Old 23rd August 2004, 10:50   #1
540is
Garage: M5 Vortech 7Ysi SC
Send a message via ICQ to 540is Send a message via MSN to 540is
Anyone knows if there is any aftermarket radiators for M5?
When I say aftermarket I mean like race/sport/heavyduty units.
540is is offline
Old 23rd August 2004, 17:39   #2
RRoberts
RRoberts's Avatar
Garage: 2001 M5 - Alpine White
Re: Anyone knows if there is any aftermarket radiators for M5?
I am not aware of any. The car is too new, with about half the fleet still under warranty, so I would guess that there have not been many radiator failures in the first place and fewer still (excepting crash damage) where the owner was obliged to pay for a replacement. Plus, there are relatively few E39s that are modified for racing and the stock radiator is satisfactory for occasional track duty.
There is long-term concern with the (limited) longevity of the plastic components in the BMW radiator, and the likely extreme consequences of loss of coolant with an all-aluminum (and very expensive) engine. Fluidyne has recently brought out an all-aluminum replacement radiator for the E36, where the factory radiators have been a source of problems on both track and street-driven cars. However, this unit does not significantly improve heat rejection ability. Failures in the field needed to rise to a significant level before it made commercial sense for Fluidyne to tool up an aftermarket upgrade.
Fluidyne will also build custom radiators to order for probably any application, but the customer will need to provide dimensions and specifications. Plan on spending the best part of $1000.00 if you go this route.
Regards, Dick Roberts
RRoberts is offline
Old 23rd August 2004, 18:48   #3
marinakorp
Garage: 99 540iT Grey
I believe Nissen makes a replacement for the e39 540 ... not sure if that also applies to the M5
there also was anothr manufacturer that was putting out an aluminum radiator... thought REVHIGH was tracking down a lead on that one
99 540iT
Powerchip Gold 93
M5 Rear Swaybars
Shadow Badging / Grill
marinakorp is offline
Old 23rd August 2004, 22:17   #4
540is
Iam not looking for a OEM replacement - but a Nurnburgring in Sahara version....
540is is offline
Old 23rd August 2004, 23:20   #5
marinakorp
Like I said... someone was working on an all aluminum one not too long ago... that in conjunction with a remote oil / tranny / diff cooler would give you what you are looking for... yes?
Old 23rd August 2004, 23:26   #6
boostmiser
boostmiser's Avatar
Garage: 2002 Alpine White M5
Fluidyne makes them for the e36 but I don't see why they couldn't start making them for the e39 if someone asked.
http://www.fluidyne.com/images/fluidyne.pdf
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
boostmiser is offline
Old 23rd August 2004, 23:43   #7
ArsenalFC
Garage: 2008 - ///M5 - White
THey are going to make one for the E39
http://www.zionsvilleautosport.com
| Dixis| Gruppe M | Brembo | OZ Ultraleggera HLT |
ArsenalFC is offline
Old 24th August 2004, 01:07   #8
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
But it doesn't look like they are including the M5....No place for M5 as "model" in interest sign up sheet...
gsfent is offline
Old 24th August 2004, 01:15   #9
Ohmess
Ohmess's Avatar
Garage: Black 540i6
They actually added the e39 when a bunch of us from some other board (which will remain unmentioned) sent emails to them requesting one. Within a couple of days, they had the note up that they were working one. We must have generated a pretty good response. I intend to replace mine as a preventative measure.
Ohmess is offline
Old 25th August 2004, 05:12   #10
Gorilla Beast
Guest
Gorilla Beast's Avatar
Garage: E39 M5 Silverstone
Send a message via AIM to Gorilla Beast
Fluidyne barely came out with the E36 Radiator about 1.5-2 yrs ago and look how many of those E36's are around and how long it was available already 92-99 and this is in US I am talking about. I doubt they will attempt to mock up and tool one for M5 esp. Demand is too low for our M5 and most are still pretty new or with low miles, it seems at least in US.
Gorilla Beast is offline
dealer already claiming he's charging over sticker Tomk E60 M5 and E61 M5 Touring Discussion 48 2nd August 2004 16:32
POLL: Who has aftermarket tranny fluid in their car? Need4Spd E39 M5 and E52 Z8 Discussion 10 30th August 2003 18:48
Need advise on chosing between (3) aftermarket exhausts....... FAST 5 E39 M5 and E52 Z8 Discussion 9 22nd October 2002 15:34
Insuring aftermarket parts tfung E39 M5 and E52 Z8 Discussion 3 11th November 2001 01:30
Page generated in 0.23207 seconds with 11 queries
