Old 24th August 2004, 04:45   #1
Osodog
Osodog's Avatar
Garage: M5
Diagnosing understeer/floating at highway speeds
Hi, I am trying to troubleshoot an issue I am having. I am not sure if understeer is the best term but basically when crusing on the highway and going over some undulating roads, the car feels like its floating and wanting to push on the outside of the turn - so if I am going right, it wants to drift to the. Sort of like its on its but its not. I had new rear tires put on, a 4 wheel alignment done and had the suspension looked at but did not find anything. The tires were over-inflated (42 fr, 46 rr) and adjusted them to 37,39 which did make a difference but I still have this drifting type sensation.
Any thoughts?
Visit my web site to help raise funds for LLS:
http://pages.teamintraining.org/sf/Yosemit109/jmilne
Osodog is offline
Old 24th August 2004, 05:58   #2
TCM
TCM's Avatar
Re: Diagnosing understeer/floating at highway speeds
The M5 can get floaty at high speeds (120mph+), but I think you might have some luck changing your tire pressure around. To reduce the amount of understeer, try 41psi front, 39psi rear. I have found this to be a great pressure to help keep the vehicle fairly neutral in turns and have the ability to power the rear around when needed. Hope this helps.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 24th August 2004, 06:52   #3
Osodog
Osodog's Avatar
Garage: M5
Thanks, I'll give those settings a try. The floating is happening even at relatively low speeds for the M5 (70 - 80 mph). It also seems to be tramlining more than I remember it being, so maybe the fronts are getting worn down
Osodog is offline
Old 24th August 2004, 07:15   #4
PhilSeastrand
PhilSeastrand's Avatar
Garage: 2001 M5 Silverstone/Silverstone
Send a message via MSN to PhilSeastrand Send a message via Yahoo to PhilSeastrand
Floating at 70-80? Something is definitely wrong. My experience has been that the faster I go, the more planted it feels, at least up to 150 (haven't had an opportunity to exceed that yet).
How is the wear pattern on your tires? Even? Cupping? Inside-out?
Phil
2010 Toyota Prius
2004 Honda Pilot
PhilSeastrand is offline
Old 24th August 2004, 12:17   #5
BeastPower
Guest
The M5 needs a suspension upgrade, to either stiffer struts/springs or a coilover suspension. I also noticed exactly what you are describing, at around the 60-70mph level, so I doubt anything is wrong with your M5. If you are used to driving sports cars, you will be much more sensitive to this "bouncy" feeling.
Cheers.
Old 24th August 2004, 14:48   #6
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
I know this will sound a bit nuts, but on tire pressures, I have found the best setup is 38 front/ 34 rear. I was really wearing out the middles of the rears and with this setup the steering takes on better weighting and the rears are wearing more evenly. I have purchased a pyrometer to help me see if if I have it right, but so far I havent had the time to go drive the car hard and take readings.
If you have any worries at all, I suggest you have the dealer inspect it and get someone who is familiar with M5s to take your car for a quick test drive with you in the passenger seat. Then you'll know if its a normal car and you are just extra sensitive or if you really have a problem.
All the best,
MEnthusiast is offline
Old 24th August 2004, 17:39   #7
M'nd
Guest
M'nd's Avatar
Garage: 2002 M5 Carbon Black
I have to agree with the above statement. The one time I was at 145 the car just sucked down on the road. Very stable and confident.
M'nd is offline
Old 24th August 2004, 17:57   #8
Osodog
Osodog's Avatar
Garage: M5
The car had some decent toe-in (the right slightly more than the left), the outer edges of the front tires were getting worn. I will probably replace the fronts soon, hopefully that will help.
Osodog is offline
Old 24th August 2004, 19:06   #9
Greco
Greco's Avatar
Garage: 1998 E39 540 Biarritz Blue/Beige SPP
Could be rear ball joints. Ever since mine started to go the rear always felt loose...
- Bill
>> Just an E39 540i/6 Biarritz Blue <<
Greco is offline
Old 24th August 2004, 19:48   #10
M5Kid
Garage: N/A
Can somebody explain toe-in to me. I understand by increasing the toe-in you also increase negative camber?
Travis
M5Kid is offline
Video: Highway Challenge 2004 SUPRA Gumball 3000 Forum 23 5th November 2004 00:29
Dinan stage III fine tuning...for "skittish" handling at higher speeds Jacob Lee E39 M5 and E52 Z8 Discussion 7 8th February 2002 23:41
Page generated in 0.13851 seconds with 11 queries
