Old 12th October 2004, 04:57   #1
Redshift
Redshift's Avatar
Garage: 01 M5 / 02 330Cic / 03 540iT / 94 M3
Sales Feedback: (11)
BMW Accessories Roof Rack - anyone have it? Pictures, installation, etc.?
Hi all
I'm considering purchasing BMW's "large" roof rack for my M5. Does anyone have it? I assume it's a pretty easy installation on the existing mounting points on the roof? How hard is it to get on there? How heavy is the rack? Let's see some pictures and hear personal feedback if you have any.
Thank you
Brian - CCA #273611
Tarheel BMW CCA Street Survival Chief Instructor
03 540iT Sapphire Black - 01 M5 LeMans Blue - 02 330Cic Orient Blue - 94 M3 w/S50B32 Imola Red 08 F800ST Blue
*** Parting out entire 03 CB/Imola/Black M5 *** - TONS OF PARTS AVAILABLE
Redshift is offline
Old 12th October 2004, 05:28   #2
Lscman
Garage: E39
Re: BMW Accessories Roof Rack - anyone have it? Pictures, installation, etc.?
I have the "Thule rack for BMW 5er". It fits nicely & screws to factory roof rack mounting bosses. It does not touch the roof panel...only contact is inside the car's rack mounting recess. I can't imagine the OEM rack working, looking or fitting much better.
I think this rack fits more than one BMW, but the BMW-brand unit probably does too. The BMW roof mounting system is fairly standard across their product line. I think only the width varies, so the crossbar on my rack can be set to fit E46 or E39 etc. The crossbar does look a little long, so it may fit 7er. This extra couple inches of width might come in handy if you're putting lots of kayak's and/or bikes on the roof. It won't help for attaching a cargo box, since they are generally 38" wide or less.
Lscman is offline
Old 12th October 2004, 06:01   #3
Redshift
Redshift's Avatar
Thank you. My plan was to, er, carry some wheels and tires up there for now If anyone has experience with the factory unit, please let me know.
Lscman, where did you get the Thule and how much did it cost?
Brian - CCA #273611
Redshift is offline
Old 12th October 2004, 19:01   #4
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
I also have the Thule rack, just had it on this past weekend with the kids bikes, i took some pics of it and the mounting. I'll try to post tonight.
My buddy at the dealer parts dept told me to not bother with the factory bmw rack back when i had my e46, he referred me to the thule dealer, said the parts are the same, and more flexible. He was right, as that same rack also works on the e39.
I'm planning on getting the "large basket attatchment" to carry track tires too, i've know of a guy with an M coupe who does this with the thule rack.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 12th October 2004, 19:04   #5
Redshift
Redshift's Avatar
If anyone has the proper part numbers for the rack itself and the basket, I'd love to have those! I need to get everything here by Friday.
Brian - CCA #273611
Redshift is offline
Old 12th October 2004, 19:18   #6
Lscman
Garage: E39
Thule has a very extensive factory web site with pics and literature. I recall visiting it, so try a search.
Lscman is offline
Old 12th October 2004, 19:19   #7
Redshift
Redshift's Avatar
Did that last night and found only a generic BMW rack system. Do you happen to know what the weight limit of the system is, also? Unless I can fit four wheels and tires up there, or at least 2-3, it will be useless.
Brian - CCA #273611
Redshift is offline
Old 12th October 2004, 19:45   #8
Lscman
Garage: E39
Is this 753-BMW rack what you're referring to:
http://www.thuleracks.com/thule/inst...274_02,753.pdf
This rack only fits E39 and E46, so it isn't exactly a universal or generic rack. Sounds like Motatti has this same E39/46 rack.
I think most auto roof gutter racks are rated for 150 lbs or less. Even a heavy factory OEM Grand Caravan roof rack that hauls a 25 cu ft cargo box is rated less than that. One tire & wheel weighs about 50#, so it'll be a bit overdutied.
Some folks carry four tires on the roof.....especially those in little sports cars. I transport race tires in the trunk and rear seat area in 36gal garbage bags....although my car does have a trunk well that holds one tire & another tire will fit in the trunk above it. I have not tried to fit three tires in the rear seat, as may be necessary in an M5. The seatbelts restrain 2 tires nicely.
Good luck either way.
Lscman is offline
Old 12th October 2004, 19:50   #9
Redshift
Redshift's Avatar
Yes, the 753 is the one. I saw it referred to as a BMW generic (or something like that) rack on their site, and looked at the installation PDF and it didn't seem to note application.
Thanks.
I usually use the back seats folded down, but I'm driving to DC first, with my wife and dog and luggage, and need to carry all four track tires and wheels plus the OEM fronts that I'm selling to a guy up there. Hard to get everything in one car, even with the roof rack
Brian - CCA #273611
Redshift is offline
Old 12th October 2004, 20:29   #10
mottati
mottati's Avatar
IIRC, the roof limit is 200kg, so maybe 3 wheels/tires on the roof is ok. In my M5, in the past, i'd throw one wheel in the trunk, one on the back seat floor (with the pass seat fully forward) and the other 2 on the seat itself (all in trash bags, of course!).
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
BMW Alpina now launched in Kuwait, Quatar, Bahrain, Saudi Arabia and Oman! Gustav ALPINABoard.com | BMW Alpina Discussion 0 14th September 2004 00:31
Big News: Official M5 E60 pics! Anymore coming with us to Geneva? Gustav E39 M5 and E52 Z8 Discussion 55 3rd March 2004 15:24
Ralf caught for speeding! (Again) Dirim Off Topic Forum 10 11th December 2002 00:48
Be EXTREMELY careful before taking delivery of your BMW: My experience abang E39 M5 and E52 Z8 Discussion 9 10th August 2000 08:23
Page generated in 0.15264 seconds with 12 queries
