Old 14th October 2004, 05:03   #1
cvp911t
cvp911t's Avatar
Garage: 00 E39 M5 silv/blk
Send a message via AIM to cvp911t
Well, we're in limp mode and..(for the techies)
symptoms:
-Earlier, the car would hesitate when motor was cold (and got better when warmed up)
-Very rough idle (the car literall shakes)
-Now, loss of power throughout the powerband, at all speeds, at any engine temp
Had a buddy Pull the following codes:
Table 18:
B8 - intake camshaft vanos position control (cyl 1-4)
And basically misfire codes on cyl 1-4, and cyl 8. Also got air fuel adapation (error AF) for cyl 5-8 - which we suspect is a cascade effect on the main error B8.
So....I'm thinking if this is the camshaft position sensor? Any of you gotten this error before? Thanks in advance for any help.
Lance
00 E39 M5, bone stock (for now)
cvp911t is offline
Old 14th October 2004, 05:26   #2
stanm5
stanm5's Avatar
Garage: 2000 e39 M5 avus blue/two tone grey
Re: Well, we're in limp mode and..(for the techies)
Originally Posted by cvp911t
symptoms:
Table 18:
Lance
It's most likely the Cam Position Sensor and possibly your MAF's.
Bring it to the dealer and have them pull the stored codes.
Good luck.
Cheers,
Stan
996 Cab
stanm5 is offline
Old 14th October 2004, 07:29   #3
BlueBomber
BlueBomber's Avatar
Garage: LeMans Blue
Send a message via ICQ to BlueBomber Send a message via AIM to BlueBomber
Good luck.
Cheers,
As stanm5 has stated, it's probably a combination of the intake CPS and MAFS. I would start with swapping out the intake CPS. Once that's done, you'll likely notice a significant change in performance.
Since you have a 2000 M5, you'll probably have the older version of the MAFS which seem to fail earlier than normal. Thus, you'll have to end up swapping them out as well.
Johnny
06/2000 Lemans Blue
BlueBomber is offline
Old 14th October 2004, 10:42   #4
Ahmed
Ahmed's Avatar
Garage: Ex- E39 M5
had the same problems as you, replaced my intake can sensor, and new set of MAF's... the car runs great!
2006 Sepang Bronze/Naturelle Brown E60 M5
Eisenmann Sport Mufflers
Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi RAM Scoops + Block Off Plates + BMC Filters
AL-Tuning Software
Eibach ProKit Springs
20" Breyton Race CS with Yokos
White Angel Eyes, 6000K HID's & LED Plate Lamps
ACS Roof Spoiler
Ahmed is offline
Old 14th October 2004, 21:43   #5
ilundber
ilundber's Avatar
Garage: 1991 M5 Lagunengrunmetallic and 2001 M5 Le Mans Blue
I have just had the same problem.
First time it was the magnetic valve for the vanos. An o-ring was busted. You can see if that is the case by checking if your air filters are being filled with oil coming from the plenum. The problem does not show up on the test but there is a servcie bulletine for it.
After that was fixed, a camshaft sensor stopped working (two weeks after and fixed today). The problem symptoms resemble the one with the magnetic valve, but is much less obvious.
So, check for oil in the air filters. If they are clean check the MAFs. If they are clean (I washed mine but got no effect) I'd say you have a camshaft sensor problem.
ilundber is offline
Old 14th October 2004, 23:58   #6
alibo70
alibo70's Avatar
Garage: '00 Avus Blue
Mine pulls the exact same codes. Putting new MAFS in this weekend.
alibo70 is offline
Old 15th October 2004, 00:06   #7
cvp911t
cvp911t's Avatar
That's a new one - so your MAFS caused the cam position sensor error too? Thanks for all the replies...
cvp911t is offline
Old 15th October 2004, 01:05   #8
alibo70
alibo70's Avatar
Its possible, but i'm leaning toward the MAFS. Earlier posts on the forum suggest that when Cam Sensor goes out the car just runs down right terrible. I really hope that of the two one of them is our problem. I can honestly say so far Beast ownership has been a nightmare. I mean MAFS are not exactly cheap. Just wondering does anybody know specifically what was updated on them after 2000.
alibo70 is offline
Old 15th October 2004, 01:07   #9
alibo70
alibo70's Avatar
Oh yeah just remembered, cleaning them had no effect on them. Have tried it twice. But I guess it doesn't hurt. I like what somebody posted earlier "a group buy on them"
alibo70 is offline
Old 15th October 2004, 01:27   #10
LSU1981
LSU1981's Avatar
Garage: 2000 M5 Avus Blue
Send a message via AIM to LSU1981
Try disconnecting the MAFs, then start the car. If the rough running goes away then 1 or both of the MAFs are bad. Reconnect one at a time to determine the bad side.
This will throw some more codes but ....
And it doesn't hurt the car, it goes to a default setting for A/F ratios, etc. --- just don't run it hard.
I don't have knowledge of MAF changes other than the change from 6pt torx security screws to a 5pt in 2003.
2000 M5 Avus Blue / LeMans Sport. (sold to MPRESIV, 9/04)
2002 M3 Carbon Black/black
2004 Sierra Denali
2008 335xi - on order
Gone - Shelby Cobra Roadster, 01 Carrera C2 Coupe, 00 M5
LSU1981 is offline
Page generated in 0.15606 seconds with 10 queries
