Old 29th June 2004, 10:53   #1
Woogie Daxel
Guest
Garage: 00 M5 Silver
1st mod and did not even know it!
Found out that my used M5 has Dinan software chip. No wonder I got it up to almost 140 the other day. I assume stock limits are 120-130mph? Correct me if wrong.
Since I have not really felt the true stock M5, was wondering if any of you guys w/ Dinan software actually noticed any "noticeable" gains after installng the chip on their stocker; or is it just a fluke besides removing rev limit?
Ltrz,
Woogie.
Woogie Daxel is offline
Old 29th June 2004, 11:12   #2
Ashok Arora
Ashok Arora's Avatar
Re: 1st mod and did not even know it!
Stock limiter is 155mph.
Ashok
Let me tell you what SMG stands for...
Ashok Arora is online now
Old 29th June 2004, 18:06   #3
XrayMD
XrayMD's Avatar
Garage: LeMans Blue M5,Silver X5 & Dk. Silver Mini S
(Correct me if I'm wrong - it happens occasionally!)The Dinan chip does little more than remove the top limiter and (I believe) raise the rev limiter. CHeck out www.powerchipgroup.com if you want software that will improve your driving experience by remapping the ECU.
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline
Old 29th June 2004, 19:18   #4
Black M5
Black M5's Avatar
Garage: Black M5
What you get with the Dinan software is:-
1) the accelerator becomes more responsive (like using the sport button when its stock. Use the sport button now and it becomes even more responsive)
2) removes the topspeed limiter,
3) it bumps the rpm redline from 7000 to 7200
Black/ Black & Grey E60 /// M5 Nicknamed Mighty M5
Exterior
RD sport front splitters (diablo has a full lip)
RD sport silver CF front inlets
Kidneys painted black (just like diablo)
CF front and rear emblems (just like diablo)
CF double sided bonnet (coated and unpainted- just like diablo )
CF logo
AC schnitzer mono block V. 8.5x20 in the front and 10x20 in the rear. 245/35 ZR20 & 285/30ZR 20
AC Schnitzer roof spoiler (just like diablo)
CSL CF trunk
AC Schnitzer rear diffuser
Smoker LED rear lights (just like diablo)
CF side grillle
V-cool all around tint
Interior
AC schnitzer steering wheel (just like diablo)
CF logo
AC scnitzer black i-drive cover (model of wheels)
Hamann pedals (just like diablo)
CF BMW steering wheel logo (just like diablo)
Trim body matched
Corbeau racing seats. Weigh only 27 lbs
Custom 2 tone interior- black and grey leather with yellow stiching
Custom door panels. same as above.
Performance
EvoSport headers (diablo has SS headers)
EvoSport pulley
ESS computer upgrade
SS race mufflers (diablo has sports mufflers)
SS X pipe (just like diablo)
RPI intake w/black scoops
Brembo 15" front and rear brakes with yellow calipers (diablo has red calipers)
16" OEM fan installed at the front of the radiator
H&R lowering springs
Gone but not forgotten
Supercharged e39 M5 nicknamed El Diablo
700+whp@only 13 psi. Has all the mods in the book minus racing seats.
Sold to board member wilsodh
Black M5 is offline
Old 29th June 2004, 19:21   #5
khiroshima
khiroshima's Avatar
Garage: 2001 M5 silver
Keep in mind as well that even though your speedo might have registered 140 mph (and that the actual limit is 155mph), BMW's speedos tend to read slightly higher than the actual speed (up to 10%), so worst case, you may have to take the car up to 165-170 (registered to find out if you REALLY don't have a speed limiter.
Have fun, drive safely. Kevin
khiroshima is offline
Old 29th June 2004, 21:05   #6
Woogie Daxel
Guest
Thanks Fellas!!!!!!!
Old 30th June 2004, 00:39   #7
SC'dKellenersM5
SC'dKellenersM5's Avatar
Garage: Red White and Blue
Hate to bring this up (again)
but dinan stgI software= usless! specially for the price!
SC'dKellenersM5 is offline
Old 30th June 2004, 01:08   #8
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
check the Dinan vs. Powerchip thread running right now.......
gsfent is offline
Old 30th June 2004, 01:15   #9
warhaven
warhaven's Avatar
Garage: 2002 M5 Jet Black
I have to agree with the stage 1 comment however, it's not designed to do anything other than improve throttle response. Stage 1 is a software program that is designed for a car with no other modifications complete. Thus there are really no real HP gains to be had from "remapping" the EMS. Not until you start getting into the intake and exhaust side of the engine i.e. Cold Air, velocity staks and throttle bodies and headers/exhaust does the software "remapping" really make a difference. You have to remember that Dinan worked their modifications to have a cumulative effect on the car. This is why there are numerous other companies that offer products that claim HP increase on a per unit (or item ) basis greater than Dinan. However the cumulative and I must add balaced effect is tremedndous. The problem as you rightly mentioned though is price. Dinan is expensive.
I stongly encourange the individual who is not planning to do a system approach i.e. all the components needed for a particular stage of Dinan software thus to go elsewhere. But if your in it for the long term and continue to make modifications to your car the cumulative effects of the Diinan process are hard to beat. 470HP rocket. I don't know anyone who has done other mods that exceed that HP rating to date.
Warhaven's 2002 Dinan S2 M5
11/22/04 Dyno: 336.2RHP/329.2T (Exhaust only)
03/15/05 Dyno: 334.38HP/326.24T (+CAI)
06/22/06 Dyno: 348.76HP/331.33T (+ MAF)
Jet Black/Black
Super Sprint X-pipe
AA Front Grill
TC Racing Pedals
TCD Sway bar brackets
MK4 V28.1 NAV upgrade
Zenon 8000K Stage II upgrade
warhaven is offline
Page generated in 0.67524 seconds with 10 queries
