• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 4th July 2004, 08:36   #1 (permalink)
          atomic80
          M5 Extraordinare!
          atomic80's Avatar
          Newly detailed blue beauty...the steps to perfection
          With the Pacific Raceway Historics coming up on July 4th, I set out to detail my M5. This would be a series of steps in giving the beast a thorough cleaning job. Many of my supplies were bought from Griot's Garage here in Washington. Others were purchased over the years from different sources.
          It took me a total of three days with several phases done over a short period of time.
          To start out with, this was just a small sample of the many supplies that I used:
          Day One
          I started out by washing the M5 using the P21s car shampoo with a sheepskin wash mitt and a green finger mitt (for the wheels and exhaust)
          Afterwards I removed the nozzle and used a gentle stream of water to get most of the water off. I used a micro fiber drying towel to get the rest of the water off. I cleaned everything including the wheels.
          Day Two
          I started out by checking to make sure that there were no residual dust left over. I would use a California Dust Mop to get the dust off.
          I also used Zaino's Clay bar
          with some Speed Shine.
          to get all of the contamination off until the finish was super smooth. I applied plenty of speed shine to ensure a wet finish while lightly applying the clay bar across the surface. This also works great to get the black soot from the exhaust fumes off the rear bumper too.
          I used some 3M General Adhesive Remover to get most of the black soot off the exhaust tips. This also worked great in getting the REALLY stubborn stuff off the bottom of the rear bumper too. I made sure to clean up all of the residual so there would be no long term damages. I did this as a precaution even though it's supposed to be clearcoat safe.
          After everything was all cleared away. I started things off by using the painter's blue masking tape (14 day delicate strength from Home Depot) on every trim piece and on the edges of the clear bra since wax/polish residue tends to build up there quite often. I also covered all of the window edges to ensure that nothing gets in the cracks. Wax/polish can cause the door edge sealings to start rubbing causing squeaking/creaking noises!
          This is what my M5 looked like when I was done taping it up.
          I was now ready to use the Porter Orbital. I used this incredible machine for only the polishing steps.
          I used three separate orange pads for each polish/glaze.
          First I applied a coat of Meguiar's Cleaning Wax which would remove any oxidation and lightly polishing the paint surface.
          I then used a detailing micro fiber towel to buff off the polish. (I used a clean one for each coating too)
          I considered skipping straight ahead to the glazing stage but I knew that my car had PLENTY of swirl marks so I went ahead and applied a coating of Meguiar's Swirl Remover too.
          And then for the last polishing step, I used Meguiar's Show Car Glaze which gives the paint finish the truly deep wet shine!
          And for the final step, I applied the Pinnacle Souveran carnuba wax paste by hand. I have used many different types of waxes over the years but this one is my favorite by far! It's easy to apply but the best part is that it's also easy to remove too! It takes just one swipe of the towel for it to come off! It gives the finish a 3D appearance and enhancing the already beautiful blue finish a truly "jewel" like look even more radiant. Having both the wax and the glaze in combination makes for a truly stunning finish!
          After I was all done with this step. I removed all of the masking tape and made one final run through with a clean towel making sure to get all of the "lines" left by the wax/polish residue.
          All this took me 3 hours and I was done for the day.
          Day Three
          I took this time to use the tiny cotton swabs.
          With the speed shine to clean out every nook and cranny throughout the car. I cleaned the engine bay, the trunk, the door edges, etc. I used the white micro fiber towel for the larger areas.
          For the leather surfaces I used Zaino "Leather in a bottle" with a terry cloth. This is my favorite because it has the best leather smell and preserves the leather quite well.
          For the rest of the car, I used some interior cleaner which does a good job of cleaning the dashboard, the door trim, and any non-leather surfaces without leaving a shiny finish.
          Finally, I vaccumed every square inch of the interior areas. Now I was all finished!
          The results speaks for itself.
          Whew! Tomorrow at the Historics, I plan to apply some tire shine to the tires when I arrive. For now, I'm ready for the Historics!
          Jason
          '05 Range Rover w/mods
          '05 K1200S w/mods
          '07 997TT w/mods
          '08 Audi A3 w/mods
          atomic80 is offline
          Old 4th July 2004, 08:41   #2 (permalink)
          Made
          Made's Avatar
          Re: Newly detailed blue beauty...the steps to perfection
          You swear it's not a new car? Incredible result, good job!
          ///Made
          Made is offline
          Old 4th July 2004, 08:59   #3 (permalink)
          EBMCS03
          EBMCS03's Avatar
          Send a message via ICQ to EBMCS03 Send a message via AIM to EBMCS03 Send a message via MSN to EBMCS03 Send a message via Yahoo to EBMCS03
          Hummm looks the same to me. hahaha
          J/K WOW thats crazy... I dont think I have that much dedication... I'm too lazy LOL
          Next: Interlagoes Blue E60 M5
          EBMCS03 is offline
          Old 4th July 2004, 09:07   #4 (permalink)
          RAREM5
          RAREM5's Avatar
          Send a message via AIM to RAREM5
          Awesome! Good job Jason!
          RARE ///M5
          2001 LMB DINAN ///M5 Gone but never forgotten!
          2005 Honda S2000 (Silverstone/Black)
          2005 Ducati 749S (Red)
          RAREM5 is offline
          Old 4th July 2004, 09:41   #5 (permalink)
          BKH
          BKH's Avatar
          Hey - I see some dust on your driver's side mat...
          BKH is offline
          Old 4th July 2004, 09:44   #6 (permalink)
          atomic80
          M5 Extraordinare!
          atomic80's Avatar
          Jason
          '05 K1200S w/mods
          '07 997TT w/mods
          '08 Audi A3 w/mods
          atomic80 is offline
          Old 4th July 2004, 12:44   #7 (permalink)
          Ahmed
          oh........................ my.......................... god !
          Don't wanna be too "insecure", so I will stick to my current cars:
          '06 Hummer H3
          '00 996 Carrera
          Ahmed is offline
          Old 4th July 2004, 14:29   #8 (permalink)
          Ashok Arora
          Ashok Arora's Avatar
          Great job Jason - how many hours did it take?
          Ashok
          2002 E39 Carbonblack/Caramel M5 (past)
          2005 E60 Blue Onyx/Caramel/Light Figured Ash M5 (past)
          2007 E90 Montego Blue/Black Alpina D3 (present)
          Beware the Red Cog of Death!
          Ashok Arora is offline
          Old 4th July 2004, 14:48   #9 (permalink)
          rost12
          rost12's Avatar
          Now that is detail, in both applicable meanings
          rost12 is offline
          Old 4th July 2004, 15:13   #10 (permalink)
          Tin
          Tin's Avatar
          WOW! that is an master art piece! good job!
          Kelleners ECU remap with Sport Camshafts, ACS DFC Suspension, 19" ACS TypeIII's, Brembo GT Kit (F:8pot/380mm front,R:4pot/345mm), Supersprint RHD headers,100cel sport kats,x-pipe and 90mm backboxes, ACS Rear Diffuser, Evosport lightweight pullies, Dinan Front & Rear Strut Bars, Dinan Rear SwayBar,ACS pedals & handbrake, GruppeM induction kit, AA CAI,IgnitionSolution PlasmaCoils, UUC Evo2 SSK, BeastPower brackets, NAV-Tv, MKIV Widescreen retrofit,2x10" M-Audio Subs, Hardwired V1,Xenon interior lights
          Tin is offline
