Heater Temp always High on re-starting? - BMW M5 Forum and M6 Forums
Like Tree1Likes
  • 1 Post By curtissp321
Old 25th February 2015, 19:12   #1
rlich8
rlich8's Avatar
Garage: Silver S2000
Hello all,
I have a very minor problem on my newly purchased E39 M5. Whenever I re-start the vehicle, the temp is always on the highest setting (89? I believe..). I adjust it to mid sixties (it's winter here) and drive around and it is then fine.
I once had an E46 325Ci that I did the final-stage resistor on, but I seem to remember that being more in relation to fan speed. Is that the possible culprit here on my E39 M5?
Please let me know
Thank you!
Royal
rlich8 is offline   Reply With Quote Quick reply to this message
Old 25th February 2015, 23:43   #2
curtissp321
curtissp321's Avatar
Garage: E39 M5 Sterling Grey
That's a bit odd - don't think its a known resistor issue.
Have tried disconnecting the battery for an hour to reset everything - some odd gremlins can be sorted this way.
Simon
curtissp321 is offline   Reply With Quote Quick reply to this message
Old 26th February 2015, 00:15   #3
rao
Garage: Silver 540i
That's not a sign of the FSU going bad. I would also recommend trying to disconnect the battery or pull the HVAC controls out and disconnect them.
If you find this post unsatisfactory, please add me to your Ignore List so you will not be disappointed again in the future.
---> http://www.m5board.com/vbulletin/pro...?do=ignorelist
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
rao is online now   Reply With Quote Quick reply to this message
Old 26th February 2015, 00:42   #4
griffincox
griffincox's Avatar
Garage: 2001 BMW M5 - Le Mans Blue
This is something that the car can remember from driver preference via programming/the key. Mine resets to more modest 72 on restart.
griffincox is online now   Reply With Quote Quick reply to this message
Old 26th February 2015, 00:53   #5
rlich8
rlich8's Avatar
OK Thank you griffincox.
Old 26th February 2015, 01:31   #6
rao
Garage: Silver 540i
If it has always done this that makes a lot of sense. I was under the impression that this was a new development. Resetting the key memories is pretty straight forward if you have the software.
Old 26th February 2015, 15:13   #7
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (4)
My HVAC settings are always what they were when I shut down. Both temps, fan speed and ventilation choices.
gsfent is offline   Reply With Quote Quick reply to this message
Old 26th February 2015, 18:15   #8
rlich8
rlich8's Avatar
I'm going to start with unplugging the battery overnight and seeing if that does it. I am not currently driving the car everyday because it is winter and the weather is terrible but I definitely want to fix this. Thanks guys.
01 M5 Ti Silver/Black
01 S2000
71 E-Type Jag
Engine temp getting too high IM6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 27th April 2014 22:20
High oil temp yohan04 E60 M5 and E61 M5 Touring Discussion 7 12th April 2011 01:09
Is this il temp reading too high? RyanPW3 E60 M5 and E61 M5 Touring Discussion 6 14th August 2010 22:17
High Oil Temp Reading (and high Coolant maybe?) olis1 E39 M5 and E52 Z8 Discussion 46 21st May 2010 05:31
Cutting out with high outside temp JohnR E34 M5 Discussion 0 12th August 2005 00:00
