however if you find yourself having to pull the tools out I will gladly walk you through it. A small assortment of tools, a hot or cold drink, a couple hours and your gal will be fit as a fiddle.
It looks like a more difficult project than it is....... on a scale of 1-10 I would place this as a 4.......... average mechanic with basic tools will perform this task just fine.
Take care.
Shadowman
shadowman is offline
Old 10th November 2004, 04:39   #8
JohnL
Take care.
Shadowman
Shadowman,
Thanks for the offer. I've changed many VC gaskets myself, just looking to make sure that BMW hasn't done something to make this harder than it should be. I'll probably check with the dealer and if they don't cover it, I'll do it myself and probably send you an email for tips.
JohnL is offline
Shadowman's Plenum Cover completed and installed shadowman E39 M5 and E52 Z8 Discussion 72 9th April 2008 23:50
Looking for E34 M5 valve cover Philo E34 M5 Discussion 0 27th August 2004 05:06
Blown valve cover gasket..how common? TiAgM5Miami E39 M5 and E52 Z8 Discussion 2 26th April 2003 02:21
oil leak stever E39 M5 and E52 Z8 Discussion 3 8th August 2001 16:07
Valve cover gasket replaced brutus E39 M5 and E52 Z8 Discussion 0 2nd March 2001 05:23
Page generated in 0.13657 seconds with 11 queries
