• Latest threads
    • Custom feed
      • Updates
        Old 30th May 2001, 00:45   #1 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
        HID 9006 foglight bulbs for M5
        I've just received these foglight bulbs from xenonshop.com and it looks like it's the right ones.
        I've taken these quotes from a friend of mine from bimmer.org who gave me good advice about what bulbs to get and what to avoid.
        "Price. You tend to get what you pay for. Two yrs ago, most of the HID outfitters were selling kits for ~$1000. I bought my first set from www.hidlights.com. Ben, the owner, was using Osram 1st gen D2S bulbs w/Aromat ballasts. Results were awesome -- very OEM color, smooth swath of light. I'm a regular on the Philips lighting forum and about 1.5 yrs ago, Phoenix Microlight popped up. They were selling a Philips based kit (bulb and ballast) for $600. Seemed like a good deal. So I ordered a 9006 D2R kit. I was shocked. The output was green!/yellow and littered w/ hot-spots/glare. Furthermore, the base (adapter) on the bulb was a joke (soft, machined PVC/brittle cyanoacrilate). My disappointment/complaint actually led the owner (Bob) to totally redesign his 9006 base. Surprise! the second unit he sent roke inside my housing (and was yellow/green again w/tons of glare). Type/Brand. This is a *real* touchy subject. First, when retrofitting, NEVER use D2R bulbs. -- If you
        don't already know, both Osram and Philips make 2 kinds of HID bulbs: D2S and D2R. Within OEM xenon/HID housings, D2S are to be used w/projector-style housings, whereas D2R are designed for parabolic reflector/free-form headlights. The D2R bulb is striped with a dark paint to (in theory) block glare. Ignorant retrofit companies recommend D2Rs in free-form reflectors (actually, that's what you're M5 fogs are) -- 90% of the time, this results in glare and coloration. D2Rs are simply not intended for
        housings not originally made for OEM HID. Point is, stick w/D2S. Back in the day, Osram 1st gen bulbs yielded the best output/color. Unfortunately they've become very difficult to find. So, your options are
        Philips or Osram 2nd gen bulbs. From my experience, when correctly matched to the original filament placement, Philps bulbs (D2S) can yield decent colored output. Which is where the actual retrofit shop comes
        into play. I use/suggest: www.hidlights.com. They're the only company I've dealt with that doesn't lay blame on your optics if the output is green/yellow. I've used their 9006, H4 and H1 based
        bulbs and all have produced the same blue/OEM color in multiple vehicles w/ NO glare."
        It's also said that the ballast from Phillips is a good one since it's what those non-japanese manufacturers tend to use with their HID headlights.
        Jason
        '01 Lemans/Lemans - Status 160
        atomic80 is offline
        Old 30th May 2001, 21:43   #2 (permalink)
        Fernando
        Fernando's Avatar
        Did it fitted on original fog??I heard that the 9006 don't fit exatly on original,you need to modify de fog.I want to buy too for my 2000 M-5 for fog lamps but i did not buy not yet because i'm afraid that don't fit.Give me an answer??
        Regards and put some pics.
        Fernando
        2000 M-5 Jet Black/sport Black interior with aluminium
        Nowack chip ecu upgrade,K&N filer
        2001 BMW GS 1150 Motorcycle yellow
        Fernando is offline
        Old 31st May 2001, 03:05   #3 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
        Post
        Fernando,
        I've read up on this by doing a "search" on this board and the 9006 bulbs is the right one for the foglights so I don't foresee a problem fitting it.
        I don't have my car yet so I won't be able to try it out.
        Jason
        atomic80 is offline
        Old 31st May 2001, 03:26   #4 (permalink)
        Le Mans
        Post
        Fernando hwo i sthe nowack chip tun8ing you did? Do you feel any difference? What are the performance gains? How much did it cost and how as the install done. Thanks for your input i am thinking about doing the same.
        Le Mans is offline
        Old 1st June 2001, 16:29   #5 (permalink)
        Fernando
        Fernando's Avatar
        Post
        Hi LeMans.What i change was the eprom ecu from original.They read my old eprom program,than they change the program and by laptop they installed the nowack program.I payed here in Brasil 4000 Dem.The performance increase for me a lot.I gain with K&N filter 30,32 Hp.I felt de difference 0-60 mph,60-180mp/h, i went in gps 189 MPH.The car changes the torque too.It's not a big deal,but a felt difference.I heard too that Dinan,has the same program and the guys in this site approve too.I only bought from Oliver Nowack because he has a friend here who has the telemetry and the computer to change and read my software.For all regards and more question write me fernando@rosset.com.br
        Regrads
        Fernando is offline
        Forum Jump
        HID Stage II 6000K bulbs (a pair) for sale m5monster For Sale or Wanted 1 18th November 2002 22:47
        Installed 6000K HID bulbs and 4150k H3 Fogs Oak Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 2 3rd April 2002 18:29
        Foglight Conversion--Use of Old Zenon bulbs steveB E39 M5 and E52 Z8 Discussion 1 9th March 2002 20:15
        PIAA foglight bulbs upgrade Stallion M5 For Sale or Wanted 0 5th August 2001 07:54
        For sale: HID 9006 phillips headlight bulbs atomic80 For Sale or Wanted 1 19th June 2001 01:46
        Page generated in 0.22888 seconds with 11 queries
