BBS CH-R Customization for the Beast - BMW M5 Forum and M6 Forums
 6Likes
  • 2 Post By ldawgtheg
  • 4 Post By ldawgtheg
post #1 of 7 Old 25th April 2015, 09:31 AM Thread Starter
ldawgtheg
ldawgtheg's Avatar
Hi M5board,
It's been a while since I've posted but since I use M5board all the time (thank you everyone who has helped contribute to writing DIY's and sharing your experience), I wanted to do a write up on fitting the BBS CH-R wheel on the beast.
I got them and immediately proceeded to thoroughly cleaning them. From the outer face to inner barrel, I touched on all surfaces.
Coming from Forgestar SDC wheels (which looked awesome), I had always dreamed of owning a set of BBS. I was doing an extensive amount of research and knew the CH-R was the one I had wanted. There have been many inquiries of fitting these wheels on the beast but many are concerned with the fitment. Like many, I was extremely concerned. The e39 comes with the ridiculous 74.1 mm hub size that makes it near-impossible to find a wheel that is "made" for this car asides from the Style 65s (which I love). Personally, I have the shop experience and could use a CNC to bore wheels out but that would be my last resort. Fortunately I found out some facts that made BBS the wheel company for me.
Facts:
  1. BBS makes all of their wheels to a bore size of 82 mm. I talked to Robert who works for BBS USA and he informed me that this is solely because of the fact that the e39 does not share a standard hub size as all other BMW's (72.56 mm). Although it does make things tricky, BBS decided to be wise and make all of their wheels with a large and adjustable enough so they could be fit onto any BMW. I ordered their snap-on hub centric rings and that will convert the wheel from 82->72.56 mm to 82 ->74.1 mm.
  2. BBS is a reputable company with racing heritage built into all of their wheels. I believe that wheels are more than just looks. They need to be robust and thoroughly tested.
  3. Why not HRE?
    I love what HRE has been doing. With their attention to detail and gorgeous designs, each wheel is a work of art and they are making a difference in the market. Unfortunately, they will not make a wheel for the e39. If we happen to bore out their wheels to fit our car, such as the Flowform series, it voids their "Lifetime Warranty." I was seriously considering getting a set before I chose the CH-R's.
    Some people say that the "Lifetime Warranty" can be overlooked but I feel a slight cringe if I knowingly void it. This is why I chose to let go of the R40's so that any failure or machine error would not void this so-called "Lifetime Warranty."
Now! Finally after my rant, onto the wheels.
The wheels come in a semigloss matte black sort of finish with rim protectors that were previously installed. Many of my friends and acquaintances have been raising their eyebrows regarding the stainless steel rim protector. Saying that the color mismatch is a huge drawback with the wheels. When I had first received the wheels, I thought yeah it was pretty cool! But as I am about to mount them, I have also caved in to thinking how much better an all black wheel would look without the stainless steel contrast. So today, I did some research and decided to paint (plastidip) the SS rings in matte black.
I wanted to do this right so here is the documentation of my process:
#1.) Tape up all internal edges of the rim where the stainless steel ring meets the rim with electrical tape. The electrical tape has more stretch and flex than masking tape.
#2.) Cut out 4 cardboard circles approximately 18.00"-18.50" in diameter. I used a string/yard that traced the radius of the circle and cut them out. Once this is done, put a microfiber cloth between the wheel and the cardboard circle. This will protect the wheels from any sort of scratching.
#3.) Place the cardboard circles on each wheel and apply masking tape onto the surface of the electrical tape. Watch out to see that you are not masking areas that the electrical tape left exposed to be painted.
#4.) Shake the plastidip can for at least 5-6 minutes. This will prevent an large clumps or particles from clogging the rim.
#5.) Put index cards between the outer rim and the tire. The apply 3 coats of plastidip in 30 minute intervals.
#6.) Peel off the the index cards, cardboard, and electrical tape. When removing, proceed with caution as the plastidip is not yet full dry and could easily be peeled off.
#7.) Admire.
