21st August 2004, 23:30
#1 (permalink)
Gas problem
This is a very odd problem that I cannot figure out for the life of me. Over the past week I have been putting gas in as I usually do in the car but when I wake up the car says their is no gas with less than 5 miles to go before going dry, or gas is just missing in general. I thought maybe something is leaking but their is no gas on the garage floor. I don't know where to even start to think the problem is. The car runs and drives fine, but this problem is costing me a fortune! Any help would be appreciated.
21st August 2004, 23:34
#2 (permalink)
Re: Gas problem
Either somebody else is driving your car or you have a thief in the area
MISC PICS
2003 M5 - Jet Blk/Silverstone/Black Birch Anthracite,35% Window tinting, CPT8000, Valentine 1, Royal Purple,Rogue SS,Rogue WSR,Rogue Tranny Mounts,3m Stoneguard,Powerchip,AA CAI, IATS Relocate,Stealth-One,Lidatek LE-30
22nd August 2004, 01:29
#3 (permalink)
Re: Gas problem
Haha, no nobody is driving the car, humm about the theif, I'm going to test that theory, I'm going to fill it up and surveilance the car all night..let's see what happens. But the only thing that is making me think its not that is gas isn't dissapearing from the other cars...it's worth a try!
22nd August 2004, 15:38
#4 (permalink)
Re: Gas problem
Rather than staying up all night, why not just log the odometer mileage?
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed
StopTech 4-wheel big brake upgrade (ST40 front/ST22 rear)
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion
CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8
2007 Corvette Z51 Coupe 6-Speed
2009 Honda Fit Sport w/NAV
22nd August 2004, 19:10
#5 (permalink)
Re: Gas problem
Who has access to your keys? Maybe someone playing a practical joke on you? After a few weeks, maybe then they start putting in gas and make you think you're getting 200 miles a gallon?
Are they any signs your gas door lock is broken? If there is no gas on the floor or gas smell, then someone is either driving your car or siphoning out your gas.
Need4Spd
22nd August 2004, 19:17
#6 (permalink)
Re: Gas problem
Ruffinit;
Can you confirm if you are in fact loosing the gas? By that I mean when you fill up does the tank take the gallons the gauge says are missing?
Second, I would consider checking the car's fuel system under load, you may have a gas leak which only shows up under higher fuel system pressure, in the garage you are usually at or near idle, and if it is a high pressure leak, it may not show up in those conditions. One thing you could try is park the car, and rev the engine giving it a lot of gas a few times and then check under the car.
Lastly I would attempt some aggressive take off, and down shift maneuvers, keep your eye in the rear view mirror, see if you notice an excessive amount of black smoke when you're into the throttle.
Lastly, do you have a 16-85 yo son with a preverbal sweet tooth for ///M Power?!
Best of luck finding the problem
-Audio
2006 M6 Indianapolis Red / Sepang Bronze
2004 SL55 Brilliant Silver / Berry Red
2000 M5 Carbon Black / Silverstone (Retired)
- Iforged Aeros
- Stoptech Reds
- BB Tri-flo
- 6000K
- Rogue SSK
23rd August 2004, 08:01
#7 (permalink)
Re: Gas problem
Haha, thanks for all the replies. The car is currently under vigilence at all times, so we'll see!
Audio: Unfortunately their is a preverbal sweet tooth running around the house at the age of 18, I am watching to see if he sneeks it out at night! But I am going to try those tricks tomorrow for sure.
23rd August 2004, 17:14
#8 (permalink)
Re: Gas problem
You also could activate the security code...it won't move then
MISC PICS
24th August 2004, 02:05
#9 (permalink)
Re: Gas problem
M5 has a gas problem? Stop feeding it mexican food before you put it in the garage at night...(sorry, someone had to make the horrible joke).
My Triumph did something similar, but it just turned out to be bad O2 sensors making the car run rich (didnt have a working gas gauge, so I had to go by mileage), and burn more gas. That wouldnt be your issue though.
I dont think it would be the 18 year old, as I was once a sneaky 18 year old myself. The trick is bring the car back with the amount of gas you took it with, and I am sure he would be smart enough to do that. Let us know what you find.
-Brendan
'01 540/6
25th August 2004, 04:04
#10 (permalink)
Re: Gas problem
Going in tomorrow, I'll keep everyone posted
25th August 2004, 15:47
#11 (permalink)
Re: Gas problem
if you rgas is indeed being syphoned out every night, then next time put some diesel in it and give the thief a nice surprise!
ummmm..... forget i said that!
Don't wanna be too "insecure", so I will stick to my current cars:
'06 Hummer H3
'00 996 Carrera
