Old 18th August 2004, 18:52   #1
lindenTT
Garage: 1996 993TT
M5 driving experience from potential owener
So after dirving an M5 yesterday I thought I would ask a couple of questions concerning the driving experience.
The first thing I noticed when I pulled out of the parking lot was the long throw of the shifter. Do people on the board swap out the stock shifter for a short shift kit? If so who would the board recommend? THe power of the car comes on very nicely and does not throw you back into the seat like the D4 I am coming from. I like the turbos but sometimes the power comes on too fast and harsh for my taste.
I took the M5 out onto the freeway and purposely got the thing up to 80 to see how it felt at some highway speeds. It was very nice. I headed straight for the clover leaf exit that I know very well. It is a 25mph 180 degree turn and in the S4 I can comfotably take it at 55mph. The M5 seemed to do it almost better.
The car had a more solid feel than the S4 and didnt have too much body roll. My S4 has coilovers on it as well as other modifications so I was a litlte surprised to how well the M5 went throuh the corner without any modifications done to it other than the Dinan exhaust on the car, which sounded amazing.
Overall the car was great. It was fast on the straights and comfortable in traffic. The corners were fantastic.
So to get to some questions:
1. What short shift would people put on the car??
2. What suspensions modifications do people do to the car?
3. Do people upgrade the brakes on the cars or is that somehting that even needs to be done?
4. How many miles do you get out of a set of summer tires?
5. Gas mileage....should I ask?
Thanks.
lindenTT is offline
Old 18th August 2004, 19:45   #2
Jayson
Jayson's Avatar
Garage: m5
Send a message via AIM to Jayson
Re: M5 driving experience from potential owener
Thanks.
1. UUC, Rouge, RMS, ACS
2.Dinan, Coilovers, Sway bars, camber plates.
3.Not many but theres many choices including a t 15" 8 piston front and 14" 4 piston rear
4.I got 12k outta the stockers, it's gonna depend on how you drive. Expect 15k-20k
5. 14 mpg city, 22 highway.
Jayson is offline
Old 19th August 2004, 00:41   #3
Suretyagent
Suretyagent's Avatar
Garage: 2001 M5 Carbon Black
Dear lindenTT:
Welcome. If the M5 you drove was not throwing you back in the seat harder than an Audi S4 then you should make sure the M5 is running without fault. There may be something wrong with the car if it is not noticably faster than your S4. Note - The M5 really comes into its own over 120mph.
1) I've left mine stock but am still considering a short shift kit.
2) Start with an adjustable rear anti-sway bar and go from there. Be sure to replace rear sway bar mounting brackets as stock pieces are weak.
3) For serious track work big brake kits are needed. Spirited road driving - stock brakes work well.
4) Between 8,000 and 15,000 miles depending on how aggressive I drive and how often I go to the track. I've known other owners to get nearly 20,000 and I've also seen a new set of tires shredded during one day at the track.
5) 12mpg to 20mpg. I tend to average around 16-17mpg but I do more city driving and often use full throttle.
Derek
Suretyagent is offline
Old 19th August 2004, 02:10   #4
warhaven
warhaven's Avatar
Garage: 2002 M5 Jet Black
Many options but,
1. EVO3
2. Dinan sways, stut braces, camber plates
3. Brembo or Stop techs "big brake Kits"
4. 20K
5. 16.7 City / 23 HWY
Warhaven's 2002 Dinan S2 M5
11/22/04 Dyno: 336.2RHP/329.2T (Exhaust only)
03/15/05 Dyno: 334.38HP/326.24T (+CAI)
06/22/06 Dyno: 348.76HP/331.33T (+ MAF)
Jet Black/Black
Super Sprint X-pipe
AA Front Grill
TC Racing Pedals
TCD Sway bar brackets
MK4 V28.1 NAV upgrade
Zenon 8000K Stage II upgrade
warhaven is offline
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 53 22nd March 2009 16:12
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 22:03
Need some help with M5 driving experience TonyS555 E39 M5 and E52 Z8 Discussion 4 29th April 2002 17:47
M5 driving experience bgomez E39 M5 and E52 Z8 Discussion 16 22nd January 2002 20:25
Page generated in 0.14978 seconds with 11 queries
