Old 26th June 2004, 04:36   #1
Mvious
Mvious's Avatar
Garage: 2001 Lemans Blue M5
Sales Feedback: (3)
Suspension ????????
Curious to know if any one has used the H&R Lowering springs. If so did you feel any difference in the ride?
Also want to know it it help the handling?
Thanx in advance
Marion
Mvious is offline
Old 26th June 2004, 04:56   #2
2003 M5!!!
2003 M5!!!'s Avatar
Garage: 2003 Silver M5
Re: Suspension ????????
I use then (and some pictures are posted). You know for 300 bucks, I really really like then.
The front is lower (which on a BMW is a must!). The ride feels about the same, but I have to be careful when I park.
I also think that the traditional BMW understeer has decreased. It feels more even, but I don't know why. If you read the posts, the front springs are stiffer. Stiffer front springs usually mean increased understeer.
I am no rocket scientist, but maybe it is because the weight of the car is a little lower that the unersteer is reduced? Who knows. Maybe someone can comment on this . . . The guys at H&R have apparently commented on this, but I don't know their technical reasons, as I wasn't a party to the conversation.
If you want the back to be lower, or if you want the front to be more than one inch lower (and you have 2 thousand), then the coilovers are a great option that allow one to play with the settings (including the camber). For me, this wasn't really an option if I didn't want to find my stuff on the lawn.
It is basically stock, with a meaner look (a little), and with less understeer. For 300 bucks plus 100 or so for installation you really cannot go wrong. You can always do the coilovers later and you will only be out a few bills. The only thing I don't want to do now is add Dinan camber plates because the ride hight will be raised a 1/4 (or maybe an 1/8) of an inch. For me, the front can be no higher than it is now, only lower. But this is the only negative for me. Otherwise, one great and cheap product.
Thanx in advance
Marion
Silver 2003 M5
GC Coilovers by Shadowman
Supersrint Headers by Shadowman
Supersprint X-Pipe
Dinan Exhaust
Shadowman Software
IATS by Shadowman
AA Cold Air Intake
Dinan Rear Sway Bar
Dinan Front Strut Bar
B&M SSK
DSSR
Power Pulleys
SSR GT3s - 8.5 & 10 x 19 w/ SO3s & 285s in Back
View My Alien Technology Project!
2003 M5!!! is offline
Old 26th June 2004, 05:47   #3
Mvious
Mvious's Avatar
Sales Feedback: (3)
2003 M5!!!
Thank you very much! You couldn've done a better job in answering my question. I also look at your car it looks GREAT!!
I am placing my order on monday!!
Thanx
Marion
Mvious is offline
Old 26th June 2004, 08:52   #4
2003 M5!!!
2003 M5!!!'s Avatar
No problem.
Take a look at STANM5's (I think this is right?) car. He has the springs too, but he has 19. You can see the ride hight with 19s - it actually looks real good.
His recent post was something like . . . my ride has new shoes, or something.
Another good thing about keeping the rear up a little higher is you can put 285s on if you go with 19 x 10s without any issues. It seems you can still lower it a bit in the back (later) with this set up too with no rubbing issues. Win Win.
2003 M5!!!
Thanx
Marion
Silver 2003 M5
Supersprint X-Pipe
Dinan Exhaust
Shadowman Software
IATS by Shadowman
AA Cold Air Intake
Dinan Rear Sway Bar
B&M SSK
DSSR
Power Pulleys
Old 26th June 2004, 20:04   #5
BeastPower
Guest
You will not see any significant improvement in handling without going for coilovers. This is not what you wanted to hear, but it is the truth - speaking from lots of direct and indirect experience.
Cheers.
Old 26th June 2004, 21:10   #6
2003 M5!!!
2003 M5!!!'s Avatar
Agreed!
BeastPower,
Can you explain why H&R claims a minor reduction in understeer (but the springs are stiffer, which should create more?)?
This has always been a little confusing to me -- and I wouldn't normally want to add such springs if understeer is increased.
