Old 8th October 2004, 08:13   #1
Tom Burns
Tom Burns's Avatar
Garage: 2003 M5 Jet Black
Easy Camera Mount
Just made a nifty camera mount for my 03 M5 that cost about 1/4 of anything I saw on the web.
Get a cheapo tripod with a standard camera/video mount at any camera shop. Just make sure the piece that the mount connects to and moves up and down in the tripod is at least 16-18" long. All mounts will let you adjust pan/tilt/level.
Remove this piece from the tripod and take it to your car. Lay it in the desired position between the seat and headrest and mark where the 2 headrest bars meet the piece.
Go to Home Depot and buy a piece of metal (could also be wood), and a couple of fasteners which you can tighten down (basically just a couple of bolts with a wingnut fastener, or a nut and bolt with a knob, etc. Just look around for whatever looks good.
Drill holes so that the bolts can go though the metal piece and into the tripod piece on either side of the headrest poles. Attach to the headrest, add your camera, and roll tape!
The only thing you need to think about is which type of fastener to use. If you are really lazy you could just get the right lenght bolts (2) and use standard nuts. Only thing is you'll need a wrench or ratchet to install and remove.
I also glued some rubber on the inward facing surfaces for a non-slip grip. I was also able to find bolts that had a black plastic knob on the end, so I can install and remove without any tools.
Enjoy.
Founding Member "OBC" Ontario Beastowners Club
Toronto, Ontario, Canada.
2003 Jet Black / Black Leather
Dinan Rear Sway/brackets
CG Lock, UUS Big Boy Clutch Stop
2001 740i Jet Black / Black Leather
1995 325 Track Car w 1997 M3 vital organs
87 M3 (track car)
mailto:tomburns9999@hotmail.com
"The White House has always attracted the mentally ill."
-Vincent Charles, Secret Service Agent explaining why
security was hightened around the White House.
Tom Burns is offline
Old 8th October 2004, 17:03   #2
MAH
MAH's Avatar
Garage: 2001 Imola Red
Re: Easy Camera Mount
Interesting design. I have a cheaper one for you. Raise the headrest all the way up on the passanger seat. Insert camera, lower headrest until the camera is firmly held. Adjust camera angle by moving the seat back up and down or forward and backward.
I have actully seen this used on some drives with reasonable results. You better have a camera that compensates for the bumps.
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
MAH is offline
Old 8th October 2004, 21:10   #3
cali6869
Banned
cali6869's Avatar
Garage: 323ci
LOL.... good cheap idea
cali6869 is offline
Old 8th October 2004, 21:11   #4
foxyboym5
foxyboym5's Avatar
Garage: BMW E30 M3 1987 & 996 TT 2002
Send a message via MSN to foxyboym5
Mark
i did this in my old m3 at donnington on a track event....the pics and sound were awesome, and that was with an old sony Hi8 camcorder!
cheers
2002 BLACK 996 TURBO
TRACK TOY/PROJECT 1987 E30 M3 Black. Roll cage, Leda/Koni adjustables, Koni springs, camber plates, sparco seats & full race harnesses, Splitsec MAF kit, EVO2 engine, Schrick Cams, 245bhp.
PREVIOUS CARS:
1989 BMW M5 E34
2000 BMW M5 E39
1998 BMW 323Ci
1990 BMW 325i
1981 BMW 635CSi
1995 BMW M3
1995 BMW 328i
1990 BMW 525i
1988 BMW 316
foxyboym5 is offline
Old 9th October 2004, 01:40   #5
louv
louv's Avatar
Garage: '00 M5 Carbon Black / Caramel
Just be careful with this kind of a setup...
Think about what a hard point of the tripod & mount would do in the case of a crash. That would make for some nasty video.
You should consider two safety measures:
1. Safety strap between the camera and a rear seat belt buckle. Just in case the camera comes off the mount, you want it to stay in the back seat area, not be thrashing around in front.
2. Breakaway mounting. In case of a crash, you want the the mounting to break away if it hits something hard... like your helmet. It's a balancing act: strong enough mounting so the camera is steady, yet frail enough to snap itself, not you.
1989 750iL sadly ignored, but still runs great
2000 M5 121,000 miles. All mine.
2001 Tundra Hauls Stuff
2008 Z4 M Coupe My Roundel Cover Girl
2008 Mercedes C350 Sport wifey's car
2009 BMW R1200GS-Adv for on & off-road
louv is offline
rear deck camera mount M5ROKIT M5 E39 and E60 tips & tricks 0 13th September 2003 23:42
OT: 35mm SLR camera kag Off Topic Forum 1 4th November 2002 08:33
I need a cheap, easy to carry Digital Camera... Ashok Arora Off Topic Forum 2 13th September 2002 02:52
Low-tech in-car camera mount louv E39 M5 and E52 Z8 Discussion 16 11th April 2001 22:27
Page generated in 0.11185 seconds with 11 queries
