Old 25th October 2004, 21:46   #1
sevenoftoine
sevenoftoine's Avatar
Garage: 2003 bmw m5 sterling grey
barely passed CA smog
Hi,
I just went to get my new '03 e39 m5 smog-checked here in Los Angeles so that I could properly register it in California. The car originally came from Colorado.
I did pass the emissions test, but in one category (HC), barely! I'm wondering if this is normal or not.
at 15mph, 1624 rpm:
%CO2: 15.2
% O2: 0.0
HC (PPM): max: 47, average: 4, measured: 47!
CO (%): max: 0.46, average: .01, measured 0.0
NO (PPM): max: 400, average: 16, measured: 0
and at 25mph, 1807 rpm:
%CO2: 15.3
%O2: 0.0
HC (PPM): max 31: average: 4, measured 31!
CO (%): max: .43, average: .01, measured: .01
NO (PPM): max: 687, average: 18, measured: 0
So, while CO and NO are seemingly stellar, the HC (hydrocarbons?) is right at the edge of passing.
Is my beast unhappy, or is this normal? Am I spewing extra crud into the air, or is this status-quo of a 400hp machine?
Thanks,
-- Antoine Durr
sevenoftoine is offline
Old 25th October 2004, 21:55   #2
speedmonkee
speedmonkee's Avatar
Garage: 03 WRX Stage 2/ 01 M5 Carbon Black
Sales Feedback: (3)
Re: barely passed CA smog
My car was also from CO via AZ. Brought it to an independent smog place - It failed initially b/c of high HC # of 54 vs max value of 47.
Brought it to the dealer to see what was up - they said the indy shops don't let the cats warm up enough. Passed with flyin colors next round.
jeremy
Powerchip 93 Reflash - gone with car
Weichars Strut Brace - SOLD
UUC SSK EVO3 - gone with car
XM direct wired with Alpine CHA-634 - SOLD
IATS - UF Motorsport - SOLD
Titanium Trim Pieces - SOLD
Tubi Style Exhaust - SOLD
AA CAI - SOLD
SSR Competition Rims - SOLD
CCFL Angel Eyes -SOLD
Valentine1 hardwired
BSW Stage 1 upgraded Speakers - SOLD
Fiamme Air Horns
Ron Davis Custom Race Radiator -SOLD
Toys -
2003 WRX - Vishnu Stage II 350hp wagon
1999 Mazda Miata with race motor 1.9L with forged everything - 320whp -powered by Hydra ECU
2008 BMW 335i Jet Black, Sport and Premium pkg with Dinan Reflash
speedmonkee is offline
Old 26th October 2004, 00:18   #3
DaveK
DaveK's Avatar
Garage: Looking for a used M5
When I bought my used '00 several months ago in CA it wouldn't pass smog because of high hydrocarbons (It's supposed to be the responsibility of the seller but he didn't realize that and reimbursed me for the testing). Several attempts were made and it was definitely warmed up enough in at least some of them. The dealership replaced the cats under warrantee and then it passed just barely (warmed up), right at the maximum. I'm still concerned that the new cats will burn up prematurely just like the old ones did because it's running too rich, but I'm not sure what to do. As long as it passes it's considered to work properly and the dealer is under no obligations to make it better. The guy at the testing center said it was normal for cars like this to just barely pass, but I don't know. At least it seems to run fine, although it would probably produce a bit more power if the mixture was just right. The SES light just came on this past weekend though, and maybe it's related. We'll see after I bring it in.
- Dave
DaveK is offline
Old 26th October 2004, 00:19   #4
Gustav
Administrator
Gustav's Avatar
Be sure top take a few 100+ mph high speeds runs before so the cats are heated up sufficiently.
Gustav is offline
Old 26th October 2004, 01:27   #5
speedmonkee
Sales Feedback: (3)
Good one Gustav. But probably some of us already do this daily - from the sounds of the postings on this board!
j
Old 26th October 2004, 02:20   #6
SandBeast
SandBeast's Avatar
Garage: Y2K M5 Sand Metallic (Custom)
Originally Posted by sevenoftoine
Hi,
at 15mph, 1624 rpm:
%CO2: 15.2
% O2: 0.0
%CO2: 15.3
%O2: 0.0
Thanks,
-- Antoine Durr
Mine failed first time into CA (HC too high also). The smog dealer said I must drive a full week, and make sure I start up every morning to warm it up. A week later the car passed with all numbers way below limit. For 2000 model, at least two monitors must be running, and if your M5 has not been active or battery was disconnected, then you'll need to drive frequently before smogging. For 2001, I think at least 3 monitors must be running.
SandBeast is offline
Old 26th October 2004, 03:57   #7
6spd
6spd's Avatar
Garage: 73 Pinto Babypuke Green
I've had problems with BMW's in the past like this.
I found if you drive hard before testing and not turning it off it does well.
I'm currently monitoring my sensors as I drive to and from work(with a data recorder hooked to the OBDII). Funny what you can see as you drive around normally.
6spd is offline
Concorso Italiano in Monterey, CA 8/13/04 + Festorics! Bob Uenaka E39 M5 and E52 Z8 Discussion 86 14th August 2004 22:19
Fouled spark plugs causing smog failure? DaveK E39 M5 and E52 Z8 Discussion 20 25th March 2004 00:32
Who knows of a friendly smog station in the South Bay? chunpng E39 M5 and E52 Z8 Discussion 8 5th December 2003 01:56
Gustav Wins Surprise Jackpot! PaulMarin E39 M5 and E52 Z8 Discussion 12 10th October 2001 14:57
Courtesy Delivery in CA? brettcoon E39 M5 and E52 Z8 Discussion 16 1st February 2001 01:27
Page generated in 0.16044 seconds with 11 queries
