Old 23rd June 2004, 14:26   #1
PAN5R
Garage: M5 LE Orinocco Green, M5 LE Rosso Red, M635csi Dolphin Grey
DVD SAT NAV UPGRADE
Can you upgrade a Mk3 CD based sat nav to a Mk4 DVD based unit. Is it just a case of taking one out and replacing it with the new unit or do you require additional eqiupment?
PAN5R is offline
Old 23rd June 2004, 18:40   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Re: DVD SAT NAV UPGRADE
It was a simple plug and play for me when i upgraded my mk2 nav to mk4. Unplug the old and plug in the new, all worked fine. (although on a mk 2 there is a little more to do, but still simple install)
mike
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 23rd June 2004, 19:08   #3
PAN5R
thanks for that!
PAN5R is offline
Old 23rd June 2004, 19:10   #4
M5Kid
Garage: N/A
The install may be relatively easy, but the cost for parts is well over 1,000 dollars.
Travis
M5Kid is offline
Old 23rd June 2004, 19:51   #5
atomic80
M5 Extraordinare!
atomic80's Avatar
Garage: 2007 Cobalt Blue Porsche 997TT
Not from BMWNAV.com. I bought the DVD Nav drive for $775 through ebay.com which was the same fellow who runs BMWNAV.com. I got the NAV DVD Disc from him for $150 too.
It was VERY easy to install too....disconnect battery, take old unit out, plug in the new one, install the software and then I was up and running. Took me all of 30 minutes.
Jason
'05 Range Rover w/mods
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
atomic80 is offline
Old 23rd June 2004, 20:57   #6
mottati
mottati's Avatar
Travis
You can get a dvd nav drive from the dealer for somewhere between $1100 - 1800 depending on the dealer! or from the internet/ebay for around 1k. If i had a mk3, i probably wouldn't have changed it, but to me, it was worth upgrading my mk2.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 23rd June 2004, 23:41   #7
Nolift911
Nolift911's Avatar
Garage: 01 LMB
What are the benefits of doing this if I may ask...sorry newbie.
I have a 2001 what mk is that? What does the DVD based give you? When you replace the unit or upgrade is it just the rear unit or the front also?
-Jeff
nolift911@hotmail.com
Nolift911 is offline
Old 24th June 2004, 00:39   #8
mottati
mottati's Avatar
-Jeff
a 2001 would have a mk 3 system. the dvd system is a little faster, and you get the entire country on one disc. It also has some other point of interest features on it. You can search for stores, doctors etc by city. This is just the trunk mounted unit. I had the smaller nav screen, which i updated as well.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 24th June 2004, 00:48   #9
atomic80
M5 Extraordinare!
atomic80's Avatar
Jeff, the benefits are as Mike mentioned but I should also point out that I think the speed upgrade is MUCH improved over the Mark III version. There is virtually no lag when you use the knob.
Mike, did yours end up showing everything in "yards" instead of "feet" after you upgraded? Mine did after I installed the OS.
Jason
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
atomic80 is offline
Old 24th June 2004, 01:10   #10
mottati
mottati's Avatar
There is a very great improvement over mk 2, which was probably worse than mk3 in the knob push to execute time.
Yes, i'm in yards, with no accept screen. Not a problem to me, i'd rather not have the accept screen, and don't have bmw assist, nor do i need the emergency function. I'm surprised there's no option to have it in meters though (rather than yards).
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Opinions needed on DVD Nav upgrade dmz E39 M5 and E52 Z8 Discussion 2 27th January 2004 17:14
Who in SoCal has the recent ETK/TIS CDs - I want to upgrade to DVD NAV INVICTO E39 M5 and E52 Z8 Discussion 4 29th November 2002 23:14
DVD sat. nav. lasseoe E39 M5 and E52 Z8 Discussion 12 8th October 2002 04:16
Nav Sw Ver 18 upgrade - FAQ 1C00lVC M5 E39 and E60 tips & tricks 0 12th March 2002 06:00
Page generated in 0.38152 seconds with 11 queries
