• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 1st July 2004, 01:13   #1 (permalink)
          Nolift911
          Nolift911's Avatar
          Real time tire pressures...
          Is it just me or is this a lacking feature? I skimmed the owners manual and saw nothing about getting real time readings. I have this feature in my Jeep and like to see the pressures on my monitor real time.
          Wouldn't there be an easy way to get the pressures and display them on the dash?
          -Jeff
          nolift911@hotmail.com
          Nolift911 is offline
          Old 1st July 2004, 02:08   #2 (permalink)
          XrayMD
          XrayMD's Avatar
          Re: Real time tire pressures...
          How about this...
          "June 18, 2004 07:55
          Tire Pressure Monitor incorporates RF and antenna technology.
          PressurePro™ monitors tires with pressures up to 150 psi and reads 1–34 tire positions. It combines small sensors that screw onto valve stems and monitor that plugs into power accessory in vehicle. System displays current tire pressures and alerts when tire pressures fall by 12.5% and again at 25%. PressurePro™ is suited for autos, RVs, buses, trucks, and towed vehicles.
          Advantage PressurePro Introduces to the Marketplace, PressurePro™ Tire Pressure Monitoring Systems
          Responding to the growing demand for Safety, Economy and Conservation of resources, Advantage PressurePro LLC., Harrisonville, Mo. introduces to the marketplace, PressurePro™ Tire Pressure Monitoring Systems, for Autos, RV’s, Buses, Trucks and Towed vehicles.
          Tire Pressure Monitoring is of utmost importance in adding safety, saving fuel, and extending tire life. The Firestone/Ford controversy cast a bright light on the importance of proper tire pressure. This issue has been reinforced by the Congress’ recent passage of the TREAD Act, which drives home the importance of tire pressure monitoring.
          PressurePro™ has pioneered the development of a revolutionary new external tire pressure monitoring system by incorporating patented RF & antenna technologies, bringing to the market a product that is versatile, reliable, durable, cost effective and simple to install and easy to use. Reading from 1 to 34 tire positions, and tires with pressures up to 150 psi, PressurePro™ delivers high reliability at an economical cost – adding greater safety and savings. Small sensors (2/3oz) screw onto the valve stems. The Monitor plugs into the power (lighter) accessory in the vehicle and displays current tire pressures (for all types of vehicles with pneumatic tires) and alerts at two low pressure levels - when tire pressures fall by 12.5% and again at 25%. PressurePro™ installs quickly and easily (the only system on the market that does not require tools to install).
          PressurePro is distributed nationwide through approved dealers, distributors, and their website at: www.advantagepressurepro.com
          For more information, contact:
          Joseph Haddy – Marketing Manager
          205 West Wall Street
          Harrisonville, Mo. 64701
          Ia. Tel: 319-298-0121
          Mo. Tel: 816-887-3505
          Toll Free: 800-959-3505
          E-mail: jhaddy@advantagepressurepro.com
          Contact Information:
          Joseph Haddy Marketing Manager
          Marketing
          USA
          Phone: 800-959-3505
          Company Information:
          Name: Advantage PressurePro LLC
          Address: 205 W. Wall Street
          City: Harrisonville
          State: MO
          ZIP: 64701
          Country: USA
          Phone: 816-887-3505
          http://www.advantagepressurepro.com
          Steve
          '02 M5 LeMans Blue:
          Supersprint Headers and cats
          Dinan Stage III suspension
          BeastPower sway bar brackets
          Dinan front strut tower brace
          RMS short shifter
          Llumar window tint (35%)
          XrayMD is offline
          Old 2nd July 2004, 01:40   #3 (permalink)
          jmlowe
          jmlowe's Avatar
          Hey JARIC DESIGN! Another opportunity looms...partner with these folks and give 'em an IBUS interface...see all four tire pressures in the info panel...way cool...
          JML
          2000 ///M5
          1999 V6 Passat GLS (great value but...uninspiring)
          1991 Civic Si (cheap fun!)
          1983 Rx-7 (gotta love a motor with 3 moving parts)
          ...and miscellaneous prior vehicles too shameful to list
          jmlowe is offline
          Old 2nd July 2004, 01:50   #4 (permalink)
          M-Fünf
          M-Fünf's Avatar
          As I understand it, the M5 doesn't actually monitor pressure, rather it measures rotation speed. When it senses a delta in rotation speed under certain circumstances, it assumes that a tire is low/flat.
          I like the pressurepro idea, but I think they might be too large/heavy. The current M-logo caps (not the stock caps) will bend over at high speed and actually touch the rim. If this thing is any heavier, it will take a beating against the rims...
          If it's a radio device, why can't they make one that mounts like a tire weight inside the tire on the wheel???
          M-Fünf (a.k.a. Jeff)
          His: '03 M5 Ti Silver/Silverstone
          Her's: '04 M3 Silver Gray/Black 6 speed
          M-Fünf is offline
          Old 21st August 2004, 05:22   #5 (permalink)
          XrayMD
          XrayMD's Avatar
          OK...how about www.smartire.com available from Tirerack.
          Steve
          '02 M5 LeMans Blue:
          RMS short shifter
          XrayMD is offline
          Old 21st August 2004, 16:36   #6 (permalink)
          BeastPower
          Guest
          Posts: n/a
          Fellow board member, Greg, has the Smartire system. He seems to be very happy with it.
          Cheers.
          Old 21st August 2004, 17:27   #7 (permalink)
          XrayMD
          XrayMD's Avatar
          Smartire has a new system being tested that uses no batteries. This should give the sytem longer life and it will also weigh quite a bit less. I don't know how long until it will be available. The sensors are strapped to the rims before putting the tires on rather than the valve-stem cover type.
          Steve
          '02 M5 LeMans Blue:
          RMS short shifter
          XrayMD is offline
          QUESTION: Need advise from guys who have real tire mounting experience............ FAST 5 E39 M5 and E52 Z8 Discussion 3 8th January 2003 06:30
          some sage advice re: tire pressures for the track greg E39 M5 and E52 Z8 Discussion 4 30th March 2001 02:12
          tire pressures david enock E39 M5 and E52 Z8 Discussion 7 1st January 2001 17:30
          Tire Pressure MEnthusiast E39 M5 and E52 Z8 Discussion 9 7th July 2000 02:00
          tire pressures for maximum all-around grip healeyg E39 M5 and E52 Z8 Discussion 6 6th June 2000 03:09
          Page generated in 0.33615 seconds with 11 queries