Thanks!
Cheers.
Silver 2003 M5
Supersprint X-Pipe
Dinan Exhaust
Shadowman Software
IATS by Shadowman
AA Cold Air Intake
Dinan Rear Sway Bar
B&M SSK
DSSR
Power Pulleys
Old 27th June 2004, 02:37   #7
stanm5
stanm5's Avatar
Garage: 2000 e39 M5 avus blue/two tone grey
Thanx in advance
Marion
Hi Marion,
I've attached a pic of my car with H&R springs in front, stock springs in back, 19" LM's.
The ride is a little bit harsher than stock but I don't really think handlibg is improved. Overall I'm pleased but I may opt for coilover in the near future.
Cheers,
stanm5 is offline
Old 27th June 2004, 08:49   #8
Woogie Daxel
Guest
Garage: 00 M5 Silver
IMO I think coilovers would be a waste of money if you are not periodically (spell check) tracking your car at events and you are just buying to use to lower the car more for looks and daily driving. Im getting some H&R's to drop my car also. I have no plans to track this currently. I have a couple other vehicles for that. Whether it is H&R anything you cannot go wrong.
Woogie Daxel is offline
Old 27th June 2004, 12:10   #9
BeastPower
Guest
Woogie Daxel,
I do see your point here, but I disagree with it. The best way I can describe the effect of coilovers is as follows:
1) They will allow you to lower the ride height.
2) Ride will be firmer than stock.
3) The "bouncy" nature of the "rear" of the M5 is eliminated.
4) When cruising on flat surfaces the firmness of the ride is not noticable.
5) When going over bumps (undulations in the road surface) there is a tendency for the M5 to bouce/rock ever so slightly.
6) Even at the lowest drivable ride height, entering and exiting driveways is not a problem (take it at an angle if necessary - this is what Ferrari/Lotus/Porsche/Lambo owners do all the time).
7) The M5 will corner almost completely flat, and taking on-ramps/off-ramps is an amazing experience.
8) The M5 handles within 9/10th of a Ferrari F355, Lotus Esprit and Porsche 911. I know this sounds implausible with a 4K pound 4-door, but this can be verified by owners of the M5 (e39) who have installed KW coilovers, and who have driven an exotic 2-seater sports-car.
It is because of this last point (#8 above), that I don't understand why more M5 owners don't install coilovers. Most owners of exotic 2-seater sports-cars never take their cars to the track, but just enjoy the great handling during daily driving; shouldn't M5ers also have fun? Just my $0.02
2003 M5!!!,
I will leave this one for Lscman, as he is the resident suspension expert.
Cheers.
Old 28th June 2004, 12:19   #10
m5 rus
m5 rus's Avatar
Garage: M5 Silverstone
Send a message via AIM to m5 rus Send a message via Yahoo to m5 rus
Thanx in advance
Marion
A fellow M5 owner had them of his M5 when he bought it used....He said it was too stiff....hard riding...you feel every bump....of course Russian roads are not that good...
He put OEM suspensions back...
Misha...
211 E55K AMG Mod...620 HP and 900 NM
E39 M5...sold...
m5 rus is offline
The definitive Ground Control coilover suspension discussion thread - step on in! Redshift E39 M5 and E52 Z8 Discussion 61 1st August 2004 22:27
ACS DFC suspension finally installed!!! tfung E39 M5 and E52 Z8 Discussion 19 18th May 2003 23:31
Lets talk suspension...... Tim W E39 M5 and E52 Z8 Discussion 17 22nd July 2002 15:30
Dinan suspension M5 + a slew of Z3 roadsters + supercharged M coupe! (LONG!) atomic80 E39 M5 and E52 Z8 Discussion 22 23rd April 2002 07:11
Adjustable performance suspension Jonathan E39 M5 and E52 Z8 Discussion 5 12th June 2001 22:50
Page generated in 0.18282 seconds with 11 queries
