Old 4th August 2004, 15:27   #1
Stem
Garage: 2000 M-5 Royal Red/Caramel
Check Brake Lining light question.
Just put new pads, rotors and brake wear sensors on the rear end. My Check Brake Lining message, and brake light were on since I disconnected the sensor and drove the car before doing the change.
After the change the lights are still on! Is this something that has to be reset at the dealer, or do I have to check my new sensor for some type of conductivity problem?
I know the Porsche has to get "dealer reset" for something like "low brake fluid" even if you top it off and the fluid level is back to normal! Is this the case with the M5 and the Brake Lining Light
Stem is offline
Old 4th August 2004, 16:56   #2
marinakorp
Garage: 99 540iT Grey
Re: Check Brake Lining light question.
on other E39's the re-set procedure for the BRAKE lignings (assuming all are in working order and no shorts, etc) is to turn the key to the start position (do not start... the one right before it actually turns the car over) and leave there for 30 seconds. stop and start the car... should re-set the light
if not... then you may have a continuity issue with the sensor
let us know how it works out for you
99 540iT
Powerchip Gold 93
M5 Rear Swaybars
Shadow Badging / Grill
marinakorp is offline
Old 5th August 2004, 07:09   #3
Stem
Worked like a Champ! Back to Normal.
Stem is offline
Old 5th August 2004, 16:07   #4
marinakorp
Excellent!
Help! - my brake fluid light came on Ashok Arora E39 M5 and E52 Z8 Discussion 4 17th February 2004 21:01
Brake Parts....have question TriflowM5+M3 E39 M5 and E52 Z8 Discussion 1 29th October 2002 15:44
Brake question M5NSX E39 M5 and E52 Z8 Discussion 4 7th October 2002 15:43
Clear light question for 2001 M5 E39 M5 and E52 Z8 Discussion 0 2nd October 2001 07:34
Brake Pads Question M5Bob E39 M5 and E52 Z8 Discussion 9 17th April 2001 17:20
Page generated in 0.11579 seconds with 11 queries
