Originally Posted by mad dem21
I had the same problem about a week ago. My reverse light and mirrior would dip in any gear. Frist I thought it was the back up light switch and replaced it. Didn't do a thing. The way I fixed it was easy. The gear identification switch has a wire connected to it. That same wire splits in two and plug into a sensor that is a little forward of the gear identification switch. I just switched the two wires, somehow the wires were disconnected and someone put them on in reverse. problem solved..
Hmm, fishy. Who would be removing the connections to those two switches? They aren't in the way of any kind of maintenance procedure. This would only make sense if your trouble with the reverse lights happened directly following a visit to a mechanic. If the problem started randomly, then this is not a possibility.
I just got back from inspecting the transmission. I see only two switches, and two wire harness' on the drivers side of the transmission. RealOEM confirms this. The two wiring looms do come together and run side by side up over the tranny and through the chassis, but they do not splice together at any point. They are two separate harness'.
Upon detaching the connectors you can see that each sensor has two wires inside (the gear selector switch has both wires moulded into one strand of insulation making it appear as a single wire). I tested both switches for function:
Gear identification switch: Continuity test reveals that the switch is in a
normally closed loop position. Current harness connection colors: Violet/Purple Brown/Orange
Backup light switch: Continuity test reveals that this switch is in a
normally open loop position. Current harness connection colors: Grey/Black Grey
These switches have opposite functions, so it's easy to see that if the wiring harness' were reversed that the backup lights (mirror tilt, PDC, etc) would come on in neutral, rather than in gear. Yet this is not the case for either of us. The reverse lights DO come on in reverse. They also come on in every other forward gear. This leads me to believe that there is a problem with the gear identification switch circuit. These two circuits work together since the PDC works in reverse AND first gear. Unfortunately I don't have a wiring diagram resource to verify which wiring goes to which plug. Can anybody assist in this matter?
