Old 12th October 2004, 23:57   #1
vics
vics's Avatar
Garage: 99 HayaBusa & BMW K1200RS
Whining sound?
Gang; when car's cold, a whining sound ocurrs for approx 45 seconds & goes away. Tell me this is normal....
00 M5 (8/1/00); 130K, Anthracite/black/fold-down rears/Dinan exhaust/Dinan Stage II software/cold air intake.
99 Copper HayaBusa; 19K, (unrestricted, 196 mph )
98 BMW K1200RS; 110K, The Ultimate BMW K1200/ K1300 Portal
vics is offline
Old 13th October 2004, 00:13   #2
DZeckhausen
DZeckhausen's Avatar
Garage: 2001 540i 6-Speed, Alpine White
Send a message via AIM to DZeckhausen
Re: Whining sound?
Hey! I've got that same whining sound. It goes like this: "Honey, these leather seats are so darned cold!" Then after about 45 seconds, the seat heaters kick in and the whining stops.
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion
CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8 w/StopTech ST-60 front/ST-40 rear BBK
2007 Corvette Z51 Coupe 6-Speed w/StopTech Trophy ST-60 front/ST-40 rear
2009 Honda Fit Sport w/NAV w/Acura Integra front calipers, StopTech floating rotors on order
DZeckhausen is offline
Old 13th October 2004, 00:15   #3
DrewKeen
DrewKeen's Avatar
Garage: Imola M5, Black SVT Cobra, Orange Pinto
Send a message via AIM to DrewKeen
Re: Whining sound?
hah, I don't have the same problem you do Dave, luckily.
Does it only whine when the engine is cold or does it do it all the time?
Imola Red; Black/Silver Sport
DrewKeen is offline
Old 13th October 2004, 00:35   #4
EdP
EdP's Avatar
Garage: 2001 M5 (LMB)
Re: Whining sound?
I get a slight chirp on start-up, which I assume is the belt, but no whining as a cold-start symptom. I do hear a feint whining sound that definitely is steering related. I hear it during slow manuevers (parking, pulling into the garage, etc.), especially when in sport mode. I'm assuming this is normal too (?) Doesn't sound like what you're describing, as it's not temp related.
'07 335i
'01 M5 ~ retired
'90 M3 ~ D-Mod race car
EdP is offline
Old 13th October 2004, 01:15   #5
tetherM5
tetherM5's Avatar
Garage: 2000 Carbon Black M5
Re: Whining sound?
It is normal, that is your smog pump operating. I would compare it to the sound a handheld black and decker running. Sort of a whinning, whirring type sound.
tetherM5 is offline
Old 13th October 2004, 03:19   #6
vics
vics's Avatar
Re: Whining sound?
Sounds like it my friend - why only when cold & for short duration?
Not a power steering sound; more like a turbo whine for 45 seconds - that's what I tell my neighbors anyways ....
vics is offline
Old 13th October 2004, 03:57   #7
tetherM5
tetherM5's Avatar
Re: Whining sound?
The smog pump is designed to introduce compressed air into the exhaust headers to provide additional oxygen for the combustion of CO and HC's during the initial "super" cold environment directly after a cold start (a real cold start when the car has been sitting for 6+ hours.) This is the time when the mixture is significantly rich and the low temperature of the combustion chamber results in a very raw exhaust release. After the 30 seconds or so, the cylinders are able to provide effective and complete burning of the mixture.fficeffice" />
tetherM5 is offline
Old 13th October 2004, 04:10   #8
XrayMD
XrayMD's Avatar
Garage: LeMans Blue M5,Silver X5 & Dk. Silver Mini S
Re: Whining sound?
Correct info on the pump. Also, of interest is that BMW says that this is "normal". WHat I would like to know is if it is normal, how come it didnt start making that noise for me until very recently. I've had the car for 2 years now and it never made the whine on cold start in winter.
BMW says the same thing about the whining noise from some of the power steering units which is load in "sport" mode and mostly heard when slow turning (like into a driveway). If it's normal, why do some cars NOT make that noise?
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline
Old 14th October 2004, 02:13   #9
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Re: Whining sound?
I believe BMW calls it the auxiliary air pump. It is for smog as others have said. I had one replaced under warranty. The new one is barely audible, although it can be heard. Seems a volume adjustment on the radio should solve the problem!!
gsfent is offline
Old 14th October 2004, 16:17   #10
SouthshoreM6
SouthshoreM6's Avatar
Garage: 2007 M6 Silver gray
Re: Whining sound?
I had mine replaced at 42K miles under warranty - it was called the secondary air pump by my dealer, preheats the cats? I can just hear the new one, the old one sounded like a jet engine at start up!
07 M6 - 6 speed manual, Silver gray Metallic, Merino Black full leather, Black Carbon Fiber, comfort access, heads-up display, Sirius sat radio, RPI Scoops, Charcoal Filters removed, drop-in BMC Air filters, hardwired V1, 50% tint, RPI Block off plates, M-Sprint Booster, Umnitza ICE angel eyes
97 Cobra Convertible, lots of mods, summer car
03 Audi RS 6 Avus Silver, Milltek exhaust, etc.....SOLD
01 E39 M5 Silverstone/black..many mods!.....SOLD
SouthshoreM6 is offline
E60 M5 Engine Sound rsteele E60 M5 and E61 M5 Touring Discussion 15 4th June 2004 16:25
Strange metallic sound... Fedde E39 M5 and E52 Z8 Discussion 10 4th September 2002 18:56
More engine sound at idle please Tom E39 M5 and E52 Z8 Discussion 11 22nd June 2000 06:02
Z8 sound Viken Bedrossian E39 M5 and E52 Z8 Discussion 1 5th April 2000 01:00
Page generated in 0.17521 seconds with 11 queries
