Re: 95 or 98 oct fuel question
Originally Posted by Fart
What should I use, the 98 is somewhat more expensive.
Will it make any difference in performance. What about oil consumption.
If you drive moderately, you can use the lower octane. However, very few Beast owners don't "get on it" occasionally, so you generally want the higher octane if you want maximum performance or do a lot of full throttle runs. I don't think octane affects oil consumption, although full throttle runs will!!
