Old 14th October 2004, 05:05   #1
DDB540
DDB540's Avatar
Garage: 1998 540i 6-speed Jet Black/Black
Send a message via AIM to DDB540
Need help re-installing control arm:
Well, I've replaced the front two traction struts (with bushing) and one of the two control arms, but the second control arm (passenger side) is giving me a problem. When I insert the ball joint of the new control arm up through the wheel assembly and begin to turn the nut with my 22mm wrench, the entire ball joint is turning with the nut, so the nut isn't screwing on. When this happened with the other arms, I placed my floor jack underneath the arm and pushed it up, and the joint would no longer turn. Not with this final one, though; it keeps turning no matter what I try.
Any suggestions?? I'm frustrated to be 90% done with this project and then get stuck on something like this.
This is on an E39 540i, but the ball joint issue should be consistent with an M5.
Thanks!
DDB
Click here to see my car.
DDB540 is offline
Old 14th October 2004, 16:20   #2
DDB540
DDB540's Avatar
Nevermind, I figured it out.
The ball joint bolt that goes up through the hub assembly has a hexagonal whole on top that could be used for support with an allen wrench while turning the nut. Much easier than I thought.
DDB540 is offline
Old 14th October 2004, 17:12   #3
DZeckhausen
DZeckhausen's Avatar
Garage: 2001 540i 6-Speed, Alpine White
Send a message via AIM to DZeckhausen
Re: Nevermind, I figured it out.
You beat me to it! Congratulations. I trust the rest of the installation will go smoothly.
How many miles on your car? Were you replacing the traction strut and wishbone because the bushings were shot or becuase you had free play in your ball joints? Or both?
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion
CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8 w/StopTech ST-60 front/ST-40 rear BBK
2007 Corvette Z51 Coupe 6-Speed w/StopTech Trophy ST-60 front/ST-40 rear
2009 Honda Fit Sport w/NAV w/Acura Integra front calipers, StopTech floating rotors on order
DZeckhausen is offline
Old 14th October 2004, 17:18   #4
DDB540
DDB540's Avatar
Thanks, Dave. I'll finish things up tonight.
My car has about 78K miles. Each traction strut had a small amount of back and forth play, which I attributed to worn out bushings. The control arms seemed fine, but since I was renting the 'special tool' anyway, and the control arms are fairly inexpensive, I decided to do it all at once.
~ DDB
DDB540 is offline
Old 14th October 2004, 17:23   #5
DZeckhausen
It's surprising to me that such expensive looking aluminum suspension pieces are priced as low as they are. When I first looked at the traction strut and realized it was a "consumable" item, I said "uh, oh!" Then I got a Pacific BMW price quote (which I can no longer remember) and the price was about 1/3 what I thought it would be.
Dave Zeckhausen
2001 540i 6-Speed
M5 Front Swaybar
Old 14th October 2004, 17:30   #6
DDB540
DDB540's Avatar
I was also surprised. I got all four pieces (2 control arms, 2 traction struts) with nuts and bolts from Pacific BMW for around $500.
~ DDB
DDB540 is offline
M5 rear lower control arm more stout than 540i's basil E39 M5 and E52 Z8 Discussion 0 11th September 2003 07:18
Control Arm or Pull Arm? Kodiak E28 M5 Discussion 0 6th August 2002 21:08
Page generated in 0.15665 seconds with 11 queries
