TECH: Replacing intake Camshaft Position Sensor... - Page 10 - BMW M5 Forum and M6 Forums
Old 22nd November 2011, 22:06   #91
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
You have really dirty injectors and they are not closing properly, or there is an electrical fault in that bank 1 injector circuit by your last description..
Sailor24 is online now   Reply With Quote
Old 22nd November 2011, 22:27   #92
dan.
dan.'s Avatar
Garage: m5 e39 le mans blue 2001
I found this thread very usefull when doing all 4 of mine,i went all from the top and went you get all the right size tools
it was very easy,my arms did get a tad sore and red but i could do it alot easier next time.
I am not very mechanically minded so go for it.
dan. is offline   Reply With Quote
Old 29th September 2012, 08:42   #93
Dr.No
Dr.No's Avatar
Garage: E39 M5 LeMans Blue
Post Replacing both sensors on driver's side (usa) - do the job from the top or the bottom?
I replaced both sensors on the passenger side (the side without any hoses in the way) six months ago, and it appears the sensors on the driver's side now need replacing as the car is starting to act the same way it did before replacing the first two sensors.
I am not too thrilled about the idea of doing the job from the top as I got plenty of scrapes and bleeding last time around, plus hoses need disconnecting if I am to have any chance at doing the job from the top on the driver's side.
If jacking up the car and attempting the driver's side sensor replacements from underneath the car, is it doable without needing to disconnect hoses and without too much blood and pain for someone without small female hands/arms? I think my arms and hands are average/slightly above average size.
What would be the steps for replacing both sensors from underneath the car on the driver's (left) side?
Thank you very much for any clear and concise explanation of how to go about doing that.
Chris
Dr.No is offline   Reply With Quote
Old 29th September 2012, 09:22   #94
RICKROSS
RICKROSS's Avatar
Garage: 99 AVUS BLUE M5
you can see them quite well from underneath, try a combo of above and below to access them, the drivers side does have less room to move from above
RICKROSS is offline   Reply With Quote
Old 29th September 2012, 17:14   #95
Sailor24
Sailor24's Avatar
Use wire to pull the hoses out of the way and secure them. You don't need to remove them.
UFMotorsport intake air temp. sensor installed! XrayMD E39 M5 and E52 Z8 Discussion 144 29th April 2005 00:24
Another HD intake and brake duct ArrestMeRed E39 M5 and E52 Z8 Discussion 9 5th September 2004 15:37
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
Post Camshaft Position Sensor Replacement Woes Joe Lapicki E39 M5 and E52 Z8 Discussion 11 7th April 2003 20:55
Camshaft position sensor Caribbean-M5 E39 M5 and E52 Z8 Discussion 3 27th February 2002 16:10
