TECH: Replacing intake Camshaft Position Sensor... - Page 3 - BMW M5 Forum and M6 Forums
Old 6th November 2005, 23:06   #21
amrit50
amrit50's Avatar
Garage: 2000 white M5
Re: TECH: Replacing intake Camshaft Position Sensor...
I just removed the intake sensor on bank 2, and would like to show my appreciation to you guys by showing you how i removed it.
I cut off the end of a 5mm socket and epoxyed it to a mini ratchet. Once I got it loose w/ a long 5mm allen, i got the ratchet action going...this is probably the only way to get this bolt out.
amrit50 is offline   Reply With Quote
Old 8th November 2005, 16:01   #22
amrit50
amrit50's Avatar
I removed my intake and exhaust CPS on bank 2. I did the intake from under the car, and it was fairly easy w/ this tool I made, about 15 mintues and it was done, just had to remove the belly pan (very easy) and the black bracket being held in by 2 10mm bolts. All you need there is a racheting straight wrench.
Here's my shot from under the car on my back.
Old 3rd March 2006, 16:47   #23
KRM
KRM's Avatar
Garage: E91, MRS265
My engine management warning light just popped on tonight. I recalled the engine making some sort of noticeable rattling noise upon firing up, and the car is definitely sounding much deeper upon acceleration in the low revs.
This thread is well documented, thanks for posting it. But I wanted to ask: Is it suggested to replace all of them on one go?
Thanks!!
KRM is offline   Reply With Quote
Old 3rd March 2006, 18:01   #24
amrit50
amrit50's Avatar
I just did one and the car's back to normal again...I would guess just change that one that's bad.
Old 3rd March 2006, 18:27   #25
imolaman
imolaman's Avatar
Garage: 2001 BMW M5 Imola Red
THANK YOU JOHNNY!
Hi Johnny,
Many thanks for an excellent thread. Although it's annoying to see some other members hijacking the thread with some unwanted opinions about one of BMW's masterpieces, I nevertheless appreciate the sharing of your technical skills. Please post a similar write-up for the replacement of the other CPS's, if you can, I think all of us without warranties who knows how to use our hands does find it useful.
Best regards, Rudi
2001 Imola Red II E39 M5 - Stock
imolaman is offline   Reply With Quote
Old 6th March 2006, 09:24   #26
KRM
KRM's Avatar
Garage: E91, MRS265
amrit, thanks! A quick plug-in with the reader suggest my exhaust CPS in the right bank (cyl 5-8) has gone bad. According to boardmember Fart, the above instructions are for the exhaust CPS instead of the intake?
Thanks!
Old 18th September 2006, 15:22   #27
mjshira
Garage: Silver 2000 M5
great thread! thanks guys.
how many of these are there on the S62? I would assume two for each bank of cyl?
mjshira is offline   Reply With Quote
Old 18th September 2006, 18:51   #28
Nabio
Nabio's Avatar
Garage: Jet Black E39 M5
Ok, to clear things up (I just did this two days ago). There are a total of four CPS's on the S62. These instructions at the top of the page are indeed for the exhaust CPS. The intake CPS has the electrical plug (that goes to the DME) going straight up out of the block, not at a 90 degree angle like the CPS pictured (the exhaust). I was going to post a TECH on the intake but my camera battery was out.
Jet Black 2000 M5
Nabio is offline   Reply With Quote
Old 18th September 2006, 19:19   #29
mjshira
thanks man. so how often are these to be replaced? would it make sense to do all four at once?
Old 18th September 2006, 20:07   #30
Ocean's M5
Ocean's M5's Avatar
Garage: 2002 M5
Great thread...
Thanks for the detailed info
2002-05 Build Carbon Black ///M5
First Aid Kit ~ Warning Triangle ~ Full BMW Tool Kit
Rear Cupholders ~ Stubby Air Stems ~ Rear Shades ~ PDC
M Audio ~ Fold-Down Rears ~ Black Sport Int.~ Yokohama Advan Sport~
Beast Power Sway Brackets ~ Tinting-80% Strip Windshield
Center Armrest *Storage Bin ~ ///M Black Trunk Mat
Ocean's M5 is offline   Reply With Quote
UFMotorsport intake air temp. sensor installed! XrayMD E39 M5 and E52 Z8 Discussion 144 29th April 2005 00:24
Another HD intake and brake duct ArrestMeRed E39 M5 and E52 Z8 Discussion 9 5th September 2004 15:37
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
Post Camshaft Position Sensor Replacement Woes Joe Lapicki E39 M5 and E52 Z8 Discussion 11 7th April 2003 20:55
Camshaft position sensor Caribbean-M5 E39 M5 and E52 Z8 Discussion 3 27th February 2002 16:10
