Old 12th October 2004, 21:02   #1
lsdvm
lsdvm's Avatar
Garage: 2001 M5, silver/imola red extended leather
9 quarts of oil??? Is this right??
Hey all, just got the inspection 1 done at the local dealership, and while reviewing the bill (with a magnifying glass) I realized that I was charged for 9, yes 9 quarts of 5W30 oil. Is this even possible???
I believe the manual calls for 6.9 quarts for the beast, and I know someone else here had a similar issue when they went to a dealership recently.
Any comments, or suggestions?? More importantly, will this hurt my baby??
Thanks all.
PS- Those of you who mentioned the exhaust cam sensor as the culprit for the SES light were right on the money! Ahh, the collective wisdom of this forum never ceases to amaze me!!! Cheers!!!
lsdvm is offline
Old 12th October 2004, 21:07   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Re: 9 quarts of oil??? Is this right??
There seems to be some variability for oil capacity. The manual does say 6.5L or 6.9q. On my car (6/00prod) when I change my own oil, i let the car drain for quite a while, it trickles for 30 min or so. When I refill i need 7.5L to get to the full mark. I use 10/60 hence my capacity reference is metric. Additionally, when i put my used oil in my collection containers, i come really close to filling 2 gallon jugs, so i'm pretty confident i have almost 8q of oil coming out. Not sure about the 9th in your case though.... i have been billed for 8 at the dealership.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 12th October 2004, 21:41   #3
marinakorp
Garage: 99 540iT Grey
I believe that it takes 8+- quarts of oil...
check the dipstick... if overfilled.. significantly... then you might want to question why they put too much in there.
people on the track, sometimes add 1/2 qt or more , to alleviate some of the starvation that can happen to some, etc.
on my 540, it takes 8 qts oil.. and can take a little more if you put some in the oil filter canister... about 1/2 qt or so
99 540iT
Powerchip Gold 93
M5 Rear Swaybars
Shadow Badging / Grill
marinakorp is offline
Old 12th October 2004, 22:48   #4
Suretyagent
Suretyagent's Avatar
Garage: 2001 M5 Carbon Black
Ah, Grasshopper, as wisdom was passed on to us and we passed wisdom on to you, so must you pass this wisdom on to others.
Derek
Suretyagent is offline
Old 12th October 2004, 23:23   #5
boostmiser
boostmiser's Avatar
Garage: 2002 Alpine White M5
Why? Don't we alrady have a pseudo 'druy sump' in the car which alleviates starvation issues?
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
boostmiser is offline
Old 13th October 2004, 01:02   #6
mottati
mottati's Avatar
Yeah, i think you're right, i've not heard of any M5 people doing the 'overfill' deal. It is common with the e36 m3's though.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 13th October 2004, 01:55   #7
Need4Spd
Need4Spd's Avatar
I recall reading somewhere that overfilling an M5 engine is BAD for it, so check to see it's not overfilled. This is true even for track use. There are sensors in the oiling system that close down certain baffles in high g turns so that the pump stays wet, which is the only point of the overfilling that is commonplace with e36 engines used on the track (it doesn't have the same oiling system).
Need4Spd
Need4Spd is offline
Old 13th October 2004, 02:08   #8
TCM
TCM's Avatar
The M5 takes 6.9 quarts of oil (7.5 max). I would definately check to make sure oyu do not have too much oil in the engine as it can cause problems. Please keep us updated.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 22:23
my dealer "gave" me 2 quarts of oil Jacob Lee E39 M5 and E52 Z8 Discussion 5 7th April 2001 22:09
Page generated in 0.14564 seconds with 11 queries
