Old 25th June 2004, 04:06   #1
paulbondy
Garage: Silver/Black 2006 S55 AMG
Losing power over 6k rpm in 1st gear????
I've never really taken my car to red or orange line before. Tonight I decided it's time to drive her. Well, when I got just above 6k rpm...right about where the orange indicator light is, the power completely shut down. I could chirp it into second and continue normally. Has this happened to anyone else? Power loss somewhere between 6,200 and 6,700 rpm? Shouldn't the car continue to pull all the way into redline???? Any help would be appreciated. Thanks!
2006 S55 AMG
Former 2002 M5 Owner
Soon to be 2009 Carbon Black owner, but maybe a 2009 760...depends on what engine they put in it.
paulbondy is offline
Old 25th June 2004, 05:11   #2
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
Re: Losing power over 6k rpm in 1st gear????
The tachometer has needle damping (like most gauges), and the rate of change of rpm in 1st at WOT results in tach needle position lag. When it looks like you're just getting a bit over 6k, you are already at redline. The rev limiter is kicking in, and that is what you are feeling as a power loss. (I'm guessing this is your situation anyway). It took me a while to get down just where to shift 1-2 in the M5 because of this issue. The higher gears don't exhibit this behavior as the needle's rate of change is slower. My V70R behaves exactly the same way, and I was fortunate to talk with Hans Nilsson (Volvo's R "guru") about it -- hence where I learned of this issue. I'm extrapolating what he told me to the M5 (he did mention that it is a common issue in other high performance cars).
Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
CSBM5 is offline
Old 25th June 2004, 08:45   #3
BmwNut
BmwNut's Avatar
Garage: '01 540/6
Send a message via AIM to BmwNut
A way to test if it is needle lag or if it is a true power loss to would to slowly wind the engine out to redline in first gear. Accelerate briskly but not at full throttle, and see if the problem still occurs. A slow run through the gears would answer that question.
Does it do it in other gears? If it doenst, then I think the dampened needle might have got the best of you.
-Brendan
'01 540/6
BmwNut is offline
Old 25th June 2004, 14:08   #4
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
Sounds like the rev-limiter to me. Be glad its there
All the best,
MEnthusiast is offline
Old 25th June 2004, 17:14   #5
paulbondy
Thanks for the help. I've give the tips a try and see what happens.
2006 S55 AMG
Old 25th June 2004, 21:18   #6
BmwNut
BmwNut's Avatar
Garage: '01 540/6
Anytime
-Brendan
'01 540/6
BmwNut is offline
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 61 7th January 2009 11:06
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
Losing Power! Trax2 E39 M5 and E52 Z8 Discussion 25 8th July 2002 20:36
Optimal Shift Points-it's at 7000 KirklandM5 E39 M5 and E52 Z8 Discussion 26 14th June 2001 01:58
Page generated in 0.14032 seconds with 11 queries
