Old 25th June 2004, 18:52   #1
alpineblue
Garage: 2003 M5, Alpine White
Bluetooth Problems
I continue to be unimpressed with Bluetooth, which was recently installed by my dealer. I use Cingular with the Motorola V600. Even at max gain, it is often hard to hear people speaking to me. I was hoping you could boost the volume just by turning up the soundsystem, but you can't.
Further, I get a lot of crackling in the system with incoming calls, and I continue to sound like I am speaking in a can.
Anyone out there with any suggestions--is it my phone, Cingular, or just crappy Bluetooth hardware? Not worth a $1000 yet.
Mark
2003 M5
alpineblue is offline
Old 25th June 2004, 21:01   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Re: Bluetooth Problems
Mark, you might try getting in touch with Jonathan Spira. He was the original BT in an E39 in the US, and has written a couple of articles on BT that were in Roundel. He often posts on the roadfly boards, here's his email address:
jbsbmw@basex.com He seems to be the E39 BT authority.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 25th June 2004, 22:30   #3
alpineblue
thanks mike--see you on the 12th. mark
Visteon and BMW planning September Bluetooth rollout Teutonaddict E39 M5 and E52 Z8 Discussion 2 27th August 2002 20:40
Confirmed - Bluetooth phone for MY03 andrewe E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 21st August 2002 15:32
Trip to Nordschleife/Brake problems solved johann E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 18 2nd August 2002 23:20
Trip to Nordschleife/Brake problems solved johann E39 M5 and E52 Z8 Discussion 20 19th July 2002 21:36
Is BMW loosing it? Severe technical problems w new 7! Black B10V8 E39 M5 and E52 Z8 Discussion 23 17th January 2002 09:48
Page generated in 0.09595 seconds with 11 queries
