• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 8th October 2004, 05:28   #1 (permalink)
          Tom Burns
          Tom Burns's Avatar
          Supersprint X-Pipe Question
          Hi All.
          I'm thinking of getting the Supersprint X-Pipes (from Beastpower of course), and had a couple of questions for anyone who has installed them.
          1-I'm sure they sound very nice, but I'm concerned about how much louder they are. I know it's tough to describe in words, but I really need to get a handle on how loud they are going to be compared to the stock resonators. I do a lot of highway cruising, so I don't think I'd like them so loud as to be overly intrusive (competing with the radio/cd).
          2-Are they worth it? (No offence, Beastpower). But what do these pipes offer over a set that could be fabricated by my race shop guys?
          Founding Member "OBC" Ontario Beastowners Club
          Toronto, Ontario, Canada.
          2003 Jet Black / Black Leather
          Dinan Rear Sway/brackets
          CG Lock, UUS Big Boy Clutch Stop
          2001 740i Jet Black / Black Leather
          1995 325 Track Car w 1997 M3 vital organs
          87 M3 (track car)
          mailto:tomburns9999@hotmail.com
          "The White House has always attracted the mentally ill."
          -Vincent Charles, Secret Service Agent explaining why
          security was hightened around the White House.
          Tom Burns is offline
          Old 8th October 2004, 06:20   #2 (permalink)
          BostonRocket
          BostonRocket's Avatar
          Send a message via ICQ to BostonRocket
          Re: Supersprint X-Pipe Question
          If it's going to be paired with the stock exhaust cans, you wont' see much sound change. Don't worry.
          BTW, even with a full exhaust system on the M5, it is NEVER intrusive at all, especially on the highway. The car is very well insulated. The note of the aftermarket exhausts tend to get raspier.
          'Rocket
          H&R Springs
          GONE - 2003 TiAg/Black E39 M5
          GONE - 2001 TiAg/Black E39 M5
          BostonRocket is offline
          Old 8th October 2004, 06:24   #3 (permalink)
          TCM
          TCM's Avatar
          I concur with 'Rocket. This is a definate mod in my book as it helps throttle response and has more of an overall effect thena muffler. Coupled with a stock system, it gets a bit more burbly but is a pita to install as the piping is the same size. Coupled with an aftermarket unit, you increase the noise level by about 25% or so but it does not resonate to the point of annoyance for most people. Hope this helps.
          T.C.
          '01 Silverstone M5
          SuperSprint:X-pipe
          TCM is offline
          Old 8th October 2004, 06:29   #4 (permalink)
          BostonRocket
          As far as coupling it to a stock exhaust, the "noise" gain would be like 5-10%. So basically no difference.
          'Rocket
          H&R Springs
          Old 8th October 2004, 06:52   #5 (permalink)
          RRoberts
          RRoberts's Avatar
          I have just installed a SuperSprint X-pipe and Dinan "mufflers". Throttle response is much improved, and the weight difference must be more than 50 lbs., but this setup is LOUD. The noise is not intrusive when cruising on the highway, or even around town with the windows rolled up. But full throttle will be noticed. Maybe it's my imagination, but I swear I can notice the absence of all that heavy stuff moving around under the car. I'm still considering whether this was a completely smart move, but I love the improvement in acceleration. I may add a couple of bullet mufflers to the X-pipe to take out the harshness.
          BTW, the exhaust noise is much more pleasant to my ear than the former single-mass flywheel rattle. Also more pleasant than Civics with fart cans.
          With regard to making your own X-pipe, this obviously can be done. I work part-time in a race shop these days, and know what the charge rate is. The SuperSprint part is sufficiently inexpensive and well made that I think you will end up paying about the same for a custom made duplicate. The attachment to the cats is particularly well designed, the tubing is flattened where it needs to be, has the factory hanger tabs, is constructed of 304 SS, and fits perfectly. In addition, 2.5 inch 304 tube material is not cheap. You could use carbon steel, but everything else in the exhaust system is SS. I always elect to buy the part if it is well made, and the purchase price is near what would be required to make it myself.
          Regards, Dick Roberts
          RRoberts is offline
          Old 8th October 2004, 17:11   #6 (permalink)
          MAH
          MAH's Avatar
          Get the x-pipe. It is easy to reverse if you do not like it or you want to upgrade to a Tubi exhaust which is whjat I did. I had the x-pipe for almost two years with the OEM exhaust. The resonators alone weight about thirty pounds so there is some weight savings and you will notice a difference in the way the car accelerates.
          It will increase the the exhaust note and make it deeper. You will notice it, but just barely. You do pick up a great burble on deacceleration. Over time, at least a year, it will grow deeper and louder, but the sound is very nice and it never intrudes into the cabin.
          This is one of the best and least expensive mods for the M5 and it is completely reversable.
          Mark
          MY2001 Imola Red
          Lux. Black Interior
          Painted Calipers,
          Autowerke CAI
          Powerchip Software Upgrade
          Tubi Catback Exhaust
          361RWHP
          425HP and growing!
          MAH is offline
          Old 8th October 2004, 19:07   #7 (permalink)
          foxyboym5
          foxyboym5's Avatar
          Send a message via MSN to foxyboym5
          'Rocket
          agree with rocket too..highway cruising at 70mph in 6th, can almost hear nothing from the exhaust, and thats with my Eisenmann race, which along with the kelleners is one of the loudest available for the beast (Rocket's vid clips helped convince me!!)
          2002 BLACK 996 TURBO
          TRACK TOY/PROJECT 1987 E30 M3 Black. Roll cage, Leda/Koni adjustables, Koni springs, camber plates, sparco seats & full race harnesses, Splitsec MAF kit, EVO2 engine, Schrick Cams, 245bhp.
          PREVIOUS CARS:
          1989 BMW M5 E34
          2000 BMW M5 E39
          1998 BMW 323Ci
          1990 BMW 325i
          1981 BMW 635CSi
          1995 BMW M3
          1995 BMW 328i
          1990 BMW 525i
          1988 BMW 316
          foxyboym5 is offline
          Old 8th October 2004, 19:55   #8 (permalink)
          FAST 5
          FAST 5's Avatar
          Okay Boys.......
          See my new thread, titled "TAKING "THE DEEEEP PLUNGE"
          You'll find it interesting and I'd like your opinions please.
          FAST 5 is offline
          Old 8th October 2004, 22:11   #9 (permalink)
          Carrera2RS
          I agree with all that's been said. Regaring fir, the clearances are very marginal so I would steer clear of a one off fab, more trouble than it's worth. The Supersprint is beautifully made !
          Carrera 2RS
          Carrera2RS is offline
          Rasp-X pipe & Kelleners exhaust now on! LONG ALX E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 6 7th June 2004 22:12
          Supersprint mufflers plus X pipe M5manny For Sale or Wanted 2 22nd October 2003 23:21
