Re: Anyone try the UUC/Rogue Tranny Mounts?
Yeah, I have the UUC mounts, I got the red ones with the "enforcer" caps, which are aluminum caps that go over the mounts and increase their stiffness. These do transmit some more driveline noise and exhaust resonance into the cabin. MOST of the time, i don't mind this, i'm usually alone in the car and in enjoy the additional sound. Occasionally it does bug me. I've been thinking about removing the caps, just to see what happens to the noise. I do feel the shift quality is better with this mod. I initially did it when, after several track weekends, my shifter started feeling more sloppy than usual. The mounts did tighten things up, so they do seem to work as advertised. The Al caps may be overkill though, for a mostly street car at least...
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