I'll have picture of the wheels mounted tomorrow or sometime later this week. Hope this helped! Feel free to send any feedback towards my way. Cheers~
Apex Stud Conversion 12x1.5
BBS CH-R
Bimmian Illuminated Weighted Shift Knob
Bilstein PSS Coilovers
Brake Duct Vent/Cooling Fully Routed
Carbotech Race Pads
Eurocharged Tune
Rogue Engr SSK
Slimmbones Alcantara E-brake/Shift Boot
Slimmbones Foglight intake
Stoptech ST40 BBK Custom Yellow w/Slotted Aerorotors
Stoptech Slotted Rear Rotors
Stoptech SS Brake Lines
Strassentech Styled CF Lip
Stealth Technik Piano Grilles
Timmay's Muffler Delete
Thule BMW Rack System
Umnitza 6k LED Angel Eyes
Varrstoen Blue Open-Extended Lugs
V1 Hardwired
ldawgtheg is offline
post #2 of 7 Old 25th April 2015, 10:34 AM
Mr. Rob
Mr. Rob is offline
post #3 of 7 Old 30th April 2015, 11:45 PM Thread Starter
ldawgtheg
ldawgtheg's Avatar
Haha unfortunately I won't be selling those for as long as I have the beast. Still searching for two rears for a square set up.
post #4 of 7 Old 30th April 2015, 11:52 PM Thread Starter
ldawgtheg
ldawgtheg's Avatar
And they are on!
BBS CH-R
Carbotech Race Pads
Eurocharged Tune
Rogue Engr SSK
V1 Hardwired
post #5 of 7 Old 1st May 2015, 12:05 AM
mgdmb
mgdmb's Avatar
mgdmb is offline
The Following User Says Thank You to mgdmb For This Useful Post:
ldawgtheg (1st May 2015)
post #6 of 7 Old 1st May 2015, 12:13 AM
paul88
paul88's Avatar
What tyre size and wheels sizes?
Thanks!
Paul
Thank you,
Paul.
01 BMW M5 - Le Mans Blue Metallic - Le Mans Blue / Black Interior - All options - 352RWHP/336RWTQ - 3885LBS without driver
Upgrades
Exterior - Climate Control Windshield - CF Kidney Grills - CF Lip - CF Finned Diffuser - Angeli Bright v3.0
Interior - CF Flat DTM steering wheel - CF Pedals - 2012 Illuminated M5 shifter - Euro Arm Rest w storage
Exhaust - Evolve Headers Ceramic Coated - Super Sprint XPipe - Super Sprint Race Cans
Brakes - Euro floating rotors - Carbon Blue Pads - SS Brake lines - ATE Type 200
Drivetrain - RE Octane Short Shifter - RE T Mounts - 280mm FW + Feramic disk
Audio/Video - B53 Radio with AUX input - MKV navigation - BAW speakers - BAW Subwoofer - BWM Bluetooth
Steering - All German Auto oversized 6061 aluminum power steering reservoir
Suspension - Ground Controll Coilovers (430F - 320Rlbs -GC Camber Plates - Beast Power Bracket - 18MM Rear SB - Spacers
Wheel/Tire - Style 65 - 245/40/18F 275/35/18R Michelin Super Sport
"Most Affordable Application development, ever! Having your own iPhone app couldn't be easier!"
- Robert F, Executive Director, Boys & Girls Club
All Earth needs is LOVE
Choose Appreciation and Joy as your primary emotional tones that you live in! Go to the high energy of Appreciation in order to throw off any negative events! Use your Appreciation-Key to open the door to the new world!
"Nothing will benefit human health and increase chances for survival of life on earth as much as the evolution to a vegetarian diet."
Albert Einstein
American physicist
paul88 is online now
post #7 of 7 Old 1st May 2015, 12:50 AM
Mr. Rob
Boo! That's what I want to do.
Sent from AutoGuide.com Free App
Mr. Rob is offline
Couldn't resist any longer - began customization jtawadros E60 M5 and E61 M5 Touring Discussion 15 6th December 2009 07:38 AM
SMG question in MDrive customization. opie E60 M5 and E61 M5 Touring Discussion 2 11th June 2007 06:19 AM
BBS RC wheels on my beast! M55555 E39 M5 and E52 Z8 Discussion 34 23rd December 2006 01:24 AM
Anyone have 20in BBS's on thier Beast? Tim W E39 M5 and E52 Z8 Discussion 0 26th July 2002 02:34 AM
Key customization Veritis E39 M5 and E52 Z8 Discussion 1 1st July 2000 08:27 AM
