Old 4th May 2001, 12:45   #1
HBRAMSTEDT
Post DINAN SUPERCHARGER FOR M5
Does anyone know if or when the may be a supercharger package for the M5 from Dinan?
I believe chip tuning for supercharging and chassis tuning is their strength, not this cold air intake garbage.
HBRAMSTEDT is offline
Old 4th May 2001, 14:52   #2
Sean
Garage: Black '03 Porsche 996 TT
Send a message via ICQ to Sean
Post
From previous threads.....Dinan blower presently under R&D...expected completion 8 - 12 months!
Sean
Sean is offline
Old 4th May 2001, 16:05   #3
AndyMenard
AndyMenard's Avatar
Garage: 2000 Mustang Cobra R
Send a message via Yahoo to AndyMenard
Post
Steve Dinan was in Houston last weekend at the Momentum Performance Center and he indicated the supercharger is at least a year away.
There are alot of other things in front of the supercharger on the priority list... like...
1) Headers
2) new cams
3) new intake plenum
Andy
2000 Imola M5 / Black Nappa - Titanium Trim
AndyMenard is offline
Old 12th May 2001, 09:08   #4
Stallion M5
Stallion M5's Avatar
Garage: 2006 BMW M5 (Silver Gray Metallic)
Send a message via AIM to Stallion M5
Post
I'll be the first to bring the car there when it becomes available.
I also consider finding the twin turbo kit for it, which makes more sense.
Adrian
01 M5 LeMans Blue - Silverstone/Extended Nappa Point/Heritage - Titanium Trim
Stallion M5 is offline
Old 12th May 2001, 10:22   #5
tfung
tfung's Avatar
Post
should try BBR-GTi in the UK. They made a twin turbo 540, pumping out 800hp and 750lbs ft!
http://www.bbrgti.demon.co.uk/
tfung is offline
Old 13th May 2001, 05:37   #6
Aussie2U
Aussie2U's Avatar
Garage: 2000 Avus Blue M5
Post
If anyone knows - how do they get a good amount of boost going when the stock engine is already running 11-1 compression?
I mean on a hot day with 93 octane and full throttle, 11-1 compression is pushing the limit for detonation problems. Are they shimming the heads to lower the compression, and then adding the boost? Seems you would loose lots of low end torque to get more upper???
I'm sure we'll know more when it comes out, but it just seems like a big task to tackle on a high compression engine running pump gas.
Aussie2U is offline
Old 13th May 2001, 16:17   #7
Black M5
Black M5's Avatar
Garage: Black M5
Exclamation
Race Marque systems will be coming out with a superchanrger in the Fall. I spoke with them and they are hoping to start on the project in the summer/sept period to be ready after 10 weeks. It would be developing no less than 550 hp with an optional stage II after-cooler of another 50hp!
This kit will kick Dinan's supercharger's ***. I believe they are a rival company. Check their website out www.racemarque.com
Black M5 is offline
Old 14th May 2001, 01:02   #8
AJ
Post
they are either going to require heads porting to lower the compression, or they will cap the kit at 5-6 pounds of boost. that and running a good intercooler to lower intake temps. and race gas. maybe.
the m5 engine is very blower-un-friendly and stock they either will have to make internal mods or will end up with one expensive mess of pistons, valves and vanos pieces. i think the crank and connecting rods are good though for some double digit boost. i guess we will see
alex
00 m5
AJ is offline
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4496 Yesterday 09:15
How many of you guys, read GUSTAV's article on his DINAN visit/tour............ FAST 5 E39 M5 and E52 Z8 Discussion 21 16th June 2008 18:40
German AMS magazine tests M5 suspension kits lofstrom E39 M5 and E52 Z8 Discussion 25 11th April 2008 13:24
Adding MODS to your car and warranty being possibly affected................ FAST 5 E39 M5 and E52 Z8 Discussion 1 6th November 2003 22:44
Page generated in 0.13262 seconds with 11 queries
