Old 14th September 2004, 16:22   #1
madmmt
Garage: apline white
SRS light reset????
Does anyone know how to reset the SRS light without the reset device?
While I was changing the window regulator, I turned the power on to adjust the window height with the airbag unplugged. I believe that caused a trigger and now the srs light would remain on. I know you can get a tool for around 150 but people have also reset lights by depressing buttons, grounding contacts etc.
Please Help
madmmt is offline
Old 14th September 2004, 19:10   #2
BeastPower
Guest
Re: SRS light reset????
Please Help
I would have the dealer check it out. The main reason people would want to reset the SRS light, is if they installed aftermarket seats that don't have the airbag occupant pressure pad. You may have a fault in the SRS system, which will make the system inoperable in the event of a crash.
Cheers, Daniel.
Replacing license plate light bulb? Wright E39 M5 and E52 Z8 Discussion 25 19th January 2009 18:40
Check Licplate light!?!? Anger vent Wright E39 M5 and E52 Z8 Discussion 10 17th September 2006 18:37
How many M5 owners to change a light bulb? Aussie2U Off Topic Forum 35 17th June 2005 01:04
Can an un-reset Service Indicator cause intermittent SES light? greg E39 M5 and E52 Z8 Discussion 15 8th May 2004 06:01
Page generated in 0.09166 seconds with 11 queries
