Anyone else here using Mobil 1 Motorsport 15W-50 oil (UK members in particular)?
Just want to check if anyone else here is using Mobil 1 Motorsport 15W-50 oil in their beast. Mine is a 2000 model, and I had used 10W-60 when in the US, and now I use Mobil 1 Motorsport 15W-50 oil in the UK.
Here are some specs:
Product Description
Mobil 1 15W-50 is the most advanced performance synthetic engine oil designed to provide ultimate wear protection for a smooth driving experience every time. Mobil 1 15W-50, Motor Sport Formula (EU) and Performance Driving Formula (NA), exceeds the requirements of the industry and car manufacturers' standards required for high-performance turbo-charged, supercharged gasoline and diesel multi-valve fuel injected engines. Mobil 1 15W-50 is a winning race proven technology. It is especially suited for high-speed highway, towing, and other severe service situation. Mobil 1 15W-50, Motor Sport Formula (EU) and Performance Driving Formula (NA), provides extra heavy-duty engine oil performance and protection for the winning edge. Mobil oils are the official oils of NASCAR.
Features & Benefits
Mobil 1 15W-50 is made with a patented proprietary blend of ultra high performance synthetic basestocks fortified with Supersyn Antiwear Technology, the most advanced additive system available today. Mobil 1 15W-50's heavier viscosity together with patented Supersyn Antiwear technology provides the ultimate in dynamic lubricant protection. This feature is supported, not only by exceeding the toughest industry performance standards, it is proven in gruelling racing applications.
Applications
Mobil 1 15W-50 is recommended for all types of vehicles, suitable for use in high-performance turbo-charged, supercharged gasoline and diesel multi-valve fuel injected engines found in passenger cars, light vans and trucks.
Mobil 1 15W-50 is suitable extreme engine stress conditions, where conventional oil often cannot perform.
Mobil 1 is not recommended for 2-Cycle or aviation engines, unless specifically approved by the manufacturer.
Re: Anyone else here using Mobil 1 Motorsport 15W-50 oil (UK members in particular)?
not answering your question Daniel, but what is the oil protocol in the EU for our cars. do they have later M5s using 5/30 or is that a bmwna deal only?
As for the mobil 1, does it list approval by bmw as one of their "special oils", how about porsche approval? I'd bet it's fine, at least for warm weather.
thanks,
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
Hi Daniel,
I tend to stick to the recommended stuff, Castrol TWS 10-60 oil especially as my car is one of the older variants (MY99). From my talks with Birds(UK) tend to stick to the manufacturer recommendations too.
I wonder what BMW recommend for the new E60 V10 M5 ?
Originally Posted by Tin
Yep, I believe 2001+ cars can use 5w/60.
They tell us 5/30 in the US... for cars produced after 3/2000.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
Hi,
I was using 15/50 mobil motorsport until march of this year when my dealer recommended 10/60 castrol.
I find that i am having to top up less since the changeover but the vanos is louder on tickover (car is 1999 with 54k)
The motorsports 15/50 is all we run in the engines at work.
we get barrels or 5 gal buckets full.
I haven't had much street use yet as I was just given four 5 gal buckets to use. In or work engines they seal pretty quick after break in on the dyno.
And after a long run with temps as high as 93c we only use less then 1.5 liters after a hard 6 hour run.
It doesn't give you much street info but I can tell you when these engines get torn down they look great and it doesn't stink like normal oil(burnt).
Hi
My brother in law works as a technician at Porsche UK and all the techies are from either BMW, Lexus, Merc etc.
His mate who he works with came from BMW and he has said to me that it is fine to run the M5 on Mobil 1, he even said some dealers use it instead of Castrol.....
I have been running mine on Mobil and it is fine, also it is readily avaliable at most the service stations so when the obligitory top up is needed at least you are always using the same oils.
Oh yeah Beastpower i read about your car in BMW magazine it sounds awsome...
