5th September 2004, 21:22
#1 (permalink)
Missing pixel's
Did someone of you have/had similar problem ? If yes , please help me.
01 540iA Protection line
00 740dA
5th September 2004, 21:29
#2 (permalink)
Re: Missing pixel's
Bad link.
But if you have dead pixels in your Nav screen, take it to the dealer and the screen will be replaced under warranty. Mine is on order for one dead pixel.
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
5th September 2004, 21:41
#3 (permalink)
Re: Missing pixel's
It's not the nav screen.
00 740dA
5th September 2004, 22:00
#4 (permalink)
Re: Missing pixel's
fix your link
5th September 2004, 22:50
#5 (permalink)
Re: Missing pixel's
This should be work.
00 740dA
6th September 2004, 00:15
#6 (permalink)
Re: Missing pixel's
I have the same only much worse.. the only thing that displays properly and legibly is the milometer. Apparently BMW say the only way to fix it is with a new cluster at 660 Quid!! So i'm putting up with it for now.
Cheers
DMC
6th September 2004, 00:16
#7 (permalink)
Re: Missing pixel's
I have the same problem.. sometimes its really bad, other days I can live with it.
6th September 2004, 01:10
#8 (permalink)
Re: Missing pixel's
Cheers
DMC
Did they not entertain swapping it at all, even without warranty? Im waiting to hear back from BMW GB to see how far I get with trying to get mine changed over. It is such a well known problem, they should still swap them. (I hope!)
Ps there are instructions for a possible fix somewhere, to do with cleaning the ribbon conectors in the cluster. Some people have said this has worked, others only temporarily. May be worth a bash
6th September 2004, 02:26
#9 (permalink)
Re: Missing pixel's
thats not the nav screen.
6th September 2004, 02:55
#10 (permalink)
Re: Missing pixel's
I am looking into using http://www.vdorepair.com/ If they convince me that their repair is fairly permanent then I'll take a chance. Based on what I have read it seems like the clusters all have problems so replacing it with a new one just means the problem will return again.
6th September 2004, 08:10
#11 (permalink)
Re: Missing pixel's
This is a known problem and fixed under warranty as long as it's doing it when your SA can see it.
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
6th September 2004, 12:46
#12 (permalink)
Re: Missing pixel's
My car is a 1999, don't think i have a warranty. Also the repair service is for USA only .. Anyone providing this service in the UK?
cheers
dmc
