• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 7th October 2004, 16:54   #1 (permalink)
          MAH
          MAH's Avatar
          Interesting Hidden Item - Read the manual?
          All,
          As I am sure most of you aware of(at least those who have read the manual and can remember it all) if you pull back on the turn signal stalk twice after the car is turned off, the HID headlights and tail lights will stay on for a couple of minutes for the purpose of helping you see around the car in the dark. A nice feature, but one which you generally forget about if you do not use it very often. In fact, that is the case with quit a few of these mostly forgotten options. If you never hold down on the station changing buttons on the steering wheel, you would never realize you can change stations, not just jump between preset stations.
          Anyway, all of this said, I wish BMW could have seen fit to engineer the lights automatically turning off once you remove the key to the ignition and open the door. It probably would save a number of dead battery situations for us all.
          Too much to ask?
          Mark
          MY2001 Imola Red
          Lux. Black Interior
          Painted Calipers,
          Autowerke CAI
          Powerchip Software Upgrade
          Tubi Catback Exhaust
          361RWHP
          425HP and growing!
          MAH is offline
          Old 7th October 2004, 17:25   #2 (permalink)
          Ashok Arora
          Ashok Arora's Avatar
          Re: Interesting Hidden Item - Read the manual?
          ...and if you hold down the seat heater button, it will switch off no matter what setting it's on
          Ashok
          2002 E39 Carbonblack/Caramel M5 (past)
          2005 E60 Blue Onyx/Caramel/Light Figured Ash M5 (past)
          2007 E90 Montego Blue/Black Alpina D3 (present)
          Beware the Red Cog of Death!
          Ashok Arora is offline
          Old 7th October 2004, 17:56   #3 (permalink)
          basil
          basil's Avatar
          And those two little red dots of light above on the overhead light fixture serve as navagation lights so one can read a map, etc. in the dark without having to turn the regular cabin lights on and temporarily degrade night vision. The dash lights need to be turned up all the way for them to be strong enough though.
          basil is offline
          Old 7th October 2004, 18:12   #4 (permalink)
          1badm5
          1badm5's Avatar
          Read the manual...lol??? I wish for so much patience! All kidding aside, I have only BRIEFLY browsed the manual (to my detriment). I have owned the '98 740iL for about 4yrs now and I must admit there are way too many "do-dads" features to have to learn, so I pretty much "blew-em-off".
          The headlite feature you mention is a great feature though...thanks for sharing, I probably would have never known! And it's simple enough to use often without having to pull out the owners manual and have to learn the process each time!
          Thanks!
          Robert
          1badm5 is offline
          Old 7th October 2004, 20:13   #5 (permalink)
          mottati
          mottati's Avatar
          the "follow me home" feature... On my 00 car, i only have to pull back once to activate this. I use it often.
          How about this, click your turn signal into the left or right position before shutting off the car, and the parking lamps will stay illuminated on that side of the car. Helpful if you're parking on a narrow road, so someone can see your car easier.
          Engine:
          Suspension:
          Interior/Misc:
          mottati is offline
          Old 7th October 2004, 21:19   #6 (permalink)
          dwasifar
          dwasifar's Avatar
          Y'know, I liked that little feature so much that I bought the parts to install overhead LEDs in my utility car, a '99 Accord. Then other things came up and I never got around to it. I traded the Accord last weekend, for an '04 Accord, and when I took it out for its first night drive I found that Honda has obviously been paying attention to what BMW is doing - the new Accord has the same feature.
          dwasifar is offline
          Old 7th October 2004, 23:03   #7 (permalink)
          atomic80
          M5 Extraordinare!
          atomic80's Avatar
          Too much to ask?
          They did implement these automatic on/off headlights into 2002 and newer M5's. I've been trying to get these retrofitted into my 2001 M5 for a while now without luck. Maybe you'll have better luck than I did.
          Jason
          '05 Range Rover w/mods
          '05 K1200S w/mods
          '07 997TT w/mods
          '08 Audi A3 w/mods
          atomic80 is offline
          Old 8th October 2004, 04:45   #8 (permalink)
          Teutonaddict
          Teutonaddict's Avatar
          Every day's a school day!!!
          Dayum, Mark!
          You CAN teach an old dog new tricks!!
          I guess I'd better RTFM! LOL! I've owned an E39 since 97, and an E38 for two years, and I never knew I had that capability. Wow.
          Clear case of 'ESO.' Equipment Superior to Operator.
          I'm beginning to feel a bit like my late father when he saw that my 98 540i/6 came with a VHS supplement to the owner's manual. Even as an engineer, he was overwhelmed by the technology. "I just want to DRIVE the flippin' thing!" Of course, he was old school---slide rule style!
          -Dave
          BOTH SOLD!!
          '00 Carbon Black/Black All-Leather/Sportive
          #101421
          Teutonaddict is offline
          Old 8th October 2004, 05:56   #9 (permalink)
          1C00lVC
          1C00lVC's Avatar
          Send a message via AIM to 1C00lVC Send a message via Yahoo to 1C00lVC Send a message via Skype™ to 1C00lVC
          Re: Every day's a school day!!!
          If you leave the turn signal clicked to one side (left or right) and turn off the car, the corresponding side of the parking lights will stay on.
          it looks really cool if you have angle eyes lights, and only one of them is on..
          Arie
          Remember, with an automatic transmission, Shift Happens....
          '01 M5 - Titanium Silver/Siilverstone/Aluminum trim
          - PDC
          - Split seats
          - deleted spoiler
          - M Audio
          - 8000 phone
          - Voice Reco
          - TV tuner
          My Website
          1C00lVC is offline
          Old 8th October 2004, 06:09   #10 (permalink)
          Terk
          Terk's Avatar
          [quote=Teutonaddict]I guess I'd better RTFM! /QUOTE]
          I guess we learn things all the time on this board.
          Of course if we had a choice of RTFM or .... I know what I'd be doing.
          Tony
          07 997TT Basalt Black/Natural Grey
          05 X5 4.8is LeMans Blue/Black Nappa
          05 X5 4.4i Titanium Silver/Black
          69 Firebird Carousel Red/Black
          03 ///M5 LeMans Blue/LeMans Blue (sold )
          Terk is offline
          Old 8th October 2004, 16:45   #11 (permalink)
