Re: Mr.Clean Auto Dry carwash system: Fact or fiction?
Bought mine from Target on sale for $16.00.
Overall it worked as advertised.
Also, current issue of Consumer Reports gave it a good writeup.
20XX M5 Its Got To Be Red
2006 750Li White/Brown
1996 Porsche 993TT Iris Blue/Grey
2007 Mini Cooper S Vert Sidewalk Package Sparkling Silver/Malt Brown
2006 M5 Indianapolis Red/Indianapolis Red
2001 M5 Imola Red/Black/Imola Red
The Mercedes Benz/Range Rover Years
1992 Miata Red/Black
1987 535is Blue/Beige
1987 930 Black/Black
1985 535i White/Black
1985 911 Black/Black
1972 911 Blue/Black
I am glade howler brought this subject up. If you have soft water and a wax that is not easily stripped, this would be the ideal combination with this product......yes? I will have to give it a try and see what happens over the RejeX I have applied.
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
Originally Posted by PhilSeastrand
This is the first I've heard about this. How badly does it strip the wax? Do I need to wax after every wash? 10th wash?
I've used it a couple of times and have been very happy with the results. Now, however, I'm concerned about a possible wax issue.
Phil, it's not that bad, i had zaino'd my wifes landcruiser maybe 8 months ago, then after a couple months of washes it was needing a re-wax. I re-zaino'd it maybe 6 weeks ago, and have 'mr cleaned' it maybe 3 times since, and it still beads up very nicely. I'd say a synthetic polymer like zaino could easily go 3-4 mos (assuming a couple of washes per month, parked indoors etc) and still look pretty decent.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
Over at the Roadfly Detailing/Car Care Message Board some of the gurus have commented on the harshness of the shampoo and its propensity for leaving a residue. I believe this is highly variable, depending upon your base wax. Since I use only Pinnacle Souveran without combining it with polymers such as Zaino Brothers or Klasse, I find that most of the carnauba wax will be stripped after using the AutoDry shampoo. As an experiment I used my Pinnacle shampoo with the AutoDry system, and, while the water did not sheet off as it did with the Mr. Clean shampoo, and I still had to dry with microfiber towels, much more of the carnauba wax seemed to be retained, both optically and tactilely.
I currently use the Mr. Clean shampoo only every 3rd or 4th wash, and I always follow with several coats of Pinnacle Souveran, even when I use the Pinnacle shampoo.
Al
Al
2003 M5 CB/Silverstone (all options except spoiler deletion), HOME AT LAST!
2008 X5 4.8i Sport Space Gray/Tobacco/Bamboo
2002 540ia Sapphire Black
2004 FX35
1999 MB ML430 (3rd row seats)
1992 Jeep Grand Cherokee
1981 320i 5-speed Henna Red
Sounds like a pretty good product, however I have been just as happy with using a california gold car squegee. works great for getting the water off and the difference in drying time is minor.
Warhaven's 2002 Dinan S2 M5
11/22/04 Dyno: 336.2RHP/329.2T (Exhaust only)
03/15/05 Dyno: 334.38HP/326.24T (+CAI)
06/22/06 Dyno: 348.76HP/331.33T (+ MAF)
Jet Black/Black
Super Sprint X-pipe
AA Front Grill
TC Racing Pedals
TCD Sway bar brackets
MK4 V28.1 NAV upgrade
Zenon 8000K Stage II upgrade
Worked for me. It's no secret that water spots come from mineral deposits. Filter out those minerals and you'll get no spots - no magic in it; amazing it took this long for a product like this to reach mass market.
Works for me as well.
I only use it for the final rinse. I don't really buy into the polymer soap thing, plus it strips your wax. It is important to work from the top to the bottom of the car and completely wash off the other water. I then take a drive down the road and let the air wipe the car off, then I use a towel to hit any wet areas and the windows. It is better than using a towel to dry the whole car. Also the filters only last about 6-8 washes for me. i guess I have really hard water.
You gotta be carefull with it, if the car's paint is too hot, you can end up with a white haze all over the car, that is not easy to get off.
It does sheet like it says, but you still gotta do some spots with a towel.
Personally I plan but not as of yet have done it, I plan to get one, and use only the filter water, ie wash as normal with the "clean water" soap etc, then wash off with "clean water". I think this should help some.
Anyone seriously creative out there?
Sounds like from the feedback the biggest advantage is the filter on the rinse side. How aout someone experimenting with a "PUR" or "Britta" waterfilter. I bet one of those direct faucet replacements could be re-threaded to work with a standard garden hose fitting.... anyone have the tools/dies to try this?
