• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 9th October 2004, 22:04   #1 (permalink)
          Hobbez
          Hobbez's Avatar
          Send a message via AIM to Hobbez
          Can anyone loan me/obtain for me a 5-point Torx T20 "tamper proof" bit?
          Id like to clean out my MAFS when I replace my air filters (car seems a bit sluggish lately) and I'm having a very hard time finding the 5 point/tamper proof Torx T20 bit. Evidently they don't sell them to the general public.
          If anyone can get me one (so I can buy it from you) or let me borrow one, I'd appreciate it greatly. I'd be more than happy to pay for shipping and your troubles.
          Drop me an email at sanford.scheppele@gmail.com or send me a PM here. Thanks!
          Hobbez is offline
          Old 9th October 2004, 22:27   #2 (permalink)
          x703jko
          x703jko's Avatar
          Re: Can anyone loan me/obtain for me a 5-point Torx T20 "tamper proof" bit?
          Wiha makes all kinds of fastener bits. They sell security torx bits. Check them out.
          Jeff
          2003 M5 LeMans Blue/Caramel/Walnut
          Dinan S3 Includes all Dinan S3 Mods With JRZ Sruts/Shocks, Oil Cooler, Monoball Links
          StopTech 4 Wheel BBK With Red Calipers And Slotted Rotors
          Axxis Ultimate Pads
          M Enhanced Audio
          Park Distance Sensors
          Two Sets Of Dinan Lightweight Forged Wheels
          Winter Tires - Michelin Pilot Sport A/S - 275/35ZR18(Y) (F); 285/35ZR18(Y) (R) (Not Sure If They'll Survive The S3)
          Summer Tires - Toyo RA1s- 275/35ZR18(Y) (F); 275/35ZR18(Y) (R)
          Dual, Front Mounted LE30's With Custom AIDesigns Kill Switch/LED Panel
          Valentine V1 With Stealth One
          UUC Short Shifter With DSSR
          Oil - BMW/Castrol 5W30 Changed and tested every 3000 miles.
          x703jko is offline
          Old 9th October 2004, 23:25   #3 (permalink)
          ard
          ard's Avatar
          Wiha is a source. Unfortunately they will not sell that bit. You must be a certified purchaser of those fasteners - they will actually check and make sure that you are a company and you actually buy those fasteners.
          Anyway, that was last time I checked.
          Decided not to screw with them (pun intended) and dremeled the head off and replaced the screws. (THis was NOT on an M...)
          ard
          ard is offline
          Old 10th October 2004, 02:08   #4 (permalink)
          01M5
          01M5's Avatar
          $10 bux at sears
          http://www.sears.com/sr/javasr/produ...id=00925702000
          Craftsman 6 pc. Bit Set, Torx® Security
          Sears item #00925702000 Mfr. model #25702
          01M5 is offline
          Old 10th October 2004, 02:50   #5 (permalink)
          ard
          ard's Avatar
          Are we talking a six point torx security bit- or a 5 point torx security bit? Both have a hole in the middle (such that the raised center point in the fastener goes into the hole in the end?)
          The latter is the one I was referring to as a security bit...
          http://www.wihatools.com/716_IPR_serie.htm
          ard
          PS There's some confusion over 5 vs 6 points.
          ard is offline
          Old 10th October 2004, 05:44   #6 (permalink)
          XrayMD
          XrayMD's Avatar
          You can find Torx security bits and/or drivers at Home Depot or Lowes
          Steve
          '02 M5 LeMans Blue:
          Supersprint Headers and cats
          Dinan Stage III suspension
          BeastPower sway bar brackets
          Dinan front strut tower brace
          RMS short shifter
          Llumar window tint (35%)
          XrayMD is offline
          Old 10th October 2004, 05:51   #7 (permalink)
          Hobbez
          Hobbez's Avatar
          It's the crazy 5-point one.
          I actually bought the ones from Sears, but they are the 6 point security bits. The 5 point one is the special one.
          Hobbez is offline
          Old 10th October 2004, 05:51   #8 (permalink)
          ard
          ard's Avatar
          5 point or 6?
          Near as I know, there are several varieties for torx:
          5 point
          6 point
          5 point security
          6 point security
          3 of these are freely available.
          ard
          ard is offline
          Old 10th October 2004, 06:08   #9 (permalink)
          BM5W
          Send a message via AIM to BM5W
          Can you drill a small hole in the tip of a 5-point Torx bit?
          BM5W is offline
          Old 12th October 2004, 03:32   #10 (permalink)
          Lscman
          I can't. Torx bits are generally harder than a drill bit. The 5 point with a hole is likely more common than a 5 point with no hole. Obviously a security bit with a hole in the middle works on either application.
          Lscman is offline
          Old 12th October 2004, 04:07   #11 (permalink)
