On my previous 2002 330i Sport, if you pressed the DSC button once, it turned on the warning triangle, and disabled DSC "one level" to a point where it let you spin the wheels, but kicked in if the car got really sideways. If you held the DSC button down for 3 seconds, the DSC Triangle AND the BRAKE light would illuminate in an amber color to let you know that you had COMPLETELY disabled the DSC system.
Is it supposed to work the same way on my 2002 M5? I tried it yesterday, and the "second level" deactivation didn't work. I kept holding the button, and then I got to a point where I couldn't deactivate DSC at all. Every time I pressed the button, nothing at all would happen. I had to shut off and restart the car to get "normal" operation back of the DSC disable button, but it still does not let me set it to the second disabled setting like it did on my 330i.
Any ideas? Is this normal for M5? I thought it was a two level setting choice.
The E46 M3 is a multi-setting. When press the DSC button once, it goes to one-level. Hold it down for more that a few seconds, then the DSC triangle light stays on and you're in level 2. To reset, you will have to turn off the car.
__________________ Stay hungry. Stay foolish.
'06 M5 in Silverstone Metallic/Silverstone II Perforated Leather/Aluminum Trim - all options, Hüper Optik Nano-Ceramic 30 Tint, Dinan Aluminum Pedals, Clear Bra, BMW iPod Adapter
'04 X5 4.8iS Titanium Silver/Black (wife's car)
I stand corrected on the M3 front then, strange it's different between the two
I think in the E39 M5 if you hold the DSC button in for a few seconds it turns on the DSC full-time until you shut down the engine.
Jeff
2003 M5 LeMans Blue/Caramel/Walnut
Dinan S3 Includes all Dinan S3 Mods With JRZ Sruts/Shocks, Oil Cooler, Monoball Links
StopTech 4 Wheel BBK With Red Calipers And Slotted Rotors
Axxis Ultimate Pads
M Enhanced Audio
Park Distance Sensors
Two Sets Of Dinan Lightweight Forged Wheels
Winter Tires - Michelin Pilot Sport A/S - 275/35ZR18(Y) (F); 285/35ZR18(Y) (R) (Not Sure If They'll Survive The S3)
Summer Tires - Toyo RA1s- 275/35ZR18(Y) (F); 275/35ZR18(Y) (R)
Dual, Front Mounted LE30's With Custom AIDesigns Kill Switch/LED Panel
Valentine V1 With Stealth One
UUC Short Shifter With DSSR
Oil - BMW/Castrol 5W30 Changed and tested every 3000 miles.
Jeff
I've read/heard that this could be used kind of like for a valet purpose but, it doesn't make a lot of sense. If you hold the DSC button for more than a few seconds, you basically disable the ability to turn off DSC (or as Jeff says, you turn it on full time). That would work - sort of - but, only until the car is turned off and then back on.
On my '02 330Ci, there were two selections other than the default 'on,' just as others have reported. Pressing the DSC button once, disabled the DSC function but left the Automatic Differential Brake (ADB) control active. So, I would still have braking control functions but, DSC would not intervene to prevent wheel spin or other pervceived loss of traction scenarios. Holding the DSC button for more than about 3 seconds, disables both DSC and ADB functions so, it is then all up to you...
On the M5 (e39), pressing the DSC button once, deactivates the DSC and ADB/DBC functions so, it is then all up to you. (This is akin to hold the button for +3 seconds on the E46).
On the M5 (e39), pressing and holding (for more than ~3-5 seconds,) the DSC button, basically disables the ability to turn off the DSC, until the car is restarted. I have not found a use for this. I suppose if I were to actually let one of my kids drive the car even with me in it (not likely), I could force the DSC on...
Hope that helps explain a little and, if anyone could shed some light on the subject, please do.
Thanks,
Greg 2003 ///M5 Jet Black/Black, Sport
Beastpower Sway Bar Brackets, Bluetooth, & all options except PDC & spoiler delete...
