Old 12th October 2004, 15:23   #1
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
AA improved air intake
I have been running the Active Autowerkes Cold Air Intake since last summer. I have had the front bumper off several times for other installs (electric engine fan, remote air temp sensor, etc...). Each time I had access to the air tubes, I would try to seal up air leaks to create a 'ram' air path. Well just the other day I noticed the plastic air tubes were not aligned and were actualy restricting the flow. Without removing the bumper or the front wheels, I was able to remove the black plastic air tubes and the aluminum air box that the flex air hose connected to. I found that I could twist the air hose and connect the hose right to the aluminum fitting in the plastic mesh. After tightening the clamp, I found that if I just folded over the portion of the aluminum air box that extended in front of the box opening, I could mount it up and still have mounting points for the air pan. Now I have a direct air path to the air filter boxes. I an not concerned about rain getting in as there are drain holes in the filter box and it would be dificult for water to travel that far up. I will check this the next time I am out on a rainy day. As to the butt-o-meter I have to say I really do feel a big difference. I think this complements the other mods.
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Old 12th October 2004, 15:31   #2
SC'dKellenersM5
SC'dKellenersM5's Avatar
Garage: Red White and Blue
Re: AA improved air intake
interesting....
Im in the highspeed aluminum business
SC'dKellenersM5 is offline
Old 12th October 2004, 16:01   #3
Tin
Tin's Avatar
Garage: M5 - Avus Blue
hmm.... quite a good idea, except that you've taken away cooling away from the brakes.. unless you feeding another pipe towards the inner grill area..
Kelleners ECU remap, Kelleners uprated Sport Camshafts, Kelleners Custom 3.45 Rear Diff, ACS DFC Suspension, 19" ACS TypeIII's, Brembo GT Kit (F:8pot/380mm front,R:4pot/345mm), Supersprint RHD headers,100cel sport cats,x-pipe and 90mm backboxes, ACS Rear Diffuser, Evosport lightweight pullies, Dinan Front & Rear Strut Bars, Dinan Rear SwayBar,ACS pedals & handbrake, GruppeM induction kit, AA CAI,IgnitionSolution PlasmaCoils, Rouge SSK with weighted rod, BeastPower brackets, NAV-Tv, MKIV Widescreen retrofit,2x10" M-Audio Subs, Hardwired V1,Xenon interior lights
Tin is offline
Old 12th October 2004, 16:27   #4
mr_bock
mr_bock's Avatar
My inner plastic fender well does not have the holes for the air and I did not want to cut them as I feel the air would only hit the back of the dust shield. Unless you have ducted dust shields that put the air where it is needed. These could be piped to an area around the fog lights. I also felt that the AA air path did not put enough air to the intake filters. With so many gaps and leakage areas, the air flow would always take the path of least resistance, i.e. right out the brake duct. Now the air cloumn to the air filter box is always packed at speed. I don't know if I will dyno this as I would have to find a way to simulate air flow at speed (a leaf blower?). Right now all I know is that it feel great.
UUC Clutch Stop
NAV MKIV DVD
mr_bock is offline
Old 12th October 2004, 18:00   #5
MAH
MAH's Avatar
Garage: 2001 Imola Red
I have the same setup, but I do have the ducting to the brakes as well. I never saw the issues you mentioned with regards to air leaks. Of course I have not removed the front bumper lately. Did these leaks occur over time?
I have had the AA CAI for the better part of two years and there is no way to realize the posative impact from this modification on a dyno no matter how much air you try and force into those intakes. I suppose it is in theory, possible to simulate the ram air effect, but no one has been able to.
Mark
BTW - I like the AA CAI. I would do it again.
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
MAH is offline
Old 12th October 2004, 18:14   #6
mr_bock
mr_bock's Avatar
The air leaks are the gaps and lose fitting between the plastic tubes (AA CAI) that just sit behind the aluminum inlets in the grill. I tried using Heating/Air conditioning aluminum tape to close off and seal the openings. This is hard to do because of the way these fit together along with the bumper. Anyway, running the hose direct solves all of this. I do have to remember to release the hoses when the bumper has to come off. Any excess air pressure being forced into the inlets from forward motion of the car has only a couple of small vent holes in the air box.
UUC Clutch Stop
NAV MKIV DVD
mr_bock is offline
Old 12th October 2004, 18:22   #7
MAH
MAH's Avatar
I am still confused. Did the openings in the hoses occur because of a faulty install or are the hoses too short to fit properly against the fittings?
Can you see these problems by looking in the wheel wells with the wheels turned all the way to one side? If not, how did you discover the problem?
Thanks,
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
361RWHP
425HP and growing!
MAH is offline
Old 12th October 2004, 18:39   #8
cali6869
Banned
cali6869's Avatar
Garage: 323ci
I did something similar on my car last week. I installed the sink drains in my front lower grille, then I connected the the sink drains to some hose.... the other end of the hose goes to the airboxes. Now, what is different on my kit? what I noticed is that those pipes (the snorkel tubes from airbox to the front bumper) had good fitting, so I decided to cut them and then connect my hose to it....
all I can say its that my car feels way better, car feels more powerful and not restricted.
then last week I also installed GruppeM intakes, and boy the car feels powerfull, I will dyno the car soon just to see if there are any gains.
cali6869 is offline
Old 12th October 2004, 20:06   #9
mr_bock
mr_bock's Avatar
Thanks,
Mark
The gaps I am talking about have nothing to do with the hoses (no damaged parts). It is because there is no air tight seal between the black molded plastic tube that sits just behind the grill duct. Then there is no seal where the same plastic tube sits inside the aluminum air box. If the brake duct opening is not sealed there, the air will just rush through and out and not exactly into the hose up to the air filter box. I tried to tape all of these different sections together but it is too much hanging out while trying to get the bumper back on. Ram air intake is just that, ram it in, no leaks except that that goes into the engine when the valves open. The faster you go, the more air pressure at the valve ready to go in.
UUC Clutch Stop
NAV MKIV DVD
mr_bock is offline
Old 12th October 2004, 20:26   #10
FAST 5
FAST 5's Avatar
Mr. Bock...........
We would all be grateful if you were to post PICS of what exactly you are describing, since this will answer many questions that can't be described in words. PICS PLEASE!
FAST 5 is offline
Days 3 and 4 - Final Heat Tests, Conclusions and Recommendations greg E39 M5 and E52 Z8 Discussion 51 28th June 2007 23:06
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 10:23
I NEED SOME HELP WITH AIR INTAKE SYSTEM Thunderbird E39 M5 and E52 Z8 Discussion 6 15th May 2004 00:42
8 Brandnew Candle holders for the S62! Take a look! TriflowM5+M3 E39 M5 and E52 Z8 Discussion 56 26th October 2003 20:41
Questions about the stock air intake box/setup........... FAST 5 E39 M5 and E52 Z8 Discussion 9 16th May 2003 15:22
Page generated in 0.19283 seconds with 11 queries
