Old 11th September 2004, 07:16   #1
GussM5
GussM5's Avatar
Garage: 02 M5 Le Mans
Anyone know how to set the Home link system?
Need help guys,
I have been going nuts trying to get the home link system to work in my M5 (memory buttons adjacent to the Sunroof open/close button. I just relocated into a gated community in Florida where I must use a remote to get in. I set the ignition key to the #2 position and held the #1 and #2 buttons hoping to see them blink before commencing the remote control learning process. Unfortunately, I received no response. Am I missing a step? Any help would be truly appreciated
GussM5 is offline
Old 11th September 2004, 07:42   #2
Whiteyford
Whiteyford's Avatar
Garage: M5 Anthracite
Re: Anyone know how to set the Home link system?
I beleive you are supposed to hold in buttons 1 and 3 to reset the sytem and then go through the procedure that is in the owner manual.
Whiteyford is offline
Old 11th September 2004, 07:55   #3
ard
ard's Avatar
Ahh...possibly the same problem with my gates.
Homelink works by first sampling the signal from your regular remote so that it can copy it. It does this by you repeatedly triggering your remote so it can 'listen'...when it listens enough it copies it and sets a light so you know to stop.
Here's the problem- some remotes have a long code- if you follow the procedure in the manual you MIGHT be pressing the remote too often and interrupting the code so homelink never gets the right copy- I tried to just slow down my repetition rate- worked like a charm.
The garage doors had no problem- just the gates.
ard
PS let us know what works...
ard is offline
Old 11th September 2004, 07:55   #4
Jayson
Jayson's Avatar
Garage: m5
Send a message via AIM to Jayson
It seems to me in just trying to program some things, that if it's a rolling code system, you have no luck making it work...Course thats just one mans experience.
Jayson is offline
Old 11th September 2004, 09:04   #5
ard
ard's Avatar
Yep- but most gates don't use the security of a rolling code system. Many gates have a code that IDs the actual transmitter, so that they can keep track of who's coming and going.
ard is offline
Old 12th September 2004, 06:37   #6
GussM5
GussM5's Avatar
ard
I tried holding down the #1 & #3 buttons for a few seconds to set the system to learn, but I'm not getting the buttons to blink, which will signify that the system is ready to copy the code. How do I get those buttons to blink? Can you give me a step by step how you got yours to work? These remotes are driving me nuts. one for the gate, one for the garage, and another for the alarm system.
GussM5 is offline
Old 12th September 2004, 08:28   #7
ard
ard's Avatar
Sorry, I have a Homelink 3 button system... but not in an M5 (yet)
Hopefully someone else will post M-specific instructions- if not PM me and I'll dig out the details on the acura one...
ard
ard is offline
Old 12th September 2004, 14:20   #8
jerbro
jerbro's Avatar
Garage: 1999 540i / 6 Titanium Silver
Maybe it's just me, but do the instructions on homelink.com not work?
First Time Programming: http://www.homelink.com/program/first.html
Gate: http://www.homelink.com/program/gate.tml
Garage Door Opener: http://www.homelink.com/program/gdo.html
Erase Everything: http://www.homelink.com/program/erase.html
All instructions in one file: http://www.homelink.com/program/hlmanual.pdf
Seem mighty similar to the OEM instructions for the homelink gdo in my 540.
Luck!
-Jeremy
jerbro is offline
Old 12th September 2004, 19:21   #9
Jayson
Jayson's Avatar
Garage: m5
Luck!
-Jeremy
I clicked the garage door opner one, and it says at the end to proceed to rolling code instrutions...where is that at?
Jayson is offline
Old 12th September 2004, 19:29   #10
ard
ard's Avatar
Here:
http://www.homelink.com/program/rolling.html
ard
ard is offline
M5DE & Delivery Story - VERY LONG w/ Pictures Link matthewpenn E39 M5 and E52 Z8 Discussion 26 7th May 2003 16:37
Alpina B12 5.7 Coupe ShiftTronic CarlT ALPINABoard.com | BMW Alpina Discussion 3 15th March 2002 04:29
Nav Sw Ver 18 upgrade - FAQ 1C00lVC M5 E39 and E60 tips & tricks 0 12th March 2002 06:00
DSP Settings Jet Black E39 M5 and E52 Z8 Discussion 22 5th January 2001 01:24
How good is the M5 Sound System? Roton E39 M5 and E52 Z8 Discussion 15 18th July 2000 14:09
Page generated in 0.19833 seconds with 11 queries
