• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 27th June 2004, 00:50   #1 (permalink)
          ngc5904
          ngc5904's Avatar
          Silly question: Which color do you use on your NAV?
          Ok, here's the pointless question of the day? Which color scheme do you use on your NAV computer? I myself am partial to "3", which, at least in the US, is the blue/gray one, depending on if the headlights are on or not.
          Which brings up another question. I wonder if the color scheme's are consistent across all the countries?
          Just curious...
          'ngc5904'
          2002 CF black M5/black lux interior
          2001 525iT (wife's)
          1992 Green 325iC (Sold)
          1998 Yellow K1200RS
          DSC: on/Sport: off (or on... )
          ngc5904 is offline
          Old 27th June 2004, 02:46   #2 (permalink)
          El_Mono
          El_Mono's Avatar
          Re: Silly question: Which color do you use on your NAV?
          I used the blue/orange one for the longest time but found it to be excessively bight at night. I have now selected the muted brown one.
          2003 Carbon Black / Silverstone - M5 (duh)
          All the fixin's
          Bluetooth - SE w810
          Miltek Exhaust
          Aux Input - Not sure why I installed this, Sirius RULES.
          Sirius - The only way to go ...
          El_Mono is offline
          Old 27th June 2004, 05:08   #3 (permalink)
          Osodog
          Osodog's Avatar
          I go with the blue/gray, seems to match the interior the best.
          Osodog is offline
          Old 27th June 2004, 08:51   #4 (permalink)
          Woogie Daxel
          Guest
          I have the purple w/ pink polka dots.
          See, you gots to COORDINATE!
          Woogie Daxel is offline
          Old 27th June 2004, 12:38   #5 (permalink)
          ngc5904
          ngc5904's Avatar
          El_Mono, you have BT in your 2003 M5. I am insanely jealous. My M has a build date of 10/01, and it's four months too old to have the BT capable head unit.
          I'm so jealous. Maybe someday they'll retrofit it back to my "old" car. Either that, or I'll just swap the entire system out from a 2003.
          Four **** months...
          rasputin
          'ngc5904'
          2001 525iT (wife's)
          1998 Yellow K1200RS
          ngc5904 is offline
          Old 27th June 2004, 12:39   #6 (permalink)
          ngc5904
          ngc5904's Avatar
          Ok, Woogie, what movie was that from? I can ALMOST remember it.
          I'm straining my brain trying to remember...
          rasputin
          'ngc5904'
          2001 525iT (wife's)
          1998 Yellow K1200RS
          ngc5904 is offline
          Old 27th June 2004, 15:18   #7 (permalink)
          paulbondy
          Boomerang!
          2006 S55 AMG
          Former 2002 M5 Owner
          Soon to be 2009 Carbon Black owner
          paulbondy is offline
          Old 29th June 2004, 11:01   #8 (permalink)
          Woogie Daxel
          Guest
          Yeah your right paulbondy, I love that line!HAHAHAHAH
          Ltrz.
          Woogie.
          Old 29th June 2004, 21:51   #9 (permalink)
          mottati
          mottati's Avatar
          Four **** months...
          rasputin
          Off the subject, but there is a kit out by the people at www.bmwnav.com to retrofit BT in an earlier e39. i am the "beta tester" for their current kit, it was designed around the e38, but should all work for the e39. I'm awaiting a couple of e39 specific brackets to get it all mounted, then i'll need to get my car coded for the phone. I should have more info by the end of the week. I have no affiliations with bmwnav.com other than being a previous customer (when i updated to the widescreen nav) and this current project.
          PM me if you want more info. My car is a 6/00 production 00 M5, by the way.
          Engine:
          Suspension:
          Interior/Misc:
          mottati is offline
          Old 30th June 2004, 00:30   #10 (permalink)
          El_Mono
          El_Mono's Avatar
          I just looked and I only have "2" choices. Blue/orangey and brown/grey. Where is this choice #3 ??
          All the fixin's
          Bluetooth - SE w810
          Miltek Exhaust
          El_Mono is offline
          Old 30th June 2004, 09:14   #11 (permalink)
          atomic80
          M5 Extraordinare!
          atomic80's Avatar
          The older NAV OS (prior to v18) had three color schemes.
          Jason
          '05 Range Rover w/mods
          '05 K1200S w/mods
          '07 997TT w/mods
          '08 Audi A3 w/mods
          atomic80 is offline
          Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post! Add this post to your Facebook Profile Add this post to MySpaceStumble this Post!
