Old 23rd August 2004, 16:52   #1
MAH
MAH's Avatar
Garage: 2001 Imola Red
Aftermarket wheel question - Repair issue
All,
I have this nagging little problem that I lose about 7lbs. per day on one of my wheels. I know exactly where the loss is occurring, around the inside wheel edge. I have taken into Discount Tires twice. The last time they told me that the chrome had flaked off around the inside edge and that the tire would not seat properly, thus causing the leak. They recommended a shop nearby that could fix this problem.
My comment is that I think they don't know what they are talking about. I mean how thick can chrome be? The bead around the tire is still made of rubber so it is somewhat flexable, so even with small imperfections it should seat with no problems.
Can anyone throw some light on this subject for me?
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
MAH is offline
Old 24th August 2004, 04:37   #2
Anita
Anita's Avatar
Garage: 02 M5 TiSi
Re: Aftermarket wheel question - Repair issue
Originally Posted by MAH
All,
That sounds like a pretty significant leak to me. Unfortunately I know diddley about what could be causing your problem, but will try to remember to check with my SA tomorrow when I pick up my Coupe wheels (Yes I'm having my new Kumho's mounted at a decent place this time!!). I do know that having gouges, bends, dings etc along a wheel rim was a concern when I bought my used OEM track wheels because of the supposed potential for leakage.
How long have you been noticing the leakage? How old are your tires?
Anita
"When will I know that I really can't go
To the well once more time to decide on
When it's killing me, when will I really see
All that I need to look inside
Come to believe that I better not leave
Before I get my chance to ride" RHCP "Snow"
Anita is offline
Old 25th August 2004, 01:20   #3
Anita
Anita's Avatar
Garage: 02 M5 TiSi
OK Mark here's the word from my SA--gotta type this quick before I forget (no smart comments about that).
He said it was possible to have a leak like that resulting from the chrome flaking off inside the wheel edge and the goal was to smooth the lip down with a grinder or whatever so it was smooth all the way around (by removing the remaining chrome finish and loose bits). Then apply the bead sealer and it should not leak anymore. So here you have it another opinion, of course made without actually seeing your wheel and with me as the translator
Good luck and let us know how you eventually solve the problem.
A
Anita is offline
Old 25th August 2004, 18:45   #4
MAH
MAH's Avatar
A
Anita,
Thanks for the insight. It is good to know that this may actually be something that can be repaired as promised.
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
361RWHP
425HP and growing!
MAH is offline
Old 25th August 2004, 19:21   #5
Anita
Anita's Avatar
Garage: 02 M5 TiSi
Mark,
You're welcome! I have a person I work with at Tire Rack too that handles BMW special applications if you want another opinion. I'll dig out his extension and PM it to you. I'll admit it does sound funny that somthing as insignificant as flaking chrome could cause such a problem.
Anita
Anita is offline
Wheel removal - dumb question dwasifar E39 M5 and E52 Z8 Discussion 37 25th March 2003 20:50
Winter wheel rim question . . . Rcl4668 E39 M5 and E52 Z8 Discussion 6 8th June 2002 02:14
Far Out Question: Aftermarket M5 6 speed in SL55, Physically Possible? chunpng E39 M5 and E52 Z8 Discussion 11 7th February 2002 20:10
Wheel question - no consistent anwer. Noka E39 M5 and E52 Z8 Discussion 13 22nd December 2001 17:50
Question for those with wheel spacers Racerboy E39 M5 and E52 Z8 Discussion 2 26th November 2001 03:49
Page generated in 0.12071 seconds with 11 queries
